Hilux '04 3 ltr turbofuel problem
Submitted: Monday, Sep 28, 2009 at 15:15
Twinkles
Yesterday when heading off to
Darwin, the Lux lost power. The
orange engine light came on. The
water and oil ok and motor sounded fine. I struggled back home and changed the
fuel and air filters. Ran fine again. Went 135km into
Darwin. On way home did it again. Stopped and restarted engine. Ok again. Started this morning and seems ok.
I had washed car day before. I washed a bit under bonnet. Done that before with no dramas. Maybe got some
water into electrics??
Can you get a bit of a blockage (in new filter?) for a bit and then clear. What electrics could effect the
fuel delivery.
I'll take it for a drive tonight to see if there are any more problems.
Reply By: Member - Tony & Julie (FNQ) - Monday, Sep 28, 2009 at 15:57
I found that it is best to read the Owners Manual in the Fault Finding Section, They list the warning light and possible causes & rectification.
With computers these days what you have described could be a multiple of causes and engine compensates to avoid damage. Thats my understanding anyways.
Not trying to be funny with this, but what you can find is that to find some of these problems you have to plug it in to the computer to diagnose. Cheers Tony
384933
Follow Up By: Twinkles - Tuesday, Sep 29, 2009 at 08:27
I live a long way from town and work full time so i was trying to avoid having to go to Toyota. The manual says the light is related to turbo. I think I may have got some
water in the wiring. Seems fine now. Took it for another long drive. It's so hot here anything would have to dry out.
652761
Reply By: Maîneÿ . . .- Monday, Sep 28, 2009 at 15:59
Twinkles,
did you notice any black sooty smoke coming from the exhaust or any black residue build-up at the rear area near the exhaust ??
Maîneÿ . . .
384935
Follow Up By: Twinkles - Tuesday, Sep 29, 2009 at 08:18
No black soot, but I may have been preoccupied and not noticed.
What would this mean?
652760
Follow Up By: Maîneÿ . . .- Tuesday, Sep 29, 2009 at 08:59
Twinkles, if your muffler gets clogged in any way, including a loose baffle, it gives the same results, sudden lack of power and no other signs.
Maîneÿ . . .
652764
Reply By: Garbutt - Monday, Sep 28, 2009 at 17:02
I had a similar problem once, most noticeable when having done some rough tracks,then went onto an open road at higher speeds. Engine light came on etc and sounded to me like it was starved for
fuel. Local Toyota dealer put the diagnostic gear on and said I need a new injector pump for about $5000. Evenutally I traced it to dirty
fuel in the
tank which was restricting the pick up. I drained and flushed the
tank (an aftermarket one with a drain plug) and no more probs. Total repar cost about $5 worth of
fuel wasted. You can't always trust the diagnostic equipment.
384944
Follow Up By: Twinkles - Tuesday, Sep 29, 2009 at 08:30
Do you drive a hilux? What engine light was it?
Mine is an
orange picture of the motor.
652762
Follow Up By: Garbutt - Tuesday, Sep 29, 2009 at 18:53
Yep. 2002 Turbo diesel. Same engine light as you report, but had nothing to do with the engine.
652826
Follow Up By: Garbutt - Tuesday, Sep 29, 2009 at 18:55
652827
Reply By: Member - Mick O (VIC) - Monday, Sep 28, 2009 at 17:27
Twinkles, I had the same issue after picking up a load of dirty
fuel at
Mataranka. Had to drain and flush the
tank as
well as change
fuel filter. No problems thereafter.
384948
Follow Up By: mazcan barry - Tuesday, Sep 29, 2009 at 12:49
hi
dirty
fuel especially
water contaminated will always go to the bottom of the
tank and is the first thing shortly after refuelling that will be sucked up blocking a filter
that's why fitting an after market filter with bowl/
water trap is a very good idea as depending on the amount of dirty
fuel you get it can quiet often be drained out the bowl as
well as removing
tank plug to let
fuel flow until it looks clean without effectiing the filter : there are twin atermarket filter/bowl assemblies which are even better but of course you need the space to fit them in
always had these on our farm tractors,
mazcan barry
652784
Reply By: malley - Monday, Sep 28, 2009 at 22:35
My first reaction to your post was dirty
fuel. Reading on, others appear to be thinking along similar lines.
A friend had a very similar problem with his 93 Hilux surf recently (likely to be a very similar kz motor to yours) from a
servo just north of
Perth (
Lancelin). He took it to Toyota to have it diagnosed as dirty
fuel.
Let us know how you go and if this solves the problem, so many of these posts are left without closure
385008
Reply By: Twinkles - Tuesday, Sep 29, 2009 at 08:37
Can't get in to see Toyota for a while. Drove it last night to
Batchelor and back, 160km. No problems. Engine light means turbo. Spoke to some engineer fellas here where I work and they suggested turbo lag. Probably got
water into electrics for turbo. Must have dried out. Pretty hot here, anything has to dry out.
385034
Follow Up By: Lex M (Brisbane) - Tuesday, Sep 29, 2009 at 16:27
By the way, the engine light does not only mean turbo by any means as you'll see when you look at the code descriptions.
652804
Follow Up By: Member -Dodger - Tuesday, Sep 29, 2009 at 16:38
Take it back n trade it in.
Probably the ash trays full too.
652805
