Ernest Giles road
Submitted: Friday, Oct 23, 2009 at 07:39
ThreadID: 73239 Views:2748 Replies:6 FollowUps:0
is the Ernest Giles road between the Stuart Hwy and Luritja road usable with a normal caravan tanks you
Reply By: jdwynn (Adelaide) - Friday, Oct 23, 2009 at 07:45
NO!!
However, we were travelling west from where the Boggy Hole route hits the Ernest Giles Road. So rough my GPS (compact flash type) died. One of those roads where you try to get your speed up to limit the affects of the corrugations, then you hit a sand drift peak (dune over road) on a bend - no wonder there have been some drama's along the road.
AnswerID: 388320
Reply By: Member - Stephen L (Clare SA) - Friday, Oct 23, 2009 at 08:05
Due to the conditions of the road, there are signs at both ends advising that the road is not suitable for caravans. The soft sand in a few sections may catch out the ill prepared.
AnswerID: 388324
Reply By: ChrisK - Friday, Oct 23, 2009 at 08:15
We went through here in August as part of the Variety Bash. It was the worst bit of road we had on the whole trip from Bendigo to Alice and they gave it to us on the last day. The corrogations are some of the worst I've seen, I wouldn't take my 4x4 on there if I had a choice.
AnswerID: 388327
Reply By: nickoff - Friday, Oct 23, 2009 at 08:47
I did it 10 years ago with a 2 x 4 Hilux dual cab & a Jayco Finch. An experience I wouldn't recommend. Did most of the road in 2nd and 3rd gear because of sand. Got the whole rig airborne over one of the cattle grids.
Took longer than taking the long way round. Used more fuel. Met some idiot in a hire car (Yes car, not 4x4) going the other way, at about 140 Kph!!!
I say, take the long way round. Easier drive. More facilities. More access to help if needed.
AnswerID: 388330
Reply By: pt_nomad - Friday, Oct 23, 2009 at 18:12
peppylepiou,
I went though in August. As the others have siad, I would not recomend it.
We travelled quite slow and it was marginally quicker than the long way round. Wit hteh right speed I would not say its a road you cant do, but I would not recomend it as it will shake the BG out our you can and its contents.
Paul.
AnswerID: 388407
Reply By: Member - Mal and Di (SA) - Friday, Oct 23, 2009 at 22:40
We went that way about 10 years ago and said at the time I had been on rougher roads but couldn't remember when. Since then I have been on the Cape Levique road! Enough said.
AnswerID: 388458
