Friday, Sep 25, 2009 at 08:27
Yamaha EF1000 has
fuel tap which Honda EU10 does not. Yamaha can be run dry in the carburetor and no leakage or smell. Honda EU10 with bouncing leaks
fuel out air filter and stinks everything of
fuel. Overall Yamaha EF1000 is a lot better unit than Honda EU10
Yamaha EF1000 Feature Benefit
Lightweight Design/Easy to Carry Newly designed exterior and compact lightweight inverter unit reduces weight to 27 lbs. Lightest weight generator in its class.
Noise Reduction Design Molded casing, noise-absorbing glass wool construction and a newly designed muffler produce unbeatable noise reduction
Long Run Time Runs continuously for up to 12 hrs. without refueling (at 1/4 load*)
Variable Engine Speed Automatically adjusts engine speed to precisely match load, resulting in greater
fuel efficiency and noise reduction.
12 Volt DC Output (Battery Charging Cables Included) Recharge 12 volt batteries for RV, auto, marine, aircraft, etc.
Inverter System with Pulse Width Modulation Industry -leading system produces higher-quality and cleaner electricity. Results in pure sine wave as clean or cleaner than commercial power and can operate products with built in microcomputers.
Exclusive Dual Coil Alternator Stator Lower engine speed. Reduced noise,
fuel consumption and engine wear.
Centralized Control Panel Control panel enables easy access to controls.
Fuel Petcock Reduces carburetor contamination by turning off gasoline flow and allowing the carburetor to run dry.
OHV 50cc Engine
(overhead valve) Provides improved efficiency, increased reliability, low oil consumption and noise-reducing operation.
Large
Fuel Fill Access Wide mouth
fuel fill reduces spilling and
overflow during refueling.
384551
