Tuesday, Oct 13, 2009 at 04:32
Hi Banditfj
I've owned one of these motors for five years now, added 100K to the clock, and I smile inwardly every time I drive it.The 12HT motor is one of the best that Toyota have made and should give you plenty of years of reliable motoring.
Here's a few extra tips:-
1/ When changing the air filter always unclamp and detach the rubber hose from the top of the air cleaner, don't be tempted to leave it attached and bend it out the way when replacing the filter as the hose will split [it has different diametre ends] and it costs a lot more than $100 from Toyota to replace.
2/ Use the Toyota genuine oilfilters , they have a extra fine bypass filter built in.
3/When replacing the coolant ,flush then use a 50/50 mix of Toyota "Longlife" coolant and distilled
water and change every 2 years.
4/If you cruiser is an automatic, install a transmission fluid cooler , especially if you do a lot of towing.
5/If you cruiser is a Jap import[24 volt] replace the "Japanese conditions" thermostat with the cooler running "Australian conditions" one.
6/Oil change every 5000km[I always change the filter at the same time], dump the oil within a minute of turning off the hot engine, while all the sludge is still in
suspension and let it drain overnight. Pre-fill the new oil filter before spinning it on the motor, that way the oil pressure comes to normal much quicker.
7/ Consider adding CAV
fuel-filter with a
water-trap, this greatly extends the life of your regular
fuel-filters and is a bit more protection for your pump and injecters.
Enjoy Your Purchase
Welldone
654397
