Leaking Firestone Airbag
Submitted: Friday, Oct 09, 2009 at 16:33
Member - Jack
Hi all:
I have just discovered that one of the rear Firestone airbags on my 80 Series is leaking.
The leak is at the insert into the bag, where the airline connects. I have checked, and it is not the airline, but the thing that goes into the airbag to which the airline is connected. I tried a few quick remedies (teflon tape etc) but nothing has stopped the leaking.
Just wondering if someone can recommend a fix. It will need to be something that can handle a bit of flexing as I imagine these things can contort a bit on rough roads.
Thanks in advance.
Jack
Reply By: Atta Boy Luther - Friday, Oct 09, 2009 at 17:13
This may help , i dunno
Site Link
386405
Follow Up By: Member - Jack - Friday, Oct 09, 2009 at 17:46
Took a look at it. Thanks for posting it.
Mine are already installed, and are a bit different to those one .. it is a bag inside the coil spring.
I have tracked the leak (usi9ng soapy
water) and just need to seal that part up. I might be able to use some silicone sealant, but thought there may be another school of thought. Worst case scenario is to buy another bag, but would prefer to avoid that if possible.
Thanks for your interest.
Jack
653989
Reply By: Moose - Friday, Oct 09, 2009 at 17:45
Why not contact the supplier - may be a warranty job and if that doesn't apply they may know how to fix it. Surely yours isn't the first to leak!
386409
Reply By: Member - Graham H (NSW) - Friday, Oct 09, 2009 at 18:33
Jack
one firestone leaked in my 80 series at same spot as yours was 10 months old and replaced under warranty
386414
Follow Up By: Member - Jack - Friday, Oct 09, 2009 at 20:11
I may give that a try Graham. Only problem I see is that I have had them for about 2 years and only got around to installing them about a month ago.
Still, as they say in the classics, 'nothing ventured, nothing gained'.
Jack
654007
Reply By: Member - Mick O (VIC) - Friday, Oct 09, 2009 at 19:05
Struth you're not having much luck with these airbag thingies OBJ. Could you possibly have cross threaded a connecter (if they have them) that holds the air line in?
Mick
386419
Reply By: Member - shane (SA) - Friday, Oct 09, 2009 at 22:01
I had a similar problem as yo, it was out of warranty also. I used slim in it as i had nothing to loose, worked great. that was 3 years ago and still going.
cheers shane.
386441
Reply By: Shaker - Friday, Oct 09, 2009 at 23:26
They had a faulty batch, the replacement bags are a darker blue.
386453
Reply By: gbc - Saturday, Oct 10, 2009 at 09:03
As above - a small amout of tyre slime was the best thing I did to the bags on a previous vehicle.
386461
Reply By: Member - desray (WA) - Saturday, Oct 10, 2009 at 10:02
Reply By: OREJAP - Saturday, Oct 10, 2009 at 11:50
I heard of a quick or temporary fix on a desert trip once the tour guide/tag a long man produced a tin of vaccum sealed tennis balls when an air bag failed in the rear of a Nissan Patrol. Apparently they jacked it up and inserted the tennis balls. It worked.
386482
Reply By: Member - Greg T (ACT) - Sunday, Oct 11, 2009 at 09:59
Hi Jack,
i had the same problem just after fitting
mine. i rang the company i bought it off and they said "take the hose off and trim it so it is exactly square" i did that and no more leaks.
386577
