Koni shocks? are they worth it? What prices can you get them for?
Submitted: Thursday, Oct 15, 2009 at 21:47
ThreadID: 73041 Views:8677 Replies:7 FollowUps:6
Hi all
I have run Koni shocks before and have had a great run out of them, have nevver buggered one and have had many other so called good ones fail.
What do others recon?
What kind of $ would you pick up Koni's theese days for an 80 series?
regards
GN
Reply By: Member - Tony V (NSW) - Thursday, Oct 15, 2009 at 21:58
Google is your friend for prices
Google Search for Koni's
Suspensionstuff
AnswerID: 387232
Reply By: Crackles - Thursday, Oct 15, 2009 at 22:23
If reliability is high on your priorities then the extra cost is more than worth it. My Koni's have been transferred to their 3rd car & have taken an absolute flogging. There are higher performance shocks around for sure but not many in that price range would last as long.
Price???? I wouldn't know. From memory mine cost about $125 eleven years ago :-)
Cheers Craig............
AnswerID: 387237
Follow Up By: OREJAP - Thursday, Oct 15, 2009 at 23:29
Had Koni adjustables on three vehicles, a L/Cruiser, GU Patrol & NP Pajero and never s problem. As you probably know you can pull them apart & rebuild them. I phoned around asking touur operators what tyres & shocks do they prefer on their vehicles. Answer was Koni, Bilstein & OME. In that order.
FollowupID: 654801
Follow Up By: Crackles - Friday, Oct 16, 2009 at 22:03
Interesting they said OME at number 3. I've found them to be one of the worst performing shocks on my outback trips in fact last month one fella pulled his top price LTR's off after they faded in the first day of hard driving. I suppose like many others they fit them because they have a large service backup & a big name on the sticker.
FollowupID: 654944
Reply By: ajd - Thursday, Oct 15, 2009 at 23:54
Wouldn't use any other brand.
AnswerID: 387254
Reply By: Travelin OZ - Thursday, Oct 15, 2009 at 23:57
If they are good and they work for you, PRICE shouldn't matter, simple really.
AnswerID: 387255
Reply By: Member - Oldplodder (QLD) - Friday, Oct 16, 2009 at 08:48
Have used a range of shocks of well known makes, and now have koni.
Lasted twice as long, still one more adjustment to go, and will be sticking to them.
Might have to get them rebuilt.
How much, can't remember, too long ago. :o)
AnswerID: 387284
Follow Up By: Member - Oldplodder (QLD) - Friday, Oct 16, 2009 at 08:49
Forgot to add, what I like about the konis is that they are mainly a rebound shock, so compression is not as much as a jolt on a bump as most shocks. Makes a difference on a firmly sprung 4wd.
FollowupID: 654828
Follow Up By: Member - G N (VIC) - Friday, Oct 16, 2009 at 20:44
Hi Oldplodder
interesting info on the type of shock
I would agree the suspension on my 60 is pretty hard and has Konis and is as goos as a lot of coil vehicals i recon.
GN
FollowupID: 654936
Reply By: Member - Troll 81 (QLD) - Friday, Oct 16, 2009 at 10:23
I replaced my Rancho's adjustable's with Koni's about 12 months ago and what a difference it made in my ride. The plus factor for me was that they are rebuildable which means in 2-3 years I will only have to spend about $35 per shock.
If you are happy with them then just stick with them you can't go wrong.
AnswerID: 387300
Follow Up By: Member - G N (VIC) - Friday, Oct 16, 2009 at 10:50
Hi all and thanks for the comments,
It confirms my past experiences also.
many thnaks
GN
FollowupID: 654838
Follow Up By: Gronk - Friday, Oct 16, 2009 at 12:38
$35 a shock ??? try approx $90....!!
Have had two of my Konis lose compression damping ( 1 rear, 1front ), so the front shocks are now Bilsteins and the back will be if the Konis give any more trouble....
FollowupID: 654857
Reply By: Member - Old Girl (QLD) - Friday, Oct 16, 2009 at 20:14
My 80 has them. Great.
AnswerID: 387406
