Alternator for Jeep 2.7 litre diesel
Submitted: Monday, Oct 05, 2009 at 21:22
ThreadID: 72799 Views:3707 Replies:6 FollowUps:6
I find myself needing an alternator for my wife's Jeep Grand Cherokee
The local dealer here in Townsville said there is none in the country and if there was it would cost me $2900.
Tried Google and there are plenty for the petrol models for around $200 U.S but nowhere can I find one for the 5 cylinder 2.7 litre diesel
It is actually the clutch in the alternator that spat the dummy, but not sure if I can get that separately
Anyone with some tips or advice would be appreciated
Cheers Ray
Reply By: barney rubble - Monday, Oct 05, 2009 at 21:35
Gday pop not sure about qld but was a company in wa called ashdowns who did alt starters ect was a few years ago now but were cheaper than most
may be worth a shot Cheers Barn
AnswerID: 385873
Follow Up By: Member - Poppy (QLD) - Monday, Oct 05, 2009 at 21:39
Thanks Barney
They may be worth a phone call tomorrow
Cheers Ray
FollowupID: 653449
Reply By: ABR - SIDEWINDER - Monday, Oct 05, 2009 at 21:40
Try this seller...
Jeep-Clutch-Pulley
AnswerID: 385877
Follow Up By: Member - Poppy (QLD) - Monday, Oct 05, 2009 at 21:46
Thanks Derek, not sure if 2.5 litre and 2.8 litre is same as 2.7 litre but will chase it up
As an aside to this post, I will be in touch with you as it looks like I do need the Tekonsha brake controller I emailed you about recently.
As when I disconnect it I don't get flat batteries, so figure it must have a short somewhwere.
Cheers Ray
FollowupID: 653451
Follow Up By: ABR - SIDEWINDER - Monday, Oct 05, 2009 at 21:53
No problem, we will forward it back to Ashdown-Ingram and they will check it out.
Derek
FollowupID: 653455
Reply By: Member - Murray R (VIC) - Monday, Oct 05, 2009 at 22:14
Ray
If you take the alternator to an auto elec they should be able to source a pulley for you and fit it. All they need is the numbers off the front of the pulley, if they cann't MM me and I will see if there is a cross reference to it and get back to you possibly with a QLD supplier
Cheers Murray
Another Mexican
AnswerID: 385888
Follow Up By: Member - Poppy (QLD) - Monday, Oct 05, 2009 at 22:21
Murray
A local auto elec looked at it last week and said it was a common fault and told me to ring the local Jeep dealer , hence the $2900 quote.
Maybe I should try another auto elec
Will keep you in mind Murray and thanks
Cheers Ray
FollowupID: 653458
Reply By: Member - Tezza Qld - Monday, Oct 05, 2009 at 22:21
Hi Poppy
We have found Jeepart Recyclers near Hervey Bay very good to deal with and have a large range of stock. Ph 1800 465 337 www.j-p-r.com
Hope this helps
Cheers Teza
AnswerID: 385890
Follow Up By: Member - Poppy (QLD) - Monday, Oct 05, 2009 at 23:02
Thanks Teza, just wondering how long a 2nd hand part would last as opposed to spending the money on a new one
Thanks anyway
Ray
FollowupID: 653465
Reply By: olcoolone - Monday, Oct 05, 2009 at 22:22
Chances are you should be able to by a new alternator clutch pulley assemble from Jeep.
Most alternator clutch pulley assembles only last about 90000 kilometers and need to be replaced.
You have to use a special tool to remove and replace the alternator clutch pulley as there is a very good chance of damaging the alternator and pulley if not done right.
I doubt you will not be able to get a replacement aftermarket here in Australia but in the USA they should be available.
We have only just seen the Denso ones come available as a replacement.
AnswerID: 385891
Follow Up By: Member - Poppy (QLD) - Monday, Oct 05, 2009 at 23:07
Olcoolone, found some pulleys on ebay and some other sites, but they don't seem to be suitable for the 2.7 litre diesel, plenty for the petrol models and only about $200 U.S.
Will try Jeep themselves if all else fails
Cheers Ray
FollowupID: 653466
Reply By: mazcan barry - Tuesday, Oct 06, 2009 at 14:37
hi poppy (qld)
try www.hammond 4wd.com.au they are in brissie and have been in jeep business since 1974
www.pentastarparts.com.au also have jeep parts
my son in cairns has a wrangler and jeep aus wanted $1200 for an electric petrol pump and he got one for $385.00 jeep aus are ripping everyone off and i will personelly never ever buy another jeep
once bitten twice shy
AnswerID: 385974
