Snorkel Help
Submitted: Saturday, Oct 17, 2009 at 10:54
ThreadID: 73081 Views:3325 Replies:3 FollowUps:2
Hi All,
I want to put a snorkel on the F100. Now nobody (Safari, Airflow etc) makes one for a 1986 F100.
I've been told that the angle on the GQ Patrols is the same but can get no other details from Safari or Airflow on dimensions.
I'm looking at this one:
Safari
or this one
Airflow
If anyone has one of these fitted could you please measure the distance from the rear of the bottom corner where it curves upward to the rear of the tube section that goes through the guard.
TIA
Ross
Reply By: RobertHL (SEQ) - Saturday, Oct 17, 2009 at 15:31
G'day how are you travelling Rossco
You might like to think about making you own as quite a few others have either out of stainless,aluminium or pvc pipe around 2.5/3 inch.Have seen a couple made from these products but not up close & personal.
There have been some posts on here about them but none have had pics.
Not much help,though may be food for thought.
Bob.
AnswerID: 387483
Follow Up By: Rossc0 - Saturday, Oct 17, 2009 at 16:50
Hi Bob,
Travelling's good was down SEQ about 4 weeks ago in the F100.
Had looked at that for the snokel but just wanted something that was done as opposed to having to construct it myself.
Ross
FollowupID: 655008
Reply By: GQueue - Saturday, Oct 17, 2009 at 17:01
Okay, if I've followed what you want measured correctly....
The GQ Safari snorkel is 800mm (give or take a few mm) from the rear of the air intake to the start of the up sweep, measured on the bottom of the horizontal length. The air intake is about 100mm, so 900 or so to the front of the intake. If it helps, the angle of the snorkel is approximately 50 degrees from the horizontal for the vertical length.
Hope it helps, just don't ask us to convert to imperial!
AnswerID: 387490
Follow Up By: Rossc0 - Saturday, Oct 17, 2009 at 17:16
Thanks.
FollowupID: 655012
Reply By: Member - Duncs - Saturday, Oct 17, 2009 at 21:00
Rossco,
Don't know if it will help but the snorkel for an MQ is the same angle and the horizontal piece is a bit longer than the GQ.
Duncs
AnswerID: 387524
