Dealer Installation or Independent?
Submitted: Sunday, Sep 27, 2009 at 13:16
Blue Galaxy
Can someone please help with with the pros and cons of having the dealer do the installation of the electrics (Anderson Plug) and hitching issues on delivery of a new van?
I am getting quoted on the dealer doing it at delivery but I can't help but think that I may be paying a premium for the convenience. I have to get HR WDH fitted but I need the van to be fitted as
well, so how do I get home?
Surely the dealer has been there/done that and for that I am willing to pay a premium.
Any thoughts and comments would be greatly appreciated.
Reply By: Member - Fred B (NT) - Sunday, Sep 27, 2009 at 14:02
Surely the dealer can deliver the vehicle to your choice of supplier for fitting OR get quotes, then have the dealer match the price....
all the best,
384793
Reply By: ozjohn0 - Sunday, Sep 27, 2009 at 15:52
Purchase tour HR WDH wherever you can get the best price.
Waist of time trying to set up a WDH with an empty van with low Ball Weight and an unladen vehicle
The dealer will roughly set it up to get your van home.
After packing the van and the Tow Vehicle and filling the
Water Tank(s) etc You can then have it set up correctly.
ozjohn
384812
Follow Up By: Blue Galaxy - Sunday, Sep 27, 2009 at 19:41
Hey Oxjjohn,
Always appreciate your feedback and this is no exception. I will be hunting the best price (as I always do) but always keeping in mind the service as
well (happy to pay a little extra but I am not a charity either!)
652618
Reply By: MEMBER - Darian (SA) - Sunday, Sep 27, 2009 at 16:29
I bought my 750 model Hayman WD hitch here in
Adelaide ($690) and took it to
Melbourne for the van pick up. Had never used one before - the van maker was happy to spend time setting it up for me without charge. I did have any idea anyway of how to do it, but it was handy for someone who does it a lot to provide the demo. Of note though is the fact that once the van is sitting on the tow ball, TITLE HAD PASSED to me - the client of course carries all the responsibility for the correct setup of such hardware - I did my anderson plug wiring at home, prior. I paid an electric brake specialist to do my brake controller supply and setup.
384816
Reply By: Member - Graham H (QLD) - Sunday, Sep 27, 2009 at 17:42
Not hard to do either.
The WDH is only two bolts on the van just put the bars on and pull the chain straight up Bolt the receivers on there.
It takes a little bit of fiddling to get the car end at the right height but as an
idea back it up to the van and set the jockey wheel so that van looks level
Set the towball to that height using the bolts on the hitch to adjust.
Go here for fitting instructions and scroll down to products/weight
distribution then scroll down and the fitting instructions are there as a PDF download
http://www.haymanreese.com.au/index.htm
Take it home empty and do it then An empty van will be Ok for one trip without one surely.
The Anderson plug can be done later unless you need it for the fridge.
Pretty simple as
well 6 B&S all the way to the rear N earth strap the same onto a chassis bolt and you are away.
I put a 60 amp resettable fuse in the line at the battery $26 at Autopro.
The dealer will give it to one of the boys and charge full rates.
Do it yourself and do it right.
Incidentally my HR WDH cost me $549 in Qld last year for the 750.
Have seen horrendous prices here in the west for this sort of gear.
384826
Follow Up By: Blue Galaxy - Sunday, Sep 27, 2009 at 19:40
G'day Graham,
I am sure seeing a horendous price as I suspected and hence the post. I ahve been quoted $950!
I will be calling the dealer and asking him to be more competitive and to forget about looking after the boys.
652617
Reply By: Gazal Champion - Sunday, Sep 27, 2009 at 18:11
Hi Blue Galaxy,
Just had my anderson plug on the car fitted by local auto electrician and he also supplied the materials for the caravan.
I fitted the van side of things but left the car to the autolec as it suited me to do it that way. Labour was just under $200 but the fitting in the car also included another outlet for the Waeco fridge in the back of the cruiser.
Materials were just over $200 which included a special plug and socket for the fridge connection. (I chose an expensive one)
Total cost was $407
This should give you some Idea of a ball
park figure.
Having said all the above, you do not have to have the anderson plug fitted to pick up the van.
Hope this is of some help
Regards, Bruce.
384827
Follow Up By: Blue Galaxy - Sunday, Sep 27, 2009 at 19:38
G'day Bruce,
I am not the most practical perosn and so I think I will leave it to the "experts" on the wiring side. I have been quoted around $300 for the Anderson plus installation (which sounds ball
park) although I already have wiring to the rear of the Prado for my Thumper charge unit (with Anderson Plug).
Cheers for your feedback
652616
Follow Up By: Member - Graham H (QLD) - Sunday, Sep 27, 2009 at 20:11
Jeez are they gold plated Derek on here will sell you 50amp plugs for about $10 each
Mine cost for a 100ser Croozer
The price of the plug and $6 a metre for the wire so $36 for the red and $6 for the black.
Got a 50 amp switchable fuse for $26 and got a sparky to clamp the ends for me cost $10. 8mm ends $5
Took about 2 hours to do the job.
Ran the wire down and along the chassis rail to the rear and cable tied it to the existing wiring loom along there.
So total cost $93 and my time. A good sparky will do it in an hour or so I would think
If you already have one why not use that providing that the wire is at least of the above size. NOT ANY LIGHTER
652619
Follow Up By: Member - Graham H (QLD) - Sunday, Sep 27, 2009 at 20:14
If you are in
Perth Ill do it for a doz Pure Blonde
652620
Follow Up By: Blue Galaxy - Sunday, Sep 27, 2009 at 21:27
Graham,
based on your costings, I may be able to put the van and car on the train and have you do it!
652625
Follow Up By: Member - Graham H (QLD) - Sunday, Sep 27, 2009 at 21:35
Well I have a spare 50 amp plug and a fuse and a couple of metres of leftover 4 B & S wire so maybe it will.
HA HA
But thats honestly what it cost for One plug on the bumper all done properly.
Works Ok as van battreies are fully charged and fridge stays cold.
652627
Reply By: DIO - Monday, Sep 28, 2009 at 11:25
Best to organise fitting yourself otherwise if you do it through the dealer all they will most probably do is call in their 'mobile auto electrician' and then finish up making a profit from the transaction - at your expense. Organise your own (decent/reputable) Auto Electiorcian. You won't regret it.
384896
Reply By: j100 - Monday, Sep 28, 2009 at 15:02
384928
