low coolant alarm types? best / most reliable and easiet to install?
Submitted: Thursday, Oct 15, 2009 at 13:18
ThreadID: 73024 Views:13077 Replies:6 FollowUps:21
Hi all.
We are looking to install a low temp alarm to an 80 series wagon with the multivalve turbo motor. we have an old 60 series with a low coolant alarm but that was soldered into brass tank.
Now with plastic tanks we have been told not a good idea to drill / tap into.
I spoke to bloke at "engine saver" and their product fits in line in the radiator hose if the top hose has 80-100m of straight section,
or (i was nt so sure about this idea) the probe is fitted between the end of the radiator hose and the top tank outlet of the radiator, which he asues me will seal properly and they have been doing for years.
Can any one sugest alternatives or better ideas or let me know if they have had a good run with this kind of product?
Kind regards
GN
Reply By: Ozhumvee - Thursday, Oct 15, 2009 at 13:38
Get the unit that has both the temp sensor and low coolant alarm in one unit, much easier to find and wire a single thing than two seperate.
AnswerID: 387164
Reply By: Member - Rodney B- Thursday, Oct 15, 2009 at 14:22
I've got the engine saver with the heat sensor on my 80 series and it works very well. Easy to set your engine temp (a small dial and you set it just above mormal and if it alarms it will frighten the Bejeezus out of you, so you can't miss the alarms).
I have had no problems with the top hose fitting but I do carry a spare hose anyway. The fitting is well made and seals easily. Can't comment on the other units but I do recommend the engine saver.
AnswerID: 387169
Follow Up By: Member - G N (VIC) - Thursday, Oct 15, 2009 at 18:38
Hi Rod
thanks for info
GN
FollowupID: 654746
Reply By: Member - Trouper (NSW) - Thursday, Oct 15, 2009 at 16:13
I've had my engine saverfor 6 months now, I feel a lot more comfortable with it as I dont have to constantly look at the Temp gauge....... go for it.
Regards .......jeff
AnswerID: 387180
Follow Up By: Member - Graham H (QLD) - Thursday, Oct 15, 2009 at 17:48
Mine has been in for 28000k of towing and hasnt leaked a drop Is in the top hose of a 100 ser
FollowupID: 654740
Follow Up By: Member - G N (VIC) - Thursday, Oct 15, 2009 at 18:39
so are the units you are running the "in the hose" type or in between the hose and radiator tube type?
regards'GN
FollowupID: 654747
Follow Up By: Member - Graham H (QLD) - Thursday, Oct 15, 2009 at 19:37
Cut the hose and put the joiner in
In the 100 it goes in the angled down piece just back from the radiator So it is about 50-70mm below top of coolant level.
FollowupID: 654756
Reply By: Member - Rob S (NSW) - Thursday, Oct 15, 2009 at 16:44
Have look at these http://www.enginewatchdog.com/tm2.htmlvery easy to install
i have one and found it to be very good.
I only ever made one mistake
AnswerID: 387182
Follow Up By: Member - G N (VIC) - Thursday, Oct 15, 2009 at 18:40
Hi Rob S
are these units a low coolant alarm or a high temp alarm you put n the mortor somewhere?
regards
GN
FollowupID: 654749
Follow Up By: Member - Rob S (NSW) - Thursday, Oct 15, 2009 at 19:53
Hi GN
I thought it went hand in hand no coolant the engine gets hot?
And yes you put the sensor some where on the engine usually the thermostat housing.
There are other factors to consider that can over heat the engine other than coolant lose.
IE
Broken fan belt
blocked or clogged radiator cooling fins
oil lose
dragging brakes
towing to heavy load up hills
radiator hoses sucking flat restricting flow
thermostat stuck closed
water pump failure
FollowupID: 654757
Follow Up By: Member - Phil G (SA) - Thursday, Oct 15, 2009 at 20:23
Gn,
Yep there are plenty of options now, and if you want to cover everything, do what Ozhumvee says above and fit both types, or a unit that alarms for both high temp and low level.
But like Rob, I'm a fan of the TM2 (high temp alarm) and have fitted 3 of them now. I liked the continuous temp readout, the fact that I didn't have to break into the cooling system, there is no risk of stray current stuffing the radiator, and like Rob says it covers anything that causes overheating.
After installing it on my daughter's 1Hz 80series, the TM2 rose to 100 degrees on the hill out of Adelaide. The temp gauge didn't move. We checked out the cooling system and the radiator was 60% blocked, the fins had some mud, and the thermostat was opening 5 degrees too late. We fixed all that and the temp says low now. Great bit of gear for $149.
FollowupID: 654761
Follow Up By: Richard Kovac - Thursday, Oct 15, 2009 at 20:52
Me three. I didn't like to cut into cooling system, but I like the probe for the some engines but not mine.
Phil I was amazed with the heat soak the engine got when you shut down for 5 min (go into a shop buy something return) then start up alarms going off all over the place, but never get that hot while moving even on the hardest drive I've done since fitting it.
Image Could Not Be Found
The gauge has now been screwed to duct, Velcro tape would not hold, but it was only temp to make sure i could see it OK... and I can
Richard
FollowupID: 654763
Follow Up By: Member - Phil G (SA) - Thursday, Oct 15, 2009 at 20:59
Gday Richard,
GN has the same motor as we have - should have the same spare bolt hole in the cyl head. I have the probe in the same place as you have. My daughter's is on the bolt below it (on the alloy outlet) and I reckon she gets a quicker change of temperature.
FollowupID: 654765
Follow Up By: Member - G N (VIC) - Thursday, Oct 15, 2009 at 21:35
Hi Rob S, Phil and Richard
thanks for the good info.
I too like the idea of not chopping into the cooling system, and the stray current has crossed my mind too.
The other reasons for high temps are also valid too.
I have been wanting a product to put onto a John Deere Gator 3cyl diesle but was too much stuffing around with the coolant level type i thought, so the temp alarm may be a good option there too.
is the hiugh temp / alarm annoying after the vehical has been sitting Richard?
Can this be overcome somehow?
What temp do you have the alarm set at?
'GN
FollowupID: 654772
Follow Up By: Richard Kovac - Thursday, Oct 15, 2009 at 21:37
Mine will run at 74-76 deg all day, may climb to 80 - 82 deg. on some harder stuff, and 90 deg when only stopped for a short time and drops back when run 10 - 20 sec.
I haven't driven the Troopy for over 7 weeks so can't remember what I set it to I think 90 deg.
I also like them as they can be used for other things not just coolant Temp.
Diff. gearbox/transfer, and in my game hydraulic oil temp..
Richard
FollowupID: 654774
Follow Up By: Member - G N (VIC) - Thursday, Oct 15, 2009 at 21:44
Hi Richard
Very interesting, the hydraulic idea apeals to us too. Better than hold hand on oil tank (if can)
What size is the unit itself?
How long is the standard cable and can you extend it or get longer types?
Surely the need to have coolant level alarm would not be required with a temp alarm?
Could there be a situation where the temp alarm would not warn you if there was a suddent / total coolant loss???
regards
GN
FollowupID: 654778
Follow Up By: Member - Graham H (QLD) - Thursday, Oct 15, 2009 at 21:51
Ok Richard as u know i have one of these and have been looking at a temp gauge for Auto trans oil temp. Where would I put the sensor for that.
Have been looking at an Autometer electric oil temp gauge and probe for $58
Can get a threaded block to fit on the out line to the cooler for another $38
postage $39 which all up is less than the enginesaver model
All this from here
http://www.atlanticspeed.com/productcart/pc/viewPrd.asp?idcategory=19&idproduct=1012
FollowupID: 654780
Follow Up By: Richard Kovac - Thursday, Oct 15, 2009 at 22:44
GN
Q1 What size is the unit itself?
A1 The box section looking at the display face is W 82 mm x H 30 mm. A standard lid with mounting tabs adds 12 mm to each end.
Q2 is the high temp / alarm annoying after the vehicle has been sitting Richard?
A2 Yes - No if it goes off just set it a little higher, the paper work says find out the highest you can get the engine temp then set it 5 deg higher.
Q3 How long is the standard cable and can you extend it or get longer types?
A3 4m (12ft) Longer leads are available
Q4 Surely the need to have coolant level alarm would not be required with a temp alarm?
A4 I don't think so and nor does Toyota, but they fit a temp gauge.
Q5 Could there be a situation where the temp alarm would not warn you if there was a sudden / total coolant loss???
A5 I would say no, but I'm also not sure.
Check out there web site on the first post.
Richard
FollowupID: 654787
Follow Up By: Richard Kovac - Thursday, Oct 15, 2009 at 22:59
Graham
Q1 Where would I put the sensor for that?
A1 in or around the outlet from the transmission or at the inlet to the cooler, they will be the hottest spots.
the Auto Meter 5747 Phantom Series 2-1/16" Electric Oil Temperature Gauge
Temperature Gauge Range: 100°-250° is in Fahrenheit you will need a calculator or are you old enough? :-)
Most automotive instrument shops should have an adapter so you can get the probe in some where.
The thing as you know is the TM2 is adjustable and has an alarm, the main reason I fitted one, THE ALARM gauges are useless if you are not looking at them.
Just like the speedo, seconds before the cop pulls you over...
Richard
FollowupID: 654789
Follow Up By: Member - Graham H (QLD) - Thursday, Oct 15, 2009 at 23:07
Yep Im old enough but am getting a metric one 5748M.
FollowupID: 654791
Follow Up By: Richard Kovac - Sunday, Oct 18, 2009 at 02:15
First hot day since I fitted gauge. 37 deg c in BK. on the way back to Perth gauge showed 85 - 87 deg c, was set, adjusted, and ran at "Took the Troopy for a run up Greenmount and it reached 83 deg. c so I've set it at 85 deg. c, and will see how it goes."
"24/05/2009 I have now set the alarm to 90 deg. c and on open country, Troopy by itself she is running at around 75 to 76 deg. c." (taken from blog)
All winter, avg 25 deg c so + 10 -15 deg c ambient = same on gauge, as gauge is showing head/block temp not Coolant Temp. interesting.. will keep notes.
Richard
FollowupID: 655054
Reply By: StormyKnight - Thursday, Oct 15, 2009 at 18:15
I have just bought one of these....currently in transit...
http://www.carsensors.com/ETMS.html
Benefits...
Smaller display, easier to mount (in my Prado)
Visual & Audible indication of over temperature
Can combine with parking sensor unit
I requested a modification to the display format on mine so that instead of displaying 085 it displays just 85...this was no trouble at all during my correspondance with the company which was very quick. They also provided a few answers for me & supplied the user manual which promptly answer all my other questions.
Worth a look....can be found on ebay.com.au or direct from the web site.
AnswerID: 387191
Follow Up By: Member - G N (VIC) - Thursday, Oct 15, 2009 at 21:38
Hi StormyKnight
what are the dimensions of the unit?
regards GN
FollowupID: 654776
Follow Up By: StormyKnight - Friday, Oct 16, 2009 at 20:23
The display unit is wedge shaped....
Width is 105mm
Height is 24mm
Depth is 27mm
ideal to wedge between windscreen & dash or perhap above near rear view mirror
The control unit which you stick under the dash somewhere is a square box 75mm x 60mm x 25mm
I got my unit today, I have already bench tested it. It actually indicates yellow if below 50deg C without the buzzer, green above 50 & below the preset warning, red flashes at the warning temp with beeps & continuosly when 10 deg over the warning temp.
FollowupID: 654932
Reply By: Member - Allan B (QLD) - Friday, Oct 16, 2009 at 01:11
This has been dealt with before on an earlier thread buuuuut...............
If you experience sudden coolant loss as in a ruptured hose (as I have) the engine temperature will rise rapidly (as mine did) and wreck the engine (as mine was).
The dash temperature indicator may, or may not, show the true engine temperature (as there is no coolant to measure) and anyway, it does not provide an audible alarm and just how frequently do you look at it anyway?
Coolant is essential and you need to know if you lose it, not to learn the result of losing it!
Engine temperature monitoring is also necessary as coolant loss is not the only reason for high engine temperature, but this also needs an audible alarm for the same reasons. If driving on a difficult track you are not going to be scanning the dash gauges every ten seconds.
Fit coolant level and engine temperature alarms, both with audible.
AnswerID: 387263
Follow Up By: StormyKnight - Friday, Oct 16, 2009 at 20:26
If you choose a better point of measurement it can avoid the issue of measuring the coolant temperature rather than the actual engine temperature....
FollowupID: 654934
Follow Up By: Member - Allan B (QLD) - Saturday, Oct 17, 2009 at 00:26
Yes exactly StormyKnight. In the case of my earlier failure the temperature sensor was positioned in the coolant at the top hose manifold.
With an after-market device (usually a thermistor) you have the option of positioning it elsewhere such as directly bolted to the head or block. This seems a "better point of measurement".
FollowupID: 654957
