Igntion Timing 2.6 Petrol Rodeo
Submitted: Saturday, Oct 24, 2009 at 19:16
oldpop
Hi Guys
Bit ot Mate has a 2.6 petrol 1989 rodeo want to reset timing after engine swap
can any one help I think I have to short wires to distributor to set base timing
any help would be appreciated
Oldpop
Reply By: Member - Lionel A (WA) - Saturday, Oct 24, 2009 at 21:21
Hi Op, not sure exactly what your asking or about shorting wires.
Just assuming your timing from scratch:
Remove spark plugs.
Rotate engine manualy until the timing mark on the crankshaft pulley corresponds to the mark on the block. [ maybe 5-8 degrees before]
Poke a length of wire down No 1 plug hole to ensure your at TDC.
Lift the dizzy cap and ensure the rotor is pointing to No1 lead.
Pop the plugs back.
This will be timed within cooey and once running you can then re-time by small adjustments to the dizzy, or better still, use a timing light.
This system has never failed me no matter what engine I have worked on.
Cheers....Lionel.
388553
Follow Up By: oldpop - Saturday, Oct 24, 2009 at 21:25
Lionel
Thanks for the reply
from what I understand the ecu controls the timing need to short out two wires to be able to set base timing
need to know what wires and base timing
regards
Oldpop
656195
Follow Up By: Member - Lionel A (WA) - Saturday, Oct 24, 2009 at 21:51
Ah !!! OK, now your've got me.
Im a bit of a dinosaur, that dang-fangled electronic stuff has me buggered.
Cheers.....Lionel.
656199
Follow Up By: dbish - Saturday, Oct 24, 2009 at 22:02
Hi oldpop, only have info on Mitsubishi 2.6L 4Cyl Magna. Warmup engine, switch off, Bridge dignostic conector term 10 (grey/red wire) to term 12 (black wire) gnd. Start engine & check Ign timing 13Deg BTDC @ idle. Switch off & remove bridg wire. Posibly simillar.
656203
Reply By: Member - Phil G (SA) - Sunday, Oct 25, 2009 at 00:02
Oldpop,
Heres a link from a Gemini
forum that may help. The Gemini people like to fit the 4ze1 Rodeo 2.6 motors!
Rodeo ignition timing.
388567
