Tyre Pressure Monitors
Submitted: Wednesday, Oct 21, 2009 at 13:42
Member - steveinoz (NSW)
Hi to those that responded to my enquiry. Firstly I must apologise if I have upset a few members that responded and thank those members that have put me on the right track, Thanx.
I will humbly crawl back up into the hole and through out a few enquiries through the WEB. First stop will be ABR Sidewinder. I looked up Davies Craig and there site said NO STOCK.
Thanks for the help given and I stand repremanded. Steve. B...
Reply By: Tenpounder (SA) - Wednesday, Oct 21, 2009 at 18:27
Hi. I don't think you said anything offensive to anyone, Steve. I grappled witht ehdecision, and chose Tyredog, an then had a problem. But, thankfully, they replaced the whole rig no questions even though only one wheel sender had failed. Since then , 100% OK so I'm happy (and the Tyredog saved me a tyre on the first major trip as
well!).
As usual there are no right answers, and, heh, you gotta ask!
388084
Reply By: Member - Warwick D (SA) - Wednesday, Oct 21, 2009 at 18:46
I have Tyre Dogs. Never again. I am looking for something to replace them with. COncept excellent. Manufacture and application very poor, it became another chore, instead of an aid. WD
388093
Reply By: acdc - Sunday, Oct 25, 2009 at 20:55
Be careful, none of the screw on cap style meet safety standards.
388689
Follow Up By: Member - Graham H (QLD) - Monday, Oct 26, 2009 at 01:07
Please Explain
656416
Follow Up By: acdc - Monday, Oct 26, 2009 at 18:48
hi graham,
when you screw the cap on, it holds the shrader valve open to monitor pressure, so the only thing holding the pressure in, is the cap, a big no no.
656516
Follow Up By: Member - Graham H (QLD) - Monday, Oct 26, 2009 at 21:01
True but if they come loose or fly off the valve will close so dont see the problem.
Mine have not lost pressure ever due to this reason.
656557
Follow Up By: acdc - Monday, Oct 26, 2009 at 21:09
you are relying on the pressure membrane to hold the air in, if it fails your tyre go's flat without warning, as the sensor no longer functions.
656561
Follow Up By: Member - Graham H (QLD) - Monday, Oct 26, 2009 at 21:36
Well done 28,000 so maybe they due to go.
One has died due to vibration but hasnt dropped pressure.
Will keep an eye on them.
656570
