Tyre Pump Inflator 4WD
Submitted: Thursday, Oct 15, 2009 at 19:00
richard cee
Would like to know a quality brand and reasonable cost of a 12v tyre inflator for 4wd, reliable and able to pump up 8 tyres on car and caravan when and if need be due to pressures being reduced on the odd occassion. We live in
Perth, WA
metro area if this helps. Many thanks, R.
Reply By: Member - Tony V (NSW) - Thursday, Oct 15, 2009 at 19:24
Richard, I use a Projecta Typhoon,
twin head unit that works great after having one fail within a month.
There will be a dozen or more opinions on this...
ARB make good units, one of the traders will introduce you to the Sidewinder
Bushranger and even
Supercheap.. etc. etc.
Start looking around $200.00 + and - a few bucks, with anything above 72 ltrs per minute as a starting point.
4WD distrACTION magazine did a test not long ago. if you can fine that it will help as
well. If you have a 4WD
shop that you trust ask them as
Good luck
387201
Follow Up By: Member - Allan B (QLD) - Thursday, Oct 15, 2009 at 21:03
I also have a Projecta Typhoon although it looks a little different to the one pictured.
It never misses a beat but is getting pretty warm by the time it has re-inflated the four Coopers on the Troopy.
654766
Follow Up By: Member - Tony V (NSW) - Thursday, Oct 15, 2009 at 21:11
Alan B
If you re-read the comment above the picture you will see that its the Sidewinder from ABR.
This is the Typhoon
654769
Follow Up By: Member - Allan B (QLD) - Thursday, Oct 15, 2009 at 23:11
Tony, ahh yes, now that looks like
mine.
654796
Reply By: Member - Tonyb (FNQ) - Thursday, Oct 15, 2009 at 19:31
The Kincrome is a good compressor and will do the job
Kincrome Link
Good price here at $179
387202
Reply By: Member - ross m (WA) - Thursday, Oct 15, 2009 at 21:13
Bushranger have one for about $140 that is supposed to be ok,but if want something really good ,you need to spend a bit more.
387216
Reply By: Serendipity of Mandurah (WA) - Thursday, Oct 15, 2009 at 22:56
Hi Richard
What sort of car a you wanting to use the pump with. Because the best tyre inflater I have ever come across is using an old airconditioning pump running on your motor. I means you need the room under the bonnet to fit the unit.
With my current car I cannot fit one but my old landcruiser had one. I had one of those older versions that have two pistons in them with a little sump so they did not run out of oil.
Could pump tyres up the fastest. Cheap to setup - I think I bought
mine from a wreckers for $50 and made up a bracket to hang off the existing aircon pump and run the v belt off the extra pulley on the aircon.
David
387242
Follow Up By: richard cee - Friday, Oct 16, 2009 at 12:09
David, great idea. Car is a Pajero 2004 Diesel.
May need to consider the portability due to pumping up caravan tyres.
Thanks, R.
654852
Reply By: Member - Troll 81 (QLD) - Friday, Oct 16, 2009 at 10:38
I have one of the older ARB engine mounted ones works fine for me. It does get really hot and if that one fails one day I will upgrade to the new ARB unit
387307
Reply By: Michael ( Moss Vale NSW) - Saturday, Oct 17, 2009 at 19:23
Spend a few $$$$ more and buy a reliable Big Red Or ARB.. For reliability you just cant beat them.. THEY WILL NOT LET YOU DOWN!!!!!.Michael
387508
Follow Up By: That Troopy Bloke (SA) - Sunday, Oct 18, 2009 at 20:41
Quote : "ARB.. For reliability you just cant beat them.. THEY WILL NOT LET YOU DOWN!!!!!."
Except for when they fail.
Yes, they fail too....
mine did, and many others have too.
Glenn
655138
Reply By: richard cee - Saturday, Oct 17, 2009 at 20:14
Many thanks for the replies, will start looking in the next week or two. Once again thanks to all for your help, Richard.
387518
