Wheel clamp - is this a commercially available product?
Submitted: Sunday, Oct 04, 2009 at 18:45
This was on a rig we were parked next to. It seems to be a very good and simple way to immobilise the van (rather than the handbrake), and could be made with a lock as a theft guard.
Reply By: Motherhen - Sunday, Oct 04, 2009 at 18:47
Now for the photo
Image Could Not Be Found
385729
Reply By: Member - Graham H (QLD) - Sunday, Oct 04, 2009 at 19:16
Yes it is
Here it is
http://www.rvaccessories.com.au/OutsidePages/WheelChocks.htm
Letting down the tyres would release it of course
385730
Follow Up By: Member - Rob S (NSW) - Sunday, Oct 04, 2009 at 19:42
A'rrr
Graham this site is slow you soon get beaten to the post.
But hey too minds the same didn' take long to figure how to knock it off LOL.LOL
653298
Follow Up By: Member - Graham H (QLD) - Sunday, Oct 04, 2009 at 19:54
Well it took nearly 10 mins for me to post that reply Got several errors and timeouts.
Every other site is OK GETTING FRUSTRATING
653300
Follow Up By: Motherhen - Sunday, Oct 04, 2009 at 22:48
Thanks Graham.
Mh
653344
Reply By: Member - Rob S (NSW) - Sunday, Oct 04, 2009 at 19:34
Hi looks like it would make a
park brake device.
But as anti theft device one would only have to let down one tyer to remove
it.
Rob.
385731
Follow Up By: nsngood - Sunday, Oct 04, 2009 at 21:27
umm rather than let down a tyre why not just undo (unwind)
the nut on top as per normal jack operation.Then you dont have to pump up tyres to tow you stolen van away lol. :.)
653321
Follow Up By: Member - Rob S (NSW) - Sunday, Oct 04, 2009 at 21:35
NSNGOOD
Yes you are correct in standard it's form but If you read the original post as per Motherhen
she wanted to modify it a locking mechanism so no one could undo it !!!!!!!!!!!!!!!!!!!!
653322
Follow Up By: Member - Graham H (QLD) - Sunday, Oct 04, 2009 at 22:42
You can already buy clamps which wrap around the wheel and cover the nuts as
well so you cant remove them. They vary in price from $49 to about $149
depending on price.
Snoopercheep have them.
653339
The main attraction for us was as an immobiliser. Using as an anti-theft device was an afterthought - at the time i hadn't considered the inguenuity of a potential thief, and i do think that the tyres would need to be deflated considerably to release the clamps.
Mh
653343
Follow Up By: fisho64 - Monday, Oct 05, 2009 at 01:12
likely a stupid question but whats the purpose of "immobiliser" if not anti-theft?
653351
Follow Up By: Member - Graham H (QLD) - Monday, Oct 05, 2009 at 01:37
Is a bit if you have done any vanning.
The purpose of it is to locate the van on a not so flat site so it doesnt run away.
Same as using the handbrake really.
Same as chocks but different and a bl**dy sight more expensive.
Is basically a scissor Jack but has curved ends.
You could
well weld some plates on one considerably cheaper.
653354
Follow Up By: DIO - Monday, Oct 05, 2009 at 10:16
Good point, one of which I initially agreed with however after further consideration I found the following:
immobilizer - 5 dictionary results
–verb (used with object), -lized, -liz·ing. 1. to make immobile or immovable; fix in place.
(Source - Dictionary.com)
653363
Follow Up By: Member - Graham H (QLD) - Monday, Oct 05, 2009 at 11:37
And the point of the grammatical lesson is
By preventing the
wheels from moving you effectively stop it from being moved
Surely it is then effectively "ïmmobilised"
or is it just usual nit picking
653374
Follow Up By: fisho64 - Monday, Oct 05, 2009 at 13:18
No-my tent has a design that naturally resists rolling away. and by not fitting a tow bar to it, it is harder to tow away :-)
thats kinda what I was looking at Graham. Chocks would seem to be the logical and easy way to achieve that?
There must be a reason why someone would use that setup just to stop it rolling away-otherwise noone would buy them?
Thanks DIO-I think. Us simpletons might be need further deciphering of your meaning though??
653378
