Filter Mate 1HZ Engine Oil Filter Adaptor
Submitted: Tuesday, Oct 06, 2009 at 01:28
Member - Phil B (WA)
Hi all
Does anyone out there know if you can still buy these adaptors. If so from where?. They allow you to use Z9 oil filters on a HZ engine.
I heard of them a while back now a mate of
mine is chasing one.
Many thanks in advance
Phil B
Reply By: Mr Pointyhead - Tuesday, Oct 06, 2009 at 09:32
Only a good idea if you want to shorten the life of your motor. The toyota filter filters out much finer particles out than a Z9..
385926
Follow Up By: Member - Lotzi (QLD) - Tuesday, Oct 06, 2009 at 11:14
2nd
653490
Follow Up By: Member - Phil B (WA) - Tuesday, Oct 06, 2009 at 11:37
Not wishing to be rude I winder why Totoyta released the Cruiser 4.5 litre pertol motor and the filter that fits it is a Z9?
653491
Follow Up By: Member - Phil G (SA) - Tuesday, Oct 06, 2009 at 11:40
Petrol motors don't have much in common with an indirect injection diesel motor.
The filter for the 1Hz is dual stage (2 sets of filter elements inside) so it can filter out more of the black soot that collects in the oil of a diesel motor. Petrol motors don't have soot.
653492
Reply By: Member - Graham H (QLD) - Tuesday, Oct 06, 2009 at 11:35
I wouldnt use a Z9 on a lawnmower even if it would fit.
385942
Reply By: Member - Phil B (WA) - Tuesday, Oct 06, 2009 at 11:38
Hi all,
I am still wanting to know if these are being sold so I can let my mate make up his own mind.
Thanks again in advance.
385943
Follow Up By: Member - Ed. C. (QLD) - Tuesday, Oct 06, 2009 at 12:07
Here ya go............
Oil Filter Adaptor
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
653494
Follow Up By: Member - Phil B (WA) - Tuesday, Oct 06, 2009 at 18:17
Thanks Ed that's what I think my mate us after.
653550
Reply By: Atta Boy Luther - Tuesday, Oct 06, 2009 at 11:49
I remember seeing the ad in 4wd mags years ago and just had a phone number but no web site or address . I just buy donaldson filters which are just as good as toyota and about a third of the price .
385947
Reply By: Member - Allan B (QLD) - Tuesday, Oct 06, 2009 at 14:21
At $55 + $9 p&p for the adaptor what is the price difference between the original Toyota filter an a Z9 ?
385973
Reply By: Harrow - Wednesday, Oct 07, 2009 at 00:56
Hi Phil
To Use a Z9 is a backward step in filter efficiency
The genuine toyota and Ryco equivalents contain 2 filter membranes
the 1st is a full flow
The 2nd is much finer and is a bypass filter (takes a small % of the full flow and filters it to sun micron levels)
The end result id cleaner oils and longer drain intervals.
the Z9 is a fill flow only.
Harrow
386084
