Engel Hardwiring - 24V
Submitted: Tuesday, Oct 13, 2009 at 13:20
Banditfj
I've recently bought a HJ61 'cruiser that came with an old Engel fridge, capable of running on 24V (The car is a Japanese Import)
My problem is that the previous owner simpy cut the plug off the fridge, ran cables from the batteries to the back and hardwired the fridge without a switch or fuse! I tested the fridge with my 12/24V power supply and it still works
well so i'd like to keep it.
I'd like to install a plug and socket in the back of the car so I dont have wire hanging everywhere in the back, what 24V socket and plug sets work best? I was thinking of using the Engel Posi-fit lead and using that as the new power lead at the fridge end, then an Engel 2pin socket in the car. These are the leads that come with the new fridges which are also able to run on 24V.
What size fuse(s) should I be putting in-line from the battery end? I'm pretty sure that the start-up current of the compressor motor is 1.83A max @ 24V, will a 2A fuse suffice?
Reply By: mazcan barry - Tuesday, Oct 13, 2009 at 14:49
hi
the the fuse in my engel plug is a 10amp thermal with a directional arrow 12/24v even my old 29ltr engel 12v/240v has a 10amp fuse
386881
Follow Up By: Banditfj - Tuesday, Oct 13, 2009 at 19:18
yeah i know the lead is fused, but what about from the battery to the back of the socket? if the 12V fuse is 10A, can I run a 5A fuse near the battery?
654480
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Oct 14, 2009 at 00:44
"if the 12V fuse is 10A, can I run a 5A fuse near the battery? "
Yes in a 24V system.
| Geoff,
654556
Reply By: Member - Matt & Julie (VIC) - Tuesday, Oct 13, 2009 at 21:06
I have in the past run one 40 ltr Engel that was with a 20 amp fuse now I am running 2 40 ltr Engels I have a 32 amp fuse at the battery
386934
Reply By: Welldone WA - Wednesday, Oct 14, 2009 at 02:07
The 24 volt imports have a fuse protected, black "power outlet " box in the engine bay [driver's side] where you can tap off 24 volts from the main continuous[10 amp] , the ignition[7.5amp] or the accessories circuits[7.5amp] . Just unscrew the cover and all is revealed.
I've got my Engel on the ignition circuit[24 volts/7.5 amp] to prevent flattening the starting batteries when the motor is switched off.
When we stop away from AC power for an extended period, I plug the Engel DC lead into the 12 volt solar powered auxillary battery.
Welldone
386965
Reply By: get outmore - Wednesday, Oct 14, 2009 at 02:29
if you get the engle plug it comes with 2 fuses one for positive and for some reason one for neagative.
i couldnt recomend using the engle plug however as
mine was junk and zI just couldnt get it to make a reliable conection.
I hard wired it and have never looked back
BUT I hard wired it via the 2 fuses that came with the engle plug
386966
