80l waeco problems and fixes
Submitted: Tuesday, Oct 20, 2009 at 13:02
ThreadID: 73160 Views:3046 Replies:6 FollowUps:0
goodday all
well after 7 yrs we have had to spend some money on our 80l weaco i had to replace the fan ($28)after it got very rattly (new fan seems great used a computor fan and it seems to draw more air)
the other problem i have and cant seem to overcome is the 240v /24v/12v transformer changeover unit I replaced it earlier this year as appeared to be playing up but what I am now finding is it will run on the car battery for a little while and then go into stupid mode .The red light starts blinking and motor runs continuos
I started checking with the multimeter as i thopught the battery was stuffed again BUT i had 12.6v coming in and that was fine for a couple of minuts then into stupid mode so recheck voltage 12.6 in still but only 10.5 coming out of transformer so will be a phone call to waeco and try and get it changed somewhere as we purchased in melb but wont be back there for while
steve
Reply By: Mogul - Tuesday, Oct 20, 2009 at 13:05
Sounds like the poly fuse needs replacing.
AnswerID: 387880
Reply By: Peter McG (Member, Melbourne) - Tuesday, Oct 20, 2009 at 13:46
My experience with two Waecos recently has been that the only way to fix them is to replace the control module - cost around $280.
AnswerID: 387883
Reply By: Member - Pesty (SA) - Tuesday, Oct 20, 2009 at 14:15
Gday Steve,
ONLY way to fix this problem with any fridge, with external 240 power supply is to ditch it.
FIX ;
Hard wire fridge into car with good size wire, go buy a 25amp ctek battery charger, hard wire that in too, so when you pull up and plug in, your fridge runs on 12v as always, but you get your battery,s charged as well as supply all your 12v needs.
Doesnt matter then if you have driven 10 k or a 1000 k for the day.
Best move i ever made. Handy for top up too when camped if you need to run a genny on occasions too.
The stupid red light only comes on when there is a power problem, as it is, and is correct 99.9% of the time.
Pesty
AnswerID: 387886
Reply By: dbish - Tuesday, Oct 20, 2009 at 15:11
Steve hi , on my waeco flashing led is a code & thereis 5 different codes. You count the flashes.
AnswerID: 387893
Reply By: snoopy2 - Tuesday, Oct 20, 2009 at 16:53
Hi Steve,
The Waeco error codes are as follows:
Error Flashes per 5 seconds
1 = Low Voltage
2 = Fan Overlaoding
3 = Motor Start (Turn off for 10 minutes)
4 = Low Motor peed
5 = Blocked Ventilation
Hope this helps, Michael
AnswerID: 387906
Reply By: Member - Matt & Julie (VIC) - Tuesday, Oct 20, 2009 at 20:00
Hi Steve
we spoke about this at St George.
what I use is the waeco coolpower ESP 35 power supply have a look at one I have had no problems since I got one .
Matt & Julie
AnswerID: 387944
