1hz 70 fuel pump
Submitted: Thursday, Oct 22, 2009 at 23:00
john57
Hi does anyone have a exploded view of a
fuel pump, I have a leak somewhere and can't find it. was quoted $$$$$ for fixing it and thought I would look and see if I can do it.
cheers John
Reply By: Member - Donks1 (NSW) - Friday, Oct 23, 2009 at 07:20
[/img]
See if this works
Donks1
388316
Follow Up By: Member - Donks1 (NSW) - Friday, Oct 23, 2009 at 09:19
You can also try this link
Fuel pump
655965
Reply By: Member - ross m (WA) - Friday, Oct 23, 2009 at 09:34
Reply By: donk - Friday, Oct 23, 2009 at 10:30
Normally to fix the most common pump leak on a Toyota ve pump you need to replace the top cover oring (22774 on the picture above) & the throttle shaft oring (22740A)
What year is yours ?
Regards Don
388341
Reply By: dbish - Friday, Oct 23, 2009 at 11:04
A little tip John, when i dismantle something like that I use a digital camera & take photos as I dismantle the part & load them into the computer. Its easier to refer back to if you arent sure how something is assembled & your photos will be beter quality than wots in the manual cheers Daryl.
388348
Reply By: slammin - Friday, Oct 23, 2009 at 12:17
I was taught that diesel
fuel pump tolerances are so miniscule without the right toolshop it is not serviceable. I'm yet to see any mechanic who will work on one. They all send it away to professional shops for a reason.
Here's this
manual
388361
Follow Up By: Member - Stuart P (WA) - Friday, Oct 23, 2009 at 22:51
you will also need a $100000 test bench to test it
656096
Reply By: obee1212 - Friday, Oct 23, 2009 at 23:07
I gave my old 2wd hilux 1985 to a mechanic to fix and he passed it to a learner who bent something because he put it back together wrong. It was just an O ring but it seems a bit of care is needed at least in my case. I ended up buying a complete wreck and changed the motor and everything for less than the cost of a reconditioned pump.
I reckon now the whole effort was not worth saving the vehicle.
Owen
388464
