Will a Nuvi 765 navigate to a waypoint ?
Submitted: Monday, Oct 19, 2009 at 23:07
Bonz (Vic)
Looking at a Garmin Nuvi 765 and wonder if to would be any good for Geocaching? Does it have a capacity to input waypoint coordinates and navigate offroad to that point? Or is it little more than a glorified Melways with bluetooth?
Reply By: Member - Peter H (WA) - Monday, Oct 19, 2009 at 23:56
Hey Bonz
It should do what you want. I have the 760 and it does it.
387825
Reply By: Member - Stephen L (Clare SA) - Tuesday, Oct 20, 2009 at 08:13
Hi Bonz
You will find that all that you will have to do is add the latitude and longitude and then use that as a go to destination and it will take you to that location.
387848
Follow Up By: KennyBWilson - Tuesday, Oct 20, 2009 at 13:32
And once your near GZ have it in Off Road mode,
655476
Reply By: Member - Doug T (NT) - Tuesday, Oct 20, 2009 at 09:04
Bonz
As the others have told you, but if your using it as a hand held the battery don't seem to last , you could connect it to one of those little 12v Motorcycle batteries stuffed in a carry bag, I used
mine to mark many concrete floor bases while walking around some WW2 sites and it started to run out of power, they really meant for in vehicle use, if your going to use a GPS in the field then the best unit would BE a Garmin MAP60Cx, To do what I want I got the basic MAP60 .
Garmin MAP60Cx
387853
Reply By: Member -Signman - Tuesday, Oct 20, 2009 at 09:48
Any GPS should do that..even the l'il cheapy eTrex..
Just enter your lat and long...hit the GOTO button...
387859
Reply By: Member - Sigmund (VIC) - Tuesday, Oct 20, 2009 at 19:15
There's an external battery available in the US for the 760.
387937
Reply By: AdrianLR (VIC) - Wednesday, Oct 21, 2009 at 09:26
Hi Bonz
I have a 760 (which is fantastic, particularly with Shonkymaps loaded) BUT this is the one function that I haven't been able to master and perhaps Doug or others can clarify.
As an example, a couple of weeks ago I was trying to navigate to a lat/long position near
Andamooka where the
dingo fence meets the Borefield Road. I suspect that because I was using Shonky which is a non-routable mapset (and you need to untick City Navigator to allow Shonky to show up) if I put in the POI/Favorite I created as the place to goto an error message would come up to say that a route could not be created and the system just reverted to the map screen.
If I do this on my old Magellan 315 then it shows me the direction and distance to the POI. I simply cannot find a way to make the 760 do this. I would be surprised if the 765 was different.
Regards,
Adrian
388008
Reply By: get outmore - Wednesday, Oct 21, 2009 at 13:14
I used my Garmin 250 for that sort of purpose and it didnt seem to work
well. might have been the heavy trees but it seemed to update my position quite infrequntly compared to my garmin etrex which registers even small movements
other thing is my 250 doesnt give you the choice of different coords
- it wont do UTM for example
388048
