Fuel consumption with bigger tyres
Submitted: Wednesday, Oct 14, 2009 at 15:37
Member - Ingo57 (NSW)
Gday all,
My old man and I both have 4.8 Patrols
mine being an 06 and his an 02 & he always seems to average around 19 - 20lts per 100km,
mine always around 25/100, the only real difference is he runs standard tyres and I run 33"s. I expect a difference because of the tyres but he is grabbing another 100kms or more out of his main
tank in comparison to me.
Ive never bothered working out the speed difference but does this seem right?
Just wondering If anyone takes into account there tyre sizes when working out litres per 100.
Reply By: Robin Miller - Wednesday, Oct 14, 2009 at 16:05
Hi Ingo
To maintain high accuracy I measure my GU 4800's 16.5lt/100km long term average against the GPS which shows an odometer correction factor is required.
for my 265/75/16 wheel set the oddmeter is correct
for my 235/85/16 wheel set oddometer reads 1% low
for my 255/85/16 Coppers odometer reads 4.0% low (they are almost worn out).
for my 255/85/16 Bighorn near new mud terrain wheel set the odometer is 5% low
Minor corrections also occur when tyres are at low pressure but GPS trip meter corrects for this.
The above is in close agreement with what you would expect.
I.E. the diference between 32/33in tyres is that 33in read about 3% low on odometer
which has no relationship to speedo readings.
P.S Lumpy tyres use a lot more
fuel , espically if not at high pressures (40+)
387035
Follow Up By: Member - Ingo57 (NSW) - Wednesday, Oct 14, 2009 at 16:35
Hi Robin,
I know when we go to his farm 180kms odd each way we end up with a different speedo reading, but Im buggered If I can remember the difference.
I have always just accepted the 25/100 but I guess I will have to measure next
tank with the GPS to get a dead accurate figure, will be Interesting for I've never worked it out that way, always off the odometer!
654605
Reply By: Member - Shane D (QLD) - Wednesday, Oct 14, 2009 at 16:34
How about a swap.
Go a
tank full and swap your old mans patrol
wheels and tyres to see if the same thing happens on his vehicle.
You then have a chance to see yourself if its tyres or some other issue.
Shane
387044
Follow Up By: Member - Ingo57 (NSW) - Wednesday, Oct 14, 2009 at 16:48
The old man has a bad back so he fitted a set of Recaro's in his GU.
I run some refurbished Scheel seats that they use to fit in the Brock Commodore specials, but you couldn't pry him away from his Recaro's for a week LOL.
654610
Follow Up By: Member - Ingo57 (NSW) - Wednesday, Oct 14, 2009 at 16:57
Ooops!
Swap tyres not car.... sorry Shane I miss read your reply on that one.
654612
Reply By: Member - Tonyb (FNQ) - Wednesday, Oct 14, 2009 at 16:35
Ingo57 - You need a petrol station towed behind your car - That's a lot of
fuel :-)
387046
Follow Up By: Member - Ingo57 (NSW) - Wednesday, Oct 14, 2009 at 16:42
Yeah she's a thirsty beast.....but its great fun to drive, never short of horses !!
654607
Follow Up By: mazcan barry - Wednesday, Oct 14, 2009 at 20:00
hi
aaah there"s a good clue Ingo57 have read all the threads above
i would just about put money on the fact after reading your last thread that your father drives and uses the the throttle in a much less agressive way than you do
and believe me that can make a huge difference in
fuel consumption between to drivers the old buck and the
young towey buck - betcha !
that's got a lot to do with it
now change swap the
wheels as suggested and see what happens but drive in your normal way no cheating
seen it many times cheers
654634
Follow Up By: mikehzz - Wednesday, Oct 14, 2009 at 20:31
Roof racks make a noticeable difference as
well. Does he have racks?
654642
Follow Up By: pling - Wednesday, Oct 14, 2009 at 22:17
The "old man" does not have roof rack on like son! But does use the throttle as heavy as the son and cruise control more, regardless which gear and revs the "cruise" selects.
654661
Reply By: Snowy 3.0iTD - Thursday, Oct 15, 2009 at 08:05
Ingo57
Running 265/70R16 Duellers, then 285/75R16 Duellers, then 285/75R16 MTR's and then 285/75R16 MT MTZ's all on a 03 Patrol 3.0L diesel, I found that bigger tyres once you had corrected for the effect bigger tyres had on the odometer had no effect on
fuel consumption. More aggressive tread types did however increase
fuel consumption, although most of my driving is on the highway, rather than stop-start driving around town.
Snowy
387126
Reply By: Member - Troll 81 (QLD) - Thursday, Oct 15, 2009 at 11:34
Have you had your truck on the Dyno? I used to have really high
fuel consumption and after a dyno tune they found the MAF sensor was faulty. After a good tune and new sensor I was getting much better
fuel consumption. I only have the 4.5 though
387149
Follow Up By: Member - Ingo57 (NSW) - Thursday, Oct 15, 2009 at 12:22
No Haven't run it on a dyno Troll. Think I will do another measure but with the GPS this time but point taken, I will be happy If I get it near the old bucks 20/100 LOL.
Ive given the Patrol a hair cut as
well (took the roof rack off) but I wouldn't expect that much of a difference around town maybe on the freeway.
Just curious what's your consumption in the 4.5?? Manual or Auto?
654717
Reply By: Member - Troll 81 (QLD) - Thursday, Oct 15, 2009 at 12:46
It's manual and I get on the highway anything between 630-650 out of 115L I have a roof rack as
well. Around town I get around the 550km's
387159
