Where can I get blanking grommets?
Submitted: Thursday, Oct 22, 2009 at 09:47
Member - Boo Boo (NSW)
I have tried to get them from just about every place in
Dalby but cannot find 4mm b/grommets.
I have looked on the internet, but cannot find the elusive 4mm size.
The holes were made with a #20 rivet drill bit.
Does anyone know where I can buy and get them delivered by post?
I am going into
Toowoomba this weekend and will have a look around., but won't hold my breath
Reply By: Member - Fred B (NT) - Thursday, Oct 22, 2009 at 09:54
try Repco or Jaycar.... if you have those stores near you.
regards
388181
Follow Up By: Member - Boo Boo (NSW) - Thursday, Oct 22, 2009 at 10:00
Fred I have tried Repco, they don't go down that small.
Jacycar does not live up here.
655767
Follow Up By: Member - Fred B (NT) - Thursday, Oct 22, 2009 at 10:27
Try Jaycar online jaycar.com.au or phone 1800 022 888 I have found them very helpful.
655775
Reply By: Member - ross m (WA) - Thursday, Oct 22, 2009 at 09:55
You probably need to find a good parts ship in the city.My
shop in
Perth has plastic
orange boxes with all sorts of wonderful widgets(and grommets)
If you can find a vehicle that already has them,then you could try the dealer
388182
Reply By: wicket - Thursday, Oct 22, 2009 at 09:57
Reply By: al - Thursday, Oct 22, 2009 at 10:07
might sound silly but if you can get a slightly bigger grommet why don't you drill a hole to match.
al
388187
Follow Up By: Member - Boo Boo (NSW) - Thursday, Oct 22, 2009 at 10:13
Al
Your not as silly as you look. LOL
I have got grommets to fit a 5/16" hole. the holes are high up on the side of the camper trailer and will not cause a problem if I drill out to 5/16".
Good thinking 99.
655771
Reply By: Member - mazcan - Thursday, Oct 22, 2009 at 13:45
hi clark rubber stores usually have a large range of grommetsand all sort of other seal forms etc
388212
Reply By: Member - Lance S (VIC) - Thursday, Oct 22, 2009 at 15:43
Boo Boo,
Try Bursons, if they haven't got one small enough individually they will nick one out of a champion pack or they can order in a blister pack of the size you are after.
cheers,
Lance
388220
Reply By: Member - Doug T (NT) - Thursday, Oct 22, 2009 at 16:49
Supercheap Auto is where I get them ,
388227
Reply By: Member - Doug T (NT) - Thursday, Oct 22, 2009 at 17:03
Supecheap
Dalby
127 Cunningham Street
Dalby Phone (07) 4662 2933
388229
Follow Up By: Member - Stuart P (WA) - Thursday, Oct 22, 2009 at 20:38
is the no 20 drill 3mm?
655870
Reply By: Member - Boo Boo (NSW) - Thursday, Oct 22, 2009 at 20:47
Bugger, I forgot about super cheap here in
Dalby.
Thanks for all the advice, in the end I drilled the holes out to 5/16" and fitted what I had.
388265
Reply By: Member - Phil G (SA) - Thursday, Oct 22, 2009 at 20:59
Booboo,
I know you've got it fixed, but the other option I use with stray holes is simply block them up with a rivet.
388270
Follow Up By: Member - Allan B (QLD) - Thursday, Oct 22, 2009 at 22:14
Or a little dob of silastic.
655901
