Tuesday, Oct 20, 2009 at 18:32
"Do I have to think about rewiring the
battery setup to accommodate a regulator or is it as simple as a charger"
It's as simple as a charger.
"* . . Simple, just an input from panel and an output to
battery
Run your
accessories direct from the solar regulator - not
battery. "
Running from the regulator is only necessary if the regulator has "state of charge indication" that you want to use, or if you want to use the regulator to control the discharge of the
battery and switch things off when the
battery is low. Assume you've been doing without that functionality so it's up to you if you need the complexity.
Why do you need a secure plug ?? is it no good if the plug got accidentally knocked out ??
Won't charge will it. :-)
655522
