Anderson Plug
Submitted: Sunday, Sep 27, 2009 at 12:04
touringoz
Had an Anderson plug fitted to the Paj, do they make a plug to to seal up the opening when not connected to the Van (keep all the dust and gunk out).
fergy
Reply By: Member - Mike DID - Sunday, Sep 27, 2009 at 12:07
Yes, you can buy rubber caps that seal the opening, but careful, you may just be sealing in dirt and
water.
Make sure the cable entry side is fully sealed before fitting a cap.
384785
Follow Up By: Member - Graham H (QLD) - Sunday, Sep 27, 2009 at 12:11
www.sidewinder.com.au
652570
Follow Up By: Richard Kovac - Sunday, Sep 27, 2009 at 17:16
Mike
They would be OK on main roads, but are crap in the bush.
I have one on the Troopy and on this years trip into the Gibson, it was always knocked off, got sick of putting it back on..
Richard
The Tee handles
sidewinder sells to bolt onto the plugs are a great thing.
652597
Reply By: Rockape - Sunday, Sep 27, 2009 at 13:41
Fergy,
Anderson plugs are very robust in build and have a very simple design, dirt and dust are not a problem at all. All you have to do is hose them out.
All our underground mobile gear have them fitted for jump starting and battery charging, the machines operate in horrendous conditions and we have no problems at all.
Have a good one
384790
Reply By: sandk33 - Sunday, Sep 27, 2009 at 14:06
Just get a piece of sponge 2" sq (50mm sq) push it in with a screw driver because of compression no dust or
water simply pull out with the same screwy if you lose them pinch another piece of the washing sponge. The caps you buy $14 have to be put on before assembly of wires into plug. Either that or use the same trusty screw driver to get the connectors out put it on replug the connectors. Gee the sponge sounds simple.
384794
Reply By: ABR - SIDEWINDER - Sunday, Sep 27, 2009 at 17:04
Stop caps and end covers are freely available.
We have just finished tooling on the new rear entry covers and they will be available in 30 days.
Derek from ABR
384822
Reply By: RV Powerstream P/L - Sunday, Sep 27, 2009 at 19:09
Both safety boots and dust caps are available now at reasonable prices at www.powerstream.com.au
Ian
384841
Follow Up By: RV Powerstream P/L - Monday, Sep 28, 2009 at 06:42
What I should have said was the original safety boot as pictured above by Sidewinder which comes from USA and is Patent pending is currently available from www.powerstream.com.au at reasonable prices.
Ian
652651
Reply By: Wizard1 - Monday, Sep 28, 2009 at 11:13
Reply By: touringoz - Monday, Sep 28, 2009 at 11:32
Thanks to all who responded to my question.
fergy
384899
