Recommended caravan hire from Perth
Submitted: Monday, Oct 19, 2009 at 11:36
wantingtogetaway
My wife and i are planning a trip with our 2 boys (under 2) from
perth to
esperance via coast and some inland roads. We are looking for any recommendations for hire companies that have given great customer satifaction. We will be looking at hiring from
Perth area.
Reply By: disco driver - Monday, Oct 19, 2009 at 14:43
Hi, there are a number of hire
places listed in white pages with vans/campers which may suit your needs. Customer satisfaction I cannot vouch for.
Before you hire any 'van, you will need to know a few things about your tow vehicle so that the hire company can ensure that your outfit remains legal.
You will need to know the following:-
1. Your vehicles towing capacity, this can be limited by the towbar fitted. You may need to upgrade the tow hitch to suit the van.
2. Your vehicles total allowed weight/mass, ie the total weight/mass of the fully loaded car plus the weight of the passengers plus the towball weight of the loaded caravan.
3. The total weight/mass of the loaded caravan, including
water food and personal effects and clothing.
4. The caravan's towball weight. This is that part of the weight of the van supported by the tow hitch .
Most standard cars (Holden Falcon) and smaller 4wd's have normal tow capacities in the order of 1200-2000kg using the correct towbar assembly .
Large 4wd's eg Landcruiser, Nissan patrol and Landrover usually are able to tow 2500-3500kg depending on transmission options and usually have much higher allowable towbar weights.
I hope this helps in setting up a safe towing caravan for you.
If you know all this already, this post can be ignored.
Disco.
387733
Follow Up By: disco driver - Monday, Oct 19, 2009 at 14:45
Sorry
Should be "Yellow Pages", not white pages.
Disco.
655294
Reply By: wantingtogetaway - Tuesday, Oct 20, 2009 at 09:48
Thanks Disco, first time towing a van so that is all good info. Now i jst have to narrow down the long list of hire companies.
387858
