hj47-1hz 5 speed conversion
Submitted: Tuesday, Oct 06, 2009 at 18:05
Alec L
is it possible to put a 1hz motor with a 5 speed gearbox into a hj47 or a hj45?
if so what are the main works that need to be done?
Reply By: Member - ross m (WA) - Tuesday, Oct 06, 2009 at 20:00
Weld new engine mounts.
Possible drive shaft modification
Probable crossmember fabrication
Radiator outlets on opposite sides(using A 2F radiator should solve this)
Fit
fuel filters to firewall( an OEM 1HZ filter and primer or DELPHI 296 is easiest)
Add
fuel return to
tank (I think the 2H returns the excess
fuel to the pump)
The vacuum hoses can be plugged into the 1HZ pump.
You need to add a manual glow system.
Power steering will depend on whether you have it or not,but the 1HZ pump should work ok with the 4* series steering box
Add 12v power to
fuel cut solenoid to activate
fuel pump from ignition,you mayb able to use some wiring from the EDIC
There is a few owners doing this kind of engine swap into 40 series and other landcruisers in the diesel
forum on IH8MUD.
I put a 1HZ into a FJ73 and I got a mobile auto electrician to come and wire up the alternator and starter.
Temp sensor and oil pressure should be a straight plug and play with added wire or a change of plugs where necessary.
Tacho wil lbe easier to go aftermarket
386025
Reply By: Members Paul and Melissa (VIC) - Tuesday, Oct 06, 2009 at 20:17
I do know someone who put a 12HT in a HJ47 and he said it wasnt that hard but he also has his own workshop(diesel mechanic)
386028
Follow Up By: Member - Pesty (SA) - Tuesday, Oct 06, 2009 at 21:52
That would be easy as many HJ47 had 2h motors which is the same mounts etc
Pesty
653607
Reply By: Ozhumvee - Tuesday, Oct 06, 2009 at 20:46
To fit the 5 speed you need the matching transfer case as
well, as has been said the engine mounts, transmission crossmember and its associated mounts all need to be fitted, you also need to fit a later model rear end with handbrake on the rear brakes as the HJ47 has a transfer/rear tailshaft monted handbrake.
Wheel brake cylinders are different so you may also need to change proportioning valve and master cylinder.
BTDT but it was a long while ago, came to the conclusion that is might be easier to move on to a HJ75.
386038
Follow Up By: Member - ross m (WA) - Tuesday, Oct 06, 2009 at 21:10
I thought the HJ47 had a hand brake on the rear
wheels and the HJ45 had the hand brake on the drive shaft
653600
Follow Up By: Ozhumvee - Tuesday, Oct 06, 2009 at 21:22
I had one of the last HJ47's sold in Oz (bought april 85 after the 75 series came out) and it had a tailshaft handbrake, the FJ45 I had before it also had a tailshaft handbrake. AFAIK the 60 series was the only Tojo of that vintage to have the handbrake on the rear brakes.
60 series housings are also wider track than a 47 or 75 and the spring perches need to be relocated if using them on a 40 or 75. Alternatively the 60 and 75 brake bits will fit onto a 47 housing but you will need to weld the handbrake cable mounts on.
653604
Follow Up By: Member - Tour Boy ( Bundy QLD) - Wednesday, Oct 07, 2009 at 09:50
BJ42 had the handbrake on the rear axle
653651
Reply By: Member - Scott M (NSW) - Wednesday, Oct 07, 2009 at 00:13
God knows why you want to put a 5 speed in ... they don't go around corners above 90 km/h...
386077
Reply By: Member - William H (WA) - Wednesday, Oct 07, 2009 at 00:24
Get your self a 12HT motor and fit a 5/speed box to it and slot it in.........you will need to change the rear transfer case shaft from a 4/speed box so the hand break will fit on to the box,....(You wont need to cut or modifire the cross member behind the gear box) change the bottom out let on your radiator,so it wont touch the Pwr/steering pump,your tail shaft will need to be shortened and balanced, the front shaft will be ok.....all else fits and you will need to fit a 3 inch exhaust...........Happy motoring, as i have fitted the 12ht to my HJ47......i also have fitted two Donaldson air filters and pre cleaners.some picks in my profile.
Cheers for now...William H...Bunbury...WA.
386079
Follow Up By: Alec L - Saturday, Oct 10, 2009 at 09:39
nice cruiser you have, thanks for the info. sounds like a big job but the square cruisers are worth it :)
654047
Reply By: Member - DOZER- Wednesday, Oct 07, 2009 at 17:18
Yes, buy a 1hz out of a hzj75 with belhousing and/or 5 speed, and swap them in...even better, buy a 1hz out of a hzj75 (the engine mount block mounts are different to 80 series) and a 5 speed from a 80 series and bolt that in...stromger, lower low range, heaps better....the last option however would be to buy a hdj78 and swap the runing gear/sell the leftovers
Andrew
386157
