Thursday, Oct 08, 2009 at 22:35
I did it...here's the run down for me...
It's a Mercury system, mandrel bent, bolts straight in.
Came with the dump pipe, (twice the size of the standard one in length) opens to 3.5 inch but goes back to 3" conecting to the exhaust. Then 3" all the way.
One muffler and small resonator at the rear but all straight through.
One very good thing is the dump pipe comes with the fittings for the heat shield and a pre-drilled outlet for a pyromometer if you want one fitted.
Over-all, very happy with the quality and fit. It mounted straight into the original position, no mods required, 2 hr job.
PERFORMANCE
Very quiet....barely any difference to standard unless standing at the rear where you get a slight 'rumble'...but nice rumble.
Much more responsive off the mark. I have spent yesterday driving around
Perth and the city area. Noticeable difference, lighter under foot, less excelerater to get going. Very noticeable in heavy traffic under light acceleration. More pleasureable to drive.
I also notice a change when cornering. slow corners that resulted in acceleration use to mean a kick down back to 1st then off again. Now it seems happy to pull away in second. Don't notice any difference in other gears though.
Highway run today back home (224km's from refuel at Armadale) perfect weather...nothing really different at cruising speed noticed. Didn't do a proper
fuel test but for 224k's covered, my main
tank guage is sitting just under the 1/4 mark.
Only other thing I notice is that an existing 'vibration' I have a certain RPM now seems worse...don't like that...but will start investigating the cause more closely and seewhat I can find. Feels like driveshaft/uni joint type thing but I've checked all that and it seems fine. Bugger of a thing these annoying vibrations!
653905
