X-trail horn only works when ignition is off??? Help!?
Submitted: Friday, Oct 02, 2009 at 18:49
davelivo
Got a problem with a 2002 X-trail where if the car is off - the horn works no problem, as soon as the key is turned to ignition - the horn no longer works.
I've hooked up the multimeter to the horn and there is no power being sent to the horn unit at all once the igntion is on.
It's clearly an electrical issue of some sort - has anyone seen anything like this before?
Reply By: oldpop - Friday, Oct 02, 2009 at 18:57
davelivo
Sounds like a bad relay or the wrong one
Oldpop
385485
Follow Up By: davelivo - Friday, Oct 02, 2009 at 19:24
But if it was the relay - wouldn't the horn not work at all?
653132
Follow Up By: oldpop - Friday, Oct 02, 2009 at 19:31
daveivo
All depends check relay sounds like it has a change over relay fitted instead of
a stanndard type
Oldpop
653134
