2006 XTrail Automatic Transmission locking?
Submitted: Sunday, Oct 04, 2009 at 13:00
ThreadID: 72753 Views:3451 Replies:7 FollowUps:4
We have had this happen twice now, once on flat ground with van on back at few months ago, and second time today while in garage and trying to engage Reverse.
Eventually used shift lock release to engage A/T - has anyone else had this problem and why is it happening?
Brake lights and all fuses functioning normally.
Reply By: Member - MUZBRY(Vic) - Sunday, Oct 04, 2009 at 13:31
Gday jazzy
Sounds to me like the park locking lever is staying in the locked position with the extra weight of the van.
Murray
AnswerID: 385696
Follow Up By: JAZZY - Sunday, Oct 04, 2009 at 13:36
The second time it happened the van was not hooked up to the XTrail.
FollowupID: 653273
Follow Up By: Member - MUZBRY(Vic) - Sunday, Oct 04, 2009 at 13:41
Gday
Then i have run out of reasonable idea's.
Murray
FollowupID: 653274
Reply By: Motherhen - Sunday, Oct 04, 2009 at 15:07
It happen with the Patrol when the battery was low.
AnswerID: 385706
Follow Up By: Motherhen - Sunday, Oct 04, 2009 at 15:13
Edit: It could happen - - -
FollowupID: 653281
Reply By: disco driver - Sunday, Oct 04, 2009 at 15:17
Hi Jazzy,
My guess is that there is a gremlin running out of control in the electronics that control the auto trans system. Moisture, poor electrical contacts or poor earthing are all possibilities.
Hope that you get it sorted without too much hassle.
In the 'Good Old Days" one had a positive mechanical linkage which controlled the works (Gear Lever, 4wd lever and Hi/Lo lever), much less trouble but a bit more physical effort required. (I've got one of these old ones and a newfangled electronic computer controlled one too.
Guess which one gives less trouble???.
The old one!!!
Disco.
AnswerID: 385707
Reply By: JAZZY - Sunday, Oct 04, 2009 at 15:39
There is actually an item in the owners manual in reference to this, and how to combat it, so would doubt it would be a gremlin, just wondering if anyone else who actually owns or has owned an XTrail has had this happen to them?
PS The new electronics in vehicles can be a problem but I guess you just have to put up with it when you purchase a newer vehicle, as opposed to purchasing something that has the old system with no electrical problems but has a trillion kilometres on the clock !!! :-)
AnswerID: 385713
Reply By: Member - Phil G (SA) - Monday, Oct 05, 2009 at 21:38
Did you have your foot on the brake? It stays locked in Park if you don't.
AnswerID: 385875
Follow Up By: Wherehegon - Wednesday, Oct 07, 2009 at 22:35
Yeah wifes Yaris sedan is the same, wont release from park if foot not on brake, also if not in park you cannot get key out of ignition to exit the vehicle. Regards Steve
FollowupID: 653766
Reply By: JAZZY - Tuesday, Oct 06, 2009 at 09:20
Thanks Phil, you hit the nail on the head, it is a safety precaution so you dont put it in D when the vehicle is not stationary - a bit of a pest especially when the vehicle was parked in the garage but I can see the reasoning behind this feature.
AnswerID: 385922
Reply By: Namrog - Saturday, Oct 10, 2009 at 21:27
I have experienced this problem with my X-trail, although usually on inclines. I think it is the "park" locking on auto transmission. I suggest that you ensure that you apply the hand brake before putting the car into Park.
AnswerID: 386545
