bio-diesel
Submitted: Saturday, Sep 26, 2009 at 19:24
ThreadID: 72559 Views:3604 Replies:7 FollowUps:12
hi all have a ford courier 2001 model wondering if it will run on bio diesel and how to make it thanks
Reply By: KennyBWilson - Saturday, Sep 26, 2009 at 20:40
I have heard a lot of bad reports on Bio diesel , but you can ring a few Fuel injection workshops and ask what they think of it.
AnswerID: 384748
Follow Up By: fisho64 - Saturday, Sep 26, 2009 at 21:34
research it for yourself rather than 3rd hand urban myths.
Many fuel injection workshops even seem to have little idea of the stuff.
If it was that bad there would be broken down cars/trucks strewn for miles around Mundrabila SAFF roadhouse on the Nullabor for a start.
FollowupID: 652533
Follow Up By: dbish - Saturday, Sep 26, 2009 at 22:39
fisho64 you will find kNf asked how to make bio diesel, Big difference in home made & comercial diesel. Have a neighbour who makes his own bio diesel which works ok untill cold weather goes thick in fuel line. When this hapens he can barely drive the vehicle.
FollowupID: 652541
Follow Up By: fisho64 - Sunday, Sep 27, 2009 at 01:28
and you will find that he asked if it would run on it first, and you will also find my followup is to Kenny, who said he had heard "a lot of bad reports".
You will also find that normal diesel also does this at varying temps and waxes up.
Adding a small amount of kerosine raises the cloud point of bio diesel and mineral diesel.
FollowupID: 652548
Follow Up By: Ozboc - Sunday, Sep 27, 2009 at 08:06
This post has been read by the moderation team and has been moderated due to a breach of The Moderation Complaints Rule .
Forum Moderation Team
FollowupID: 652553
Follow Up By: fisho64 - Sunday, Sep 27, 2009 at 22:19
Ozboc-take the last bit off your post and repost it, it is relevant and well thought out information you have provided.
I imagine that was the bit causing the prob!
FollowupID: 652635
Follow Up By: Ozboc - Monday, Sep 28, 2009 at 07:10
fish -- Nope - if they dont want my whole post - then its nothing .... if my information is not valuable enough --- then so be it .. Info would have found its way via email --- thats what is important
FollowupID: 652652
Follow Up By: fisho64 - Monday, Sep 28, 2009 at 11:00
no probs, thanks anyway, yeah I received it all
cheers!
FollowupID: 652670
Reply By: Serendipity of Mandurah (WA) - Sunday, Sep 27, 2009 at 01:33
It is hard to get accurate answers because the biofuel companies will say yes and others will say no. Getting a consensus of answers from anecdotal experience from a website like this is a good start point for research.
I have heard that bio-diesel will clean the muck out of your fuel lines so many people will put an inline filter just before the fuel pump and then change it regularily until the lines & tank are cleaned out.
Toyota state in one of their pamphlets they do not approve of anything with more than 5% additive. Gull biodiesel is a 20% mix. Some places sell higher diesel mixes. Some people brew their own biodiesel.
I think the new common rail diesels would not tolerate biodiesel well. Your older mechanical pump to individual injectors would probably do better. My older turbo diesel landcruiser ran just fine on gull 5% biodiesel - did notice any difference other than the price.
Not an expert - just a driver.
David
AnswerID: 384763
Reply By: Member - Fred - Sunday, Sep 27, 2009 at 10:00
Re the comment about bio diesel from the SAFF roadhouse at Mundrabilla - if you search for SAFF you get "Mogas Regional" and they do not list bio diesel as a product they supply now.
AnswerID: 384773
Reply By: Member - joc45 (WA) - Sunday, Sep 27, 2009 at 10:07
FWIW, my experience about 3 years ago (in NSW) running 50% commercial biodiesel was that the fuel economy was noticeably worse than standard diesel, generally negating any savings in the lower per-litre cost of the bio. This was in a bog-std low-tech Patrol GU 4.2TD.
AnswerID: 384774
Follow Up By: Ozboc - Monday, Sep 28, 2009 at 07:59
there is a drop , but thats because the motor is not tuned to bio -- as for cost effective --- costing me 10 c a l to make -- much better than $1.20 + pl
FollowupID: 652659
Reply By: Shaker - Sunday, Sep 27, 2009 at 10:32
My concern is that Freedom Fuel outlets supply 20% bio-diesel but advertise 'Diesel' on their price boards, it is only when you get to the pump that there is tiny printed sticker advising of that fact.
Service stations should be made to put 'B20' on their price boards, to stop them from wasting peoples time, or worse, causing engine problems!
AnswerID: 384777
Reply By: Austravel - Sunday, Sep 27, 2009 at 15:00
kNf,
Not sure of that particular vehicle but considering the age I'd say like my patrol, it's low tech, so should be ok. Since your thinking of making it yourself you'll be able to have a good control on quality. Just a tip, don't look at just $$, try for quality and you should be ok. If you can get the feed stock cheap or free then it's the way to go. Again just work out the $$, for many I'd think it's not really worth it considering the risks. There are risks not only to your vehicle but yourself, just do a fair bit of reading first and don't cut corners on quality or your health, it's not worth it long term.
For the stuff you pump out from servos, I wouldn't personally use it. Having done some tests on this fuel and speaking with a few others doing long term tests the quality is questionable. Problem is they don't' know what the base stock will be from day to day so not really their fault. Still, one day someone needs to enforce quality control as per mineral fuels, it's not at that level yet, nowhere near it. As already stated if your using the servo stuff don't think your saving money or in fact doing the environment a favour. As a qualifier that is unless it's waste oils. If from raw materials it's not as environmental as some think.
Good luck hope it all goes to plan, always great to keep learning and if you can safely save some dollars then all the better.
AnswerID: 384801
Follow Up By: Horacehighroller - Sunday, Sep 27, 2009 at 15:41
An Australian standard was legislated about 2 years ago, and excise is required to be paid on all production for on-road use regardless of whether it's for personal use or not.
Fuel economy with straight Bio (100%) will generally be 5 - 10% worse than diesel, and logically a 10% mix will be less than 1% lower economy.
Biodiesel provides significant additional lubricity.
It is generally considered that the benefit of a 5 -10 % mix of Bio providing additional lubrication for the injection system and engine outweighs the slight economy dis-advantage of such a mix.
I used to make my own and have on occassions (as a trial) run my HZJ landcruiser and Mitsubishi canter on 100 % Bio. (It's amazing to be able to take a deep breath straight from the exhaust and not have coughing or watery eyes or any other other hay-fever-like symptoms.
As stated above it is necessary to instal an addition fuel filter as the bio (even in low doses) will remove scale etc from fuel tank & lines of an older vehicle.
FollowupID: 652585
Follow Up By: Austravel - Sunday, Sep 27, 2009 at 16:59
Hi Peter,
When doing some dyno tests on commercially available bio I believe the standards for it were of a much lower than that of mineral oil. I'll happily be corrected as I only did a quick scan. My point was quality not so much economy or lubricity which I agree with you. I'm not so sure on the advantages with modern high pressure diesels. In fact would be very careful as injectors etc are so expensive. I rang a few pump/injector places when starting the tests and they said, bio fuel induced dramas certainly helped their business. Now was that commercially available bio or poor quality home cocktails.
I'm guessing you didn't really take a deep breath from the exhaust pipe, even for bio. The transesterification process plus added highly toxic chemicals are pretty nasty compounds. Plus at high temp there are some nasty bi-products produced even for bio. Might not smell like mineral diesel but doesn't mean the by products are clean and non harmful. I recall many years ago a demo at a shopping centre. Some guy was selling natural insecticide and said it's harmless. In fact sprayed his harm and took a lick. Wonder if he's still alive, poison is poison regardless if it's natural or synthesised.
Your right with filters first few are quick changes and of course all seals, o-rings and hoses need to be changed.
Don't take this as knocking bio it's just not as clear cut as many (not you) seem to think. Again unless the dollar to risk ratio was pretty good I'd wonder why people would do it. Certainly those with access to feed stock would see a huge benefit.
FollowupID: 652595
Follow Up By: fisho64 - Sunday, Sep 27, 2009 at 22:17
from what I understand the problem with o-rings/seals etc is only vehicles older than around 93 when I understand all were to be viton or equivalent which is impervious.
FollowupID: 652634
Reply By: Member -Dodger - Sunday, Sep 27, 2009 at 16:08
I often run my 4.2td Patrol on 100% bio without any problems.
The only alteration is a filter (simple in line petrol filter) was placed in the fuel line before the pump that pumps fuel from aux tank to main tank and also a replacement CAV fuel filter system instead of the Nissan fuel filter.
Each time I fuel with bio I keep a watch on both these filters and replace when required. You may find that blending bio with petro diesel will stop most problems. 50/50 Mix.
There is little to no loss of power in my Patrol and very little difference in fuel consumption. I figure on an extra ltr per hundred.
My Patrol has had the turbo and pump opened up plus a larger dump pipe and a mandrel bent 2.5" exhaust.
Cheers Dodg.
AnswerID: 384813
Follow Up By: Member -Dodger - Sunday, Sep 27, 2009 at 16:09
Forgot to add vehicle has now 200 thou on clock.
Cheers Dodg.
FollowupID: 652588
