pathfinder suspensiion
Submitted: Sunday, Sep 27, 2009 at 12:15
ThreadID: 72569 Views:2370 Replies:3 FollowUps:2
hi all. just picked up our brand new cub drover offroad camper trailer! when i hooked up to my 98 pathfinder i noticed alot of rear suspesion drop. heavy duty springs or polly air bags ? thanks.
Reply By: DesF - Sunday, Sep 27, 2009 at 12:22
Hi Mate has same 4x4 & had same problem with his van, and we fitted
Poly- Airs, and that fixed it , about an hour to fit. rons 12lb with 16' van
Cheers Des.
AnswerID: 384787
Reply By: stevie1947 - Sunday, Sep 27, 2009 at 12:24
Hi Meggsy. Had the same trouble with my 2001 Pathy and put polly airbages on and fixed up the sag no problem.
AnswerID: 384788
Reply By: Member - Graham H (QLD) - Sunday, Sep 27, 2009 at 12:27
Polyairs AND a WDH as the polyairs lift the back but dont restore weight
removed from the front wheels when you hook up the camper
I put progressive springs and polyairs and use a heavy duty WDH with my full van.
Also check the distribution of weight in the camper You may have too much on the towball.
Next post will say you dont need a WDH but they make things easier when towing.
Perhaps a check of towball weight first before you spend any money.
AnswerID: 384789
Follow Up By: gqturbo - Sunday, Sep 27, 2009 at 15:41
WDH would probly not suit a off road coupling very well only a ball type
FollowupID: 652586
Follow Up By: Member - Graham H (QLD) - Sunday, Sep 27, 2009 at 17:46
I hear what you say but have seen a few off road vans with treg hitchs and a
WDH fitted and they reckon that they are OK
Of course are higher off the ground than a trailer.
A correctly loaded or creatively loaded trailer really shouldnt need one any way.
FollowupID: 652604
