Eva Kool Fridge Slide
Submitted: Saturday, Oct 24, 2009 at 20:01
Hools
I would like to know if anyone has a solution for a robust fridge slide for a 85 Litre EvaKool Fridge to fit into
the tub of a Nissan D40. I have one currently but it does not allow the fridge to slide out far enough so that the lid can be lifted up completely as it is restricted by the canopy top.
Reply By: Member - gujimbo - Saturday, Oct 24, 2009 at 20:38
Make your own, this is what i did with our Evacool 65 fridge/freezer, have a look at my profile for the fridge slide table that i built it uses 2 heavy duty slides that lock when in the in position and also when pulled out fully, the slide table also has a small work table that pulls out from below the fridge slide.
388543
Follow Up By: Member - Timbo - Monday, Oct 26, 2009 at 13:56
looks good gujimbo - do you mind telling us where you got the slides, what brand/model they are etc.?
656467
Follow Up By: Member - gujimbo - Monday, Oct 26, 2009 at 17:12
The slides are made by
ACCURIDE DRAWER SLIDES , they have a local distributor details of which are
WILSON & BRADLEY, they are a very good slide which have worked perfectly for me for the last 4 years.
Cheers Jim
656498
Follow Up By: Member - gujimbo - Monday, Oct 26, 2009 at 17:20
Try these for thje web links
ACCURIDE and
WILSON BRADLEY, i've posted some more pics on my rig page with some detail of the fridge slide.
656499
Follow Up By: Member - Timbo - Friday, Oct 30, 2009 at 15:10
Thanks Jim, that was the sort of info I was looking for. Do you know what specific model you used though? I had a look through and couldn't find any that lock into both the open and closed positions (maybe that particular one is discontinued?) - that could be a handy feature, just in case you end up parked in the occasional place that isn't absolutely level! :)
657143
Follow Up By: Member - gujimbo - Saturday, Oct 31, 2009 at 20:16
Accuride Model 9301 for the non locking slides and model 9328 for the lock in-lock out model.
Concept Latch in
Melbourne sell Accuride slides.
657273
Follow Up By: Member - Timbo - Monday, Nov 02, 2009 at 15:52
Thanks again Jimbo, much appreciated - I'll look them up.
657455
Reply By: Member - Phil G (SA) - Saturday, Oct 24, 2009 at 23:24
If you're interested in a simple custom DIY slide:
You can buy a set of the 1000mm long 100kg slides for about $100. They are a single extension slide that will open to 835mm. Weld whatever length of angle iron across each end and you'll have a custom fridge slide. I did this for a storage system I made a few months back.
1000mm long 100kg fridge slides
388564
Follow Up By: Member - Phil G (SA) - Saturday, Oct 24, 2009 at 23:38
I'm also assuming that the fridge slide is mounted at floor level in
the tub and if you make the above, you'll need to have the compressor facing inwards (like an engel). As the fridge is 880mm long, you should still have enough space to access the controls at the back when the fridge is pulled out. Also you'll need a spring pin or patio door bolt as a lock.
656214
Follow Up By: River Swaggie - Sunday, Oct 25, 2009 at 02:36
Hiya Phil
Thats how i hav
mine on a Evakool slide...He could go the fold down Platinum One would be a goer too..
656226
Follow Up By: Hools - Wednesday, Oct 28, 2009 at 18:30
River Swaggie when you mentioned the Platinum One what were you referring to please. Is that a specific Evakool fridge slide?
656839
Follow Up By: River Swaggie - Wednesday, Oct 28, 2009 at 21:31
Hiya Hools
No its a dropdown slide,Expensive but great idea..
The Drop Slide
656871
Follow Up By: Member - Timbo - Friday, Oct 30, 2009 at 15:12
How much are the Drop Slides? I had a look on the website but they don't seem to want to tell you the price, even though they'll happily accept an order!
657144
