Initial Battery Charge Poll results
Submitted: Tuesday, Sep 22, 2009 at 21:44
ThreadID: 72472 Views:2345 Replies:1 FollowUps:12
Thanks to those who took part in the poll and I am not going to post up any opinions on the results, people can come to their own conclusions.
Anyway here is the initial results from 52 replies of the Cranking Battery Voltage reading are as follows :-
95% ( 12.6 ) or higher = 25
90% ( 12.5 ) or higher = 13
80% ( 12.42 ) or higher = 4
70% ( 12.32 ) or higher = 2
Lower than 70% ( 12.32 ) = 8
There is a lot more data to be sorted yet but this was the main aim of the poll.
The Highest reading was 12.95v and the lowest was 11.83v
A small number of the reading were taken less than 12 hours from the last time the motor was run so I will have to do some calibrating.
Again Thank you to all those who contributed.
Reply By: Member - Toyocrusa (NSW) - Wednesday, Sep 23, 2009 at 06:55
Hi. I'm wondering how you find out about polls like this.Didn't see it when it was running. Bob.
AnswerID: 384274
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Sep 23, 2009 at 07:29
I am still getting the hang of polls too.
When you got to the forum, at the top of the forum under the banner there is a row of tabs, poll is the last one at the right.
FollowupID: 652025
Follow Up By: Sir Kev & Darkie - Wednesday, Sep 23, 2009 at 07:33
Bob and John,
Drivesafes initial thread
This was not an EO poll as such just another thread ;)
Cheers Kev
Russell Coight:
FollowupID: 652026
Follow Up By: Who was that again? (Vic) - Wednesday, Sep 23, 2009 at 08:52
Sir Kev, even reading the post you have the link to doesn't allow us to understand the point of the poll in drivesafe's post. Some secondary batteries are of different designation and require different charging characteristics. There will be no conclusions to be drawn from the poll, that will be of any value.
FollowupID: 652047
Follow Up By: Maîneÿ . . .- Wednesday, Sep 23, 2009 at 09:34
Who was that again?
Mate you should read the thread again, the entire thread is EXCLUSIVE to Cranking batteries.
There's NO reference anywhere to Auxiliary (secondary) batteries.
You say: "Some secondary batteries are of different designation and require different charging characteristics" yes, but as can be clearly seen they were not involved in the 'poll' in any way.
You then say: "There will be no conclusions to be drawn from the poll, that will be of any value"
I'm sorry you can't see a conclusion from the 'poll'
I believe it's obvious the "70% Cranking battery charging myth" has been resolved.
It can be seen ~50% of batteries are shown to be still registering 12.6v, 12 hours after being removed from their charging source, if this is not indicative of >70% charged then I will be informed here (very) soon :)
Maîneÿ . . .
FollowupID: 652058
Follow Up By: Sir Kev & Darkie - Wednesday, Sep 23, 2009 at 09:34
John,
Drivesafe started the poll not me LOL
As to what was hoped to be gained out of it, I presume only he would be able to explain it??
From what I gather it was only based on Primary batteries and not any additional ones.
Cheers Kev
Russell Coight:
FollowupID: 652059
Follow Up By: Who was that again? (Vic) - Wednesday, Sep 23, 2009 at 10:50
Mainey, I saw the other posts, but decided I didn't want to troll through again. I don't know the myth about "70% cranking batteries"
Kev, mate, enjoy St George. I haven't looked lately to see who is going, but have talked to some not going, including one driver of a souped up Troopy, who is getting further into souping up territory. He will be up to his knees in blanket sticking stuff soon if he isin't careful.
FollowupID: 652065
Follow Up By: Member - Phil G (SA) - Wednesday, Sep 23, 2009 at 12:08
Mainey,
"Mate you should read the thread again, the entire thread is EXCLUSIVE to Cranking batteries"
There are many different types of cranking batteries that have both different charging algorithms and different resting voltages. Polls can be interesting, but when you get 50 results using 50 different meters by 50 different users on say 5 different cranking battery types of different ages, with resting voltages at different times, it does lack any scientific validity.
FollowupID: 652071
Follow Up By: Maîneÿ . . .- Wednesday, Sep 23, 2009 at 19:23
Phil,
Yes, of course your correct, maybe I should have said "Cranking batteries N0T Deep Cycle batteries" to be more politically correct :-)
I will admit it does lack "scientific validity" but then it was stated to be a simple exercise, by people with their own instruments.
However I believe an average of the Voltage numbers presented will still confirm the 70% claim is myth.
Maîneÿ . . .
FollowupID: 652134
Follow Up By: Ianw - Wednesday, Sep 23, 2009 at 20:03
Na Mainey, Just proves that most low cost voltmeters read a little high !!! The figures prove it.
Ian
FollowupID: 652137
Follow Up By: drivesafe - Wednesday, Sep 23, 2009 at 20:13
Thanks Mainey.
Hi Phil, Mainey covered it pretty well, this was never intended to be a scientific experiment just a basic exercise and was intended to see how many batteries ( if any ) were being charged way above the 70% myth.
The going theory, used by quite a lot of advertisers to promote their gear, is that an alternator will not charge any flooded wet cell cranking battery above 70-75% SoC.
While collecting the figures using a multi meter is not an exacting science, neither was the intention of the poll.
But as Mainey pointed out, this 70% is a dead and buried myth.
FollowupID: 652142
Follow Up By: drivesafe - Wednesday, Sep 23, 2009 at 20:19
Quote by Ianw, “Na Mainey, Just proves that most low cost voltmeters read a little high !!! The figures prove it.” End of quote
Funny you should say that Ian, a number of people on some of the forums tried to use this as an excuse the nullify the results.
The problem with their theory is that while the accuracy of some meters could be out, it safe to say they could be out in either direction, so while some may read high others may read low.
All’s fair in love and war!
FollowupID: 652144
Follow Up By: Member - Toyocrusa (NSW) - Wednesday, Sep 23, 2009 at 20:40
Thanks John C. After about ten minutes I have finally found the button. Bob.
FollowupID: 652147
