Ozi Explorer Instructions (Help!!)
Submitted: Thursday, Oct 15, 2009 at 12:55
ThreadID: 73023 Views:4074 Replies:5 FollowUps:3
I recently purchased a VMS GPS (Touring 500 plus 2 reverse cameras) )which came with the usual Street Navigationand an off road Memory Map iTopo feature that I was trying to get into when I had an SD card malfunction.
Sent the unit back to the factory and upon return I had a new SD which included the previously mentioned features plus the Ozi Explorer off road maps arrangement.
I have found that Ozi Explorer is much better to use than Memory Map but my problem is I do not have any written instructions for its use.
Unfortunately the new Ozi Explorer feature did not come with any "Help" data.
Can any body on the site help and direct me to where I might get some good information for using the Ozi Explorer?
It would be great if I could download a PDF booklet as I did for the original Street Nav & Memory Map but the VMS site does not seem to have such information.
I am even happy to go through video sequences to learn if necessary rather than by trial and error as I am doing now.
Help!!
"Life is not a Rehearsal"
Reply By: Member - Fred B (NT) - Thursday, Oct 15, 2009 at 13:00
All you need to know is here OziExplorer CE
If you still have dramas ask specific help questions. It is a very comprehensive program and will take a little time to learn.
regards
Fred B
VKS 737: Mobile/Selcall 1334
AnswerID: 387162
Follow Up By: The Explorer - Thursday, Oct 15, 2009 at 13:12
Further to Freds post here is the link to the online help
OziCe Online Help
Best bet is to read this and have a play with the unit. When you identify a specific problem or question then post on the forum. Someone will usually be able to help.
FollowupID: 654722
Reply By: The Explorer - Thursday, Oct 15, 2009 at 13:15
There are some video tutorials here - made for the Hema Navigator but I assume program is the same one as loaded on the VMS
OziCe Video tutorials for Hema Navigator
AnswerID: 387163
Reply By: Peter W - Thursday, Oct 15, 2009 at 14:08
Thanks Fred & Greg.
These references and the info therein is excellent.
Thanks for the "heads up".
This is a great site for valuable info.
Cheers.
AnswerID: 387168
Reply By: MADOG - Thursday, Oct 15, 2009 at 19:15
Peter,
The best way to manage your VMS unit is to have the full version of OziExplorer on your computer and manage all your OziExplorer activity at that level then transfer the data back and forth via the SD card.
Good info for OziExplorer beginners can be found at OziExplorer Education. This site will also give you free access to the National OziExplorer E-TREK library where you can both submit and withdraw track and waypoint files for many locations around Australia.
Hope this helps
Roger
AnswerID: 387200
Follow Up By: Peter W - Thursday, Oct 15, 2009 at 23:07
Thanks Roger.
The first thing I need to work out is actually what I have with the Ozi Explorer addition from VMS.
From a lay man's look it seems I have an Australia wide map that will allow "moving map" ??? operation but without other support.
On my GPS screen it does not appear that I can get the usual toolbar operation.
I did try to download the Ozi Maps onto my computer but Windows could/would not open them so I am not sure what is happening.
I will continue to read up on the information provided.
FollowupID: 654793
Reply By: MADOG - Thursday, Oct 15, 2009 at 23:39
Peter,
I have an older version of VMS in my Landcruiser and cannot offer much help as to the operation of your model as the new versions are radically different to my version.
I expect you haven't much at all in there to function with OziExplorer.
I reckon you will need to get some digital maps with each ones unique OziExplorer .map file on to your computer after loading a copy of OziExplorer to run them and then copy them over to the SD card and then slip that into the VMS.
Good Luck!
Roger
AnswerID: 387251
Follow Up By: The Explorer - Friday, Oct 16, 2009 at 00:13
New versions of VMS come with a demo verion of OziExplorerCe plus GeoScience 1:250K Topo maps & HEMA Raster map collection preloaded on 8GB Micro SDHC memory card.....AFAIK..though what Peter W has is unclear.
FollowupID: 654812
