2 stroke oil in your diesel fuel
Submitted: Monday, Sep 28, 2009 at 20:47
malglo
Anyone seen this/done it/doing it
link
Mal
Reply By: Ken65 - Monday, Sep 28, 2009 at 21:03
I will let you know next year when I finish reading the post.
Interesting though.
384989
Reply By: marq - Monday, Sep 28, 2009 at 21:08
I believe it's illegal to do
fuel modification
384991
Follow Up By: marq - Monday, Sep 28, 2009 at 21:09
But we still do it!
652730
Reply By: Member - Ian H (NSW) - Monday, Sep 28, 2009 at 21:13
Mal, I just read it and it sounds like it works. Will try it in our 1HZ engine.
Thanks for the info link. Ian
384994
Reply By: Traveller - Monday, Sep 28, 2009 at 21:30
Not 2 stroke oil but I drop a dollop of Flashlube for diesels in the
tank at every fill and also a litre of vegie oil every now and then. Works a treat.....but I have an old uncomplicated diesel engine. Engine runs
well with 400K+ on the clock
384997
Follow Up By: Ozboc - Tuesday, Sep 29, 2009 at 06:04
just be carefull with the vegi oil ( or it may be canola oil - cant remember which now ) as it can destroy seals .... even destroys viton ....
Boc
652748
Reply By: dbish - Monday, Sep 28, 2009 at 21:33
At the amount they recomend to ad to a
tank of
fuel is so small cant see it being a problem. Ive seen people ad a hell of a lot more diesel
fuel adatives to there tanks than that. That amount of 2stroke oil wouldnt even smoke.
385000
Reply By: Robnicko - Monday, Sep 28, 2009 at 22:42
I saw a guy adding 2-stroke to his Landrover td5 tonight just after he filled with diesel.
385009
Reply By: Member - Leave_enough_space - Tuesday, Sep 29, 2009 at 08:08
Reply By: Member - Malcolm (Townsville) - Tuesday, Sep 29, 2009 at 09:09
I read the Patrol4x4 thread, also the comments by the advocate in the states (who is a lawyer and really knows what he is talking about).
They say to make sure it is a "mineral" oil, possible semi-synthetic, but keep away from fully synthetic oils. As you all know "oils ain't oils sol".
Last week I bought a litre of Castrol 2T Self Mix and dropped it in my tanks to try it out (in the recommended ratio of 1:200). Was it quiter? Possibly. Better
fuel consumption? Never had the chance to find out. I'll be back on the road next week with a good chance of testing out all these theories.
Malcolm
385037
Reply By: Honky - Tuesday, Sep 29, 2009 at 09:32
I use 2 stroke in my desiel as it is meant to lubricate than get burnt with low deposits.
Better than canola.
I have read in the past that most additives for petrol engines have as a top end lubricant synthetic two stroke.
If a desiel can run on bio why not a small amount of 2 stroke which is meant to burn.
Honky
385039
Follow Up By: mazcan barry - Wednesday, Sep 30, 2009 at 13:54
hi
when i was much younger 35yrs ago dad's cousin
who was i bit of a racing /hoon head fanatic use to pour a quantity of what he called racing oil, it was red, into his petrol
tank despite the make of vehicle and claimed it was good for the engine and believe me he use to drive harder and faster than anyone i have known
it gave off that familar racing car odour that one experienced at claremont speedway etc so guess this topic above re 2 stroke is just another version and is nothing new
mazcan barry
652891
Reply By: Ray - Tuesday, Sep 29, 2009 at 09:34
Slightly of the subject but I have been running my 80ser L/C LPG powered with 2 stroke oil rather than Flashlube for quite a number of years now and it still runs very sweet.
385040
Follow Up By: mazcan barry - Tuesday, Sep 29, 2009 at 11:37
hi
i read the rather long link blog last night and these,
and dont see why or how using 2 stroke could be detrimental in any way as has been mentioned 2 stroke is designed to burn
im going to try it in my golf diesel which has a high pressure common rail
fuel system
i also see it as a cheap alternative and good for the motor instead of flashlube in lpg run engines
mazcan barry
652777
Reply By: Ted G - Tuesday, Sep 29, 2009 at 13:51
Hi All
For many years I ran a Golf diesel on aviation kero (drains from aircraft
fuel tanks), mixed with 50 to 1 super outboard oil no problems apart from less economy but the
fuel was free so all I had to pay for was the oil very cheap runnning.
Ted
385066
Follow Up By: mazcan barry - Tuesday, Sep 29, 2009 at 15:16
hi
TED G
interesting but your old golf diesel would have had a conventional
fuel pump system where as
mine is the common rail h/pressure and after reading the test report mentioned
im going to urr on the side of caution until further conclusive evidence/ benefits are produced in favour of 2 stroke oil
( if it aint broke dont fix it )
mazcan barry
652797
Reply By: Member - Malcolm (Townsville) - Tuesday, Sep 29, 2009 at 14:08
I have been following this debate with great interest. There is now a scientific test result produced which shows:
7) Super Tech Outboard 2-Cycle TC-W3 Engine Oil
Unconventional
(Not ULSD compliant, may damage 2007 or newer systems)
HFRR 474, 162 micron improvement
200:1 ratio
16.64 oz/
tank
$1.09/
tank
Don't like that bit .... MAY DAMAGE 2007 or later !!
Read the full results of the test
here.Malcolm
385067
Follow Up By: Member - Malcolm (Townsville) - Tuesday, Sep 29, 2009 at 14:25
The best performing additive from these tests was "Opti-Lube XPD". Already there are people in Oz wanting to use it - including me (at least until I did some more research.
Follow up led me to this (for this product):
WARNING.
• HARMFUL IF INHALED.
• CAUSES EYE IRRITATION.
• CAUSES SKIN IRRITATION.
• HARMFUL IF ABSORBED THROUGH SKIN.
• COMBUSTIBLE LIQUID.
• CONTAINS COMPONENTS WHICH MAY CAUSE CANCER.
• MAY CAUSE CHRONIC HEALTH EFFECTS.
and it may need "notification" if sold in Australia.
The full report is
here.Malcolm
652794
Follow Up By: mazcan barry - Tuesday, Sep 29, 2009 at 15:06
hi
malcolm
read the test report with great interest re: super tech outboard 2 cycle -2 -tc-w3 eng oil results but
are all 2 stroke oils made to the same specification as this one above or are there differences apart from mineral and synthetic standards with them
mazcan barry
652796
Follow Up By: dbish - Tuesday, Sep 29, 2009 at 16:00
Yes Barry there are 2 types of 2stroke oil one for air cooled motors ( run hot) . One for
water cooled 2 stroke ( runs cooler ). I have air cooled &
water cooled out boards & use diferent oils for each one.
652802
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Sep 29, 2009 at 19:20
Malcolm!! You are not supposd to drink it!!! :0} Michael
652828
Follow Up By: Member - Malcolm (Townsville) - Tuesday, Sep 29, 2009 at 19:43
Bugger Michael. The label said it was XXXX Gold ! LOL
652832
Reply By: Member - Wamuranman - Tuesday, Sep 29, 2009 at 17:02
This is an interesting topic.
The only 2 stroke oil I have at home at present is for lawn mower/chain saw (which I buy in 5 litre container).
It says on the container:
API - TA, TB, JASO:FB
"A two stroke motor oil designed for 2 stroke lawn mower engines and other small 2 stroke air cooled engines. Diluted with a high flashpoint solvent to facilitate easy mixing with petrol"
Does anyone know if this would be OK to try in an older diesel (Toyota 12HT turbo) in the ration 1:200.
Thanks for any comments
385075
Follow Up By: Member - Malcolm (Townsville) - Tuesday, Sep 29, 2009 at 19:59
Wamuranman
from what I have read JASO : Fx is OK the higher the 2nd letter the better e.g. C, D.
I've got a 2H motor in my old Sahara and I've put in Castrol 2T Self Mix. I couldn't find a JASO (or any) rating on the label.
The last bottle of 2 stroke oil I bought was "
Mobil 2 Stroke Oil" it has a classification of JASO FD. Recommended for land based air cooled 2 stroke engines.
HTH
Malcolm
652836
Follow Up By: Member - Wamuranman - Tuesday, Sep 29, 2009 at 20:32
Malcolm for the info and explanation.
Cheers (fellow 6 wheeller owner...)
652841
