Deep cycle battery test results
Submitted: Sunday, Oct 18, 2009 at 18:09
ThreadID: 73116 Views:6019 Replies:6 FollowUps:28
A few weeks ago, I posted to say I was running a test on my new deep cycle battery set-up. The aim was to see how long I could be independent of mains power having added a 100ah deep cycle battery to our van in preference to a solar system or generator, either of which would have cost between $1,500 and $2k. Here are the results for those who are interested.
The set-up is a 16.5 ft Jayco Freedom Outback poptop powered by a 60ah Thumper deep cycle battery linked to a 100ah deep cycle battery.
For the test, I ran an 18l Waeco fridge for 24 hours a day and lights (4 x 1.5w globes) for three hours a day. Temperatures ranged from 8 to 18 deg C throughout the test. Readings were taken at 9pm each night after the lights had been on for three hours and the fridge for 24 hours.
Day 1 12.8v
Day 2 12.7v
Day 3 12.5v
Day 4 12.4v
Day 5 12.0v
Day 6 11.9v
Day 7 11.6v
Day 8 11.1v
Day 9 kaput at 6pm
The batteries took three days on mains to come up to full charge.
Under normal circumstances, we would be running our 40l Engel as well as a TV via an inverter for a couple of hours a night. Given that we only have 120 l of water on board I figure our power would last longer than our water supply.
We are doing a couple of trips this summer o I will be able to test the system in more realistic conditions. With warm weather, fridge opened and shut and so on I know we won’t get eight days.
The way we travel, three days in caravan parks and three days free camping will do just nicely and at a cost of $260 rather than $2k.
Doug
Reply By: Bonz (Vic) - Sunday, Oct 18, 2009 at 18:33
What a great test Doug, I am very impressed with how the system stood up.
So you had 100 and 60 amp batteries running the whole shebang. Day 1 to day 4 results are excellent for the setup.
If my calcs are right then thats 210 hours meaning an average draw for the Waeco of roughly 0.8 amphours. That would indicate excellent battery capacity to me I would expect around 3amphours for a Waeco.
AnswerID: 387604
Follow Up By: Tenpounder (SA) - Sunday, Oct 18, 2009 at 19:22
I don't quite get your drift, Bonz. The batteries in question were 100 AH and 60 AH, not 100 amp and 60 amp. Also the consumption you calculated should in amps (to measure 'average draw') not AH (which measures total draw over a period).
But, more important, you cannot calculate average battery draw by total nominal capacity (160 AH) divided by total operating hours (9 days at 24hrs, or 210 hrs), because the total capacity (in this case 160 AH) is not all available. Any battery I know of will cease to power anything long before it reaches zero: the voltage will collapse well before it has supplied its nominal AH capacity.
But I agree with you that the system performed well.
FollowupID: 655119
Follow Up By: Gronk - Sunday, Oct 18, 2009 at 19:35
But.....if you want good service out of the batteries.......after they reached 12V, then thats when the test should have stopped !!
But still, it will serve you well for what you want out of it !!
3 days to recharge ?? ....you must be running a small charger ??
FollowupID: 655122
Follow Up By: Bonz (Vic) - Sunday, Oct 18, 2009 at 20:08
Hey Tenpounder. If you assume that the capacity of the battery is available and that it is exhausted when the batteries die then, 160AH is available and that was exhausted after 210 hours wich averages out at 0.8 amps per hour roughly.
One would assume that a 100AH battery would deliver 100 amps for one hour or 1 amp for 100 hours and that would be the delivery of the battery.
Yer I means amps per hour not amphours, you're right
FollowupID: 655128
Follow Up By: Tenpounder (SA) - Sunday, Oct 18, 2009 at 20:31
That's exactly my point, Bonz. My understanding is that you can't assume 100% of the nominal capacity of a battery is actually available. The experts can explain the science, but my understanding is that, if you try to run batteries down to zero (like 100 hrs at 1 amp out of a 100 AH battery), you'll end up with (a) a surprising lack of power, like warm frozen food, and (b) stuffed batteries.
FollowupID: 655135
Follow Up By: Bonz (Vic) - Sunday, Oct 18, 2009 at 20:33
I reckon its more like a SWL rating. The battery will actually deliver more than the 100AH but is rated such that it will deliver that much and then further drain will deteriorate the battery and eventually kill it prematurely.
FollowupID: 655136
Follow Up By: Bonz (Vic) - Sunday, Oct 18, 2009 at 20:34
That would also explain why the maths didnt work out
FollowupID: 655137
Follow Up By: Tenpounder (SA) - Sunday, Oct 18, 2009 at 20:41
Bonz. I'm an economist: the maths ALWAYS works out, as long as you spend enough time fudging the figures.
PS I've just bought 2 new Deep cycle batteries. No, don't ask!
FollowupID: 655139
Follow Up By: Bonz (Vic) - Sunday, Oct 18, 2009 at 20:57
I have an electrical background, the variables are huge. e.g. 25 amps discharge would yield a lower AH rate than a 5 amp discharge.
And the rating system appears to be based around a number of different methods
FollowupID: 655151
Follow Up By: Bonz (Vic) - Sunday, Oct 18, 2009 at 21:08
This is a good read.
Start reading from page 20
At 25 amps the rating decreases to 67% or its 5 amp rating
FollowupID: 655159
Follow Up By: Bonz (Vic) - Sunday, Oct 18, 2009 at 21:17
A bit more info I found:
RC=Reserve Capacity at 80? (27?)The reserve capacity is the time in minutes that a new, fully charged battery can be continuously discharged at 25 amperes and maintains at least 1.75 volts per cell (10.5 volts for a 12-volt battery).
Minutes discharged at 50, 25, 15, 8, and 5 AmperesMinutes discharged is the time in minutes that a new, fully charged battery will deliver at various currents and maintains at least 1.75 volts per cell. These are nominal or average ratings.
Ampere Hour Capacity at 20, 10, 5, 3 and 1 Hour RatesAmpere hour capacity is a unit of measure that is calculated by multiplying the current in amperes by the time in hours of discharge to 1.75 volts per cell. These are nominal or average ratings.
Examples
5 amperes for 20 hours (5×20) = 100 AH @ the 20-hour rate
10 amperes for 3 hours (10×3) = 30 AH @ the 3-hour rate
20 amperes for 1 hours (20×1) = 20 AH @ the 1-hour rate
Therefore, if you have am application that requires a draw of 15 amperes for 5 hours, you would need a 75 AH battery (@ the 5-hour rate).
Examples 5 amperes for 20 hours (5×20) = 100 AH @ the 20-hour rate
FollowupID: 655162
Follow Up By: Member No 1- Monday, Oct 19, 2009 at 08:21
I just use a honda EU20
FollowupID: 655240
Follow Up By: Maîneÿ . . .- Monday, Oct 19, 2009 at 09:44
But...
* Have to constantly buy fuel for generator
* Have to carry & store the generator & the fuel
* Have to be there to monitor the battery performance
* Generator will not automatically start-up when your away fishing
* If your parked in a National Park you can't use the generator anyway
* If your parked in a shopping centre car-park you can't set-up the generator
* Batteries run down faster and much lower with a generator than with more efficient methods
Nudie,
Please forgive me, sorry I could not resist :-)
Maîneÿ . . .
FollowupID: 655253
Follow Up By: Member No 1- Monday, Oct 19, 2009 at 17:05
point 3.....i dont monitor nothin...the ctek does that
point 4...i make sure i have enough petrol in it to keep it going most of the day charging batteries and keeping the fridge cold....the only thing i do monitor
point 5...the only time i go to a national park these days is on feral pest culls...and we can atke anything we like
point 6...why would i camp at marion shopping centre or cassurinna for that matter
point 7...cant be true
poit 1 & 2 iiithink of something a bit later......
FollowupID: 655317
Follow Up By: Maîneÿ . . .- Monday, Oct 19, 2009 at 18:05
"i dont monitor nothin...the ctek does that"
. . . So obviously the generator is left running :-)
using fuel, making some noise and creating dangerous gasses too, while the Ctek is putting NO charge into the battery because it's full while your not there to monitor it ?
"i make sure i have enough petrol in it to keep it going most of the day charging batteries and keeping the fridge cold....the only thing i do monitor"
. . . See reply above :-)
"the only time i go to a national park these days is on feral pest culls and we can atke anything we like"
. . . Not in WA and NT
"why would i camp at marion shopping centre or cassurinna for that matter"
. . . True, why would you even want to go there in the first place ??
"cant be true"
. . . Yes it's absolutely positively true and it's even factual too :))
Nudie, will wait for replies to points 1 and 2 with some anticipation ha ha
you say you "have enough petrol in it to keep it going most of the day" you would use a lot of fuel (lots $$$) on a holiday of a month duration when bush camping.
However with a more efficient power supply systems that will cost the same or even less than a Honda EU20 initially and with no ongoing fuel or maintenance costs either you must save money and hassles too :-)
( yes, I realise all above is mentioned in good spirit )
Maîneÿ . . .
FollowupID: 655329
Follow Up By: Member - Mike DID - Monday, Oct 19, 2009 at 20:17
"I reckon its more like a SWL rating. The battery will actually deliver more than the 100AH but is rated such that it will deliver that much and then further drain will deteriorate the battery and eventually kill it prematurely."
- that's DEFINITELY not the way batteries are rated.
The amphours is the ABSOLUTE maximum you can get out of it. 50% is a SWL which will give a long battery life.
FollowupID: 655358
Follow Up By: Bonz (Vic) - Monday, Oct 19, 2009 at 21:28
Mike, you're right I read up on it. The amphour rating is what the battery will deliver until it hits 10.5v and is basically dead.
Mainey - re the following (point 7)
What do you mean? That a battery will run down faster if charged by a generator than if charged by solar or mains power? That cant be right surely.
FollowupID: 655379
Follow Up By: Maîneÿ . . .- Monday, Oct 19, 2009 at 22:40
Bonz, Yes " Batteries run down faster and much lower with a generator than with more efficient methods " it is correct
Maîneÿ . . .
FollowupID: 655399
Follow Up By: Bonz (Vic) - Monday, Oct 19, 2009 at 22:43
How can that be? What do you mean? That a battery will run down faster if charged by a generator than if charged by solar or mains power? That cant be right surely.
FollowupID: 655401
Follow Up By: Bonz (Vic) - Monday, Oct 19, 2009 at 22:45
Surely Mainey the discharge rate is separate from the charging method. No electrical theory I have ever learned tells me any different.
FollowupID: 655403
Follow Up By: Maîneÿ . . .- Tuesday, Oct 20, 2009 at 00:16
Bonz,
A SÖLAR system will charge an Auxiliary battery system, and will also continue to power all the 12v accessories during the day, which is the high drain and heavy battery use time anyway.
This will ensure the Auxiliary battery system remains FULLY CHARGED at the end of each day, the Auxiliary battery system will then only have to power the 12v accessories during the night.
SÖLAR will start recharging the batteries again early next morning and again will run all the appliances during the day.
* This is a very boring & repetitive procedure that will occur daily
* Fortunately you won’t even have to be there to supervise it :-))
* A correctly specified SÖLAR system will power your 12v accessories and also charge the Auxiliary battery system.
* During the day, the 12v accessories are NØT drawing any 12v power from the Auxiliary battery system
* Only during the night, is the 12v Auxiliary battery system powering the 12v accessories
* The Aux battery system probably will not get below 12v in any 24 hour period, mine doesn't and it runs a fridge drawing 10 Amps, plus lighting etc.
A generator must be actually running to charge the aux battery system.
Most people run their generator from late afternoon to recharge their aux battery system that has been running the fridge during the day and also the previous night.
The battery has been drained all day in this situation which is the heavy draw time, the Aux battery will have drained down to <12v.
If your not there to "turn on" the generator and the battery runs down even lower it can and it will damage the battery.
That's just another reason so many Aux batteries last so long when charged by solar power.
Maîneÿ . . .
FollowupID: 655414
Follow Up By: Member No 1- Tuesday, Oct 20, 2009 at 07:36
hey Smarty pants!
A generator and CTEK will charge an Auxiliary battery system, and will also continue to power all the 12v accessories during the day, which is the high drain and heavy battery use time anyway.
A generator will also start recharging the batteries again early next morning and again will run all the appliances during the day.
* Fortunately I will be there to start it cos I need lots of beauty sleep, breakfast and I am the supervisor!
...I was thinking of investing in a solar system when i get the $$$$... just need to figure out how to claim it as a business expense...:))))
FollowupID: 655423
Follow Up By: Maîneÿ . . .- Tuesday, Oct 20, 2009 at 09:49
Richard well said, Just put it down as your prefered power source when working in remote areas like the local jetty.
I'm sure Honda and Ctek will cost more than a solar system of same output :-)
Maîneÿ . . .
FollowupID: 655444
Follow Up By: Thylacine - Tuesday, Oct 20, 2009 at 11:44
Ahhh Mainey, never one to let facts confuse one of your 'theories'.
I can't believe that you haven't picked up at least some 12VDC knowledge in the last few years.
ed
FollowupID: 655458
Follow Up By: Maîneÿ . . .- Tuesday, Oct 20, 2009 at 14:10
Thylacine
( umm, extinct ? )
Please state exactly what you believe is incorrect
then state what you believe is the correct answer :-)
Maîneÿ . . .
FollowupID: 655484
Follow Up By: Thylacine - Tuesday, Oct 20, 2009 at 14:36
I think the last time we communicated I explained how difficult/frustrating/seemingly pointless it was trying to educate you, and recommended some literature to do the job (the prescribed textbook for electrical trades in VIC at the time).
You've obviously not gone near this, so explain again why my job is to teach you?
This forum is (and has been for years) rife with misinformation in regards to 12VDC systems. Many have tried to rectify this only to all end leaving in discust at the end of it all. I *very* rarely post here for just such reason. Over the five plus years I've perused this forum I've seen many posts recommending circuits that are absolute fire-hazards, yet if said circuit is posted by a 'regular' the knowledge-level of anyone pointing out the danger involved is ignored and the poor fool abused.
I cannot understand why self-taught blokes with a basic understanding of Ohm's law will dispute an expert. "You're wrong" they'll cry, yet offer no factual information to back this up. If you explain why it is so they'll often dispute the explanation due to lack of understanding.
Personally, I don't offer advice on any subject unless I have a *thorough* understanding of it. It's easy to bandy around a few electrical terms and convince a novice that you know what you're on about. But it's neither ethical or in the interest of the forum.
ed
FollowupID: 655488
Follow Up By: Maîneÿ . . .- Tuesday, Oct 20, 2009 at 16:47
Thylacine,
Why not just answer the question I've asked of you ?
If you believe anything above is wrong, why not dissect it bit by bit and explain why you believe it is wrong, don't denigrate this forum just to cover your lack of ability to show the facts are indeed facts
Maîneÿ . . .
FollowupID: 655504
Reply By: Bob of KAOS - Sunday, Oct 18, 2009 at 19:53
I'd lose the 1.5w globes and get 80 mA LEDs.
An 80 W solar panel would cost $500 (I just paid this much), and probably give you enough power to make the system last indefinitely.
AnswerID: 387612
Follow Up By: Haza - Monday, Oct 19, 2009 at 00:28
At $500 I'd add the solar panels aswell, did this include a regulator?' look for one that does a float charge if your going to have it permently attached.
The life time of panels are up to 10-20 years. This would allow you to keep your battries in optium conditon,
As others have mentioned as it gets a warmer ambient temperture the draw will be more,on your test did you have anything in the fridge.
Nothing worse then been out there and not having the fridge and lights working. I have ruined a battery by running it too flat and it was a huge pain as the battery then only ran half a day after a charge. Was another 4 days camping before I got a new one.
My 50L fridge lasted 3 day in a melbourne winter but get 1.5 in North Oz, Now I use a 100W solar panel and camp as long as the food and drink lasts.
FollowupID: 655227
Reply By: Member - Oldplodder (QLD) - Sunday, Oct 18, 2009 at 20:56
Wonder how long the batteries would last if the temps went up by 5 dwg or 10 deg?
For 5 deg, subtract 25%, add 10 deg (18 to 28) and half battery life (50% less) with more draw from the fridge?
AnswerID: 387628
Follow Up By: Member - John (Vic) - Sunday, Oct 18, 2009 at 21:29
Then open and close the fridge a few times and see the results.
FollowupID: 655164
Reply By: Crackles - Monday, Oct 19, 2009 at 17:15
6 days down to 11.9 volts is a great run but those thinking this system may suit them need to remember it's only an 18 litre fridge not being open & closed or refilled with warm drinks, nor was it very hot. Would expect on warmer days opening the fridge occationaly, the run time may be reduced by more than half. Let us know Doug how it performs in the real world over summer.
Cheers Craig.............
AnswerID: 387756
Reply By: Member - Robert R1 (SA) - Monday, Oct 19, 2009 at 23:16
I just checked through my records and with my cf50 waeco set to 0 deg C I used about 10 - 15 Ah a day in similar conditions to yours. When the temp gets around 25 - 30 deg C during the day, 30 - 40 Ah is more common. With Darwin type weather (30 deg in the day and 16 deg at night) it can get up to 60 - 65 Ah a day. Continually flattening your batteries will kill them within 12 months or less so you have to factor in this cost.
I think you need some method of charging them on site. I prefer solar which is expensive to set up but cheap over a long period of time and you aren't continually worrying about your batteries going flat and your food going off. I have seen so many couples arguing about this. They have just bought heaps of meat and two or three days into their holiday, the fridge has stopped. It ruins the holiday.
Regards,
And he sees the vision splendid of the sunlit plains extended, And at night the wondrous glory of the everlasting stars. Clancy of the Overflow.
AnswerID: 387823
Reply By: skulldug - Tuesday, Oct 20, 2009 at 17:55
Thanks to all for the informative comments as well as the debate. I will certainly post again when I have had an opportunity to get outdoors in the heat.
Doug
AnswerID: 387923
