Reverse your tongue
Submitted: Sunday, Oct 25, 2009 at 12:13
Member - Malcolm (Townsville)
Well that's good advice for some people BUT what I am REALLY talking about here is the tow-bar tongue. You know that thing you hook your caravan/trailer etc to.
Apologies to fellow members that already know this stuff. There are a always newcomers that need to learn - this is for them.
PROBLEM
Backed up new car to KK and hooked up trailer .....
Image Could Not Be Found
Then I wound the trailer leg up as far as it would go BUMMER would not go far enough.
SOLUTION
Reversed the tongue on the tow-bar .....
PROBLEM SOLVED and the camper is much more level.
HTH
Malcolm
Reply By: Maîneÿ . . .- Sunday, Oct 25, 2009 at 12:45
Malcolm,
Do you know what your "quick connect" shackles are rated at ??
With the tongue facing down, do you believe the bolt could be hanging down just a bit too low ??
At least it will protect the power cables a bit more.
Maîneÿ . . .
388609
Reply By: DIO - Sunday, Oct 25, 2009 at 12:46
Great suggestion. Might pay for you to check the length of your chains as it's doubtful they would keep the drawbar off the ground (as required by law) in the event the coupling failed. Might also pay to check the capacity of your shackle (not spring clip - they are not classified to acceptable standards) in order to ascertain their legallity. Check the accompanying link for some comprehensive information regarding
388611
Follow Up By: DIO - Sunday, Oct 25, 2009 at 12:47
Sorry for double posting, glitches and bugs obviously 'at play'.
656264
Follow Up By: Member - Malcolm (Townsville) - Sunday, Oct 25, 2009 at 13:00
DIO and Mainey
The quick release shackles were with the KK when I bought it (from 'teabag' I'm sure you know who he is - it featured in 4WD Action). I have no idea what they are rated at but will check them.
I may just go back to the new shackles that came with the TB and then I can shorten the links.
I'll do that now and post a piccy ....
Malcolm
656266
Follow Up By: Member - Malcolm (Townsville) - Sunday, Oct 25, 2009 at 13:16
I'm back .....
The quick release coupling is rated at max 12kN (whatever that means). For those that don't know what it is ....
Removed them and fitted the standard Hayman Reece shackles, shortened chains one link .....
Malcolm
656270
Follow Up By: Isuzumu - Sunday, Oct 25, 2009 at 14:16
New tug looks good
Malcolm... hows it going so far?
656278
Follow Up By: Member - Malcolm (Townsville) - Sunday, Oct 25, 2009 at 14:38
There's da good news and da bad news, whcih do you want to hear?
I'll start a new thread. OT here .....
Malcolm
656279
Follow Up By: Isuzumu - Sunday, Oct 25, 2009 at 15:16
Maybe an MM might be better
656289
Follow Up By: Member - Malcolm (Townsville) - Sunday, Oct 25, 2009 at 15:41
Thread 73292 for follow up for those interested.
656294
Follow Up By: gbdid - Sunday, Oct 25, 2009 at 15:58
The shackles that were supplied with my HR towbar did not have a rating. So I have chucked them and only use rated shackles that were supplied by my trailer maker. Have rated chains too.
I also cross the chains over the towbar hitch .
656302
Reply By: Member - Graham H (QLD) - Sunday, Oct 25, 2009 at 13:10
Good idea BUT
I have seen on tongues like this a sticker that says not to do this as it imposes different stresses on the weld.
Admittedly it should be of a suitable quality but it may not be.
The chains are far too long as they must be short enough to prevent the A frame from hitting the ground if the weld breaks LOL
Snaplocks or Carabeiners unless rated are definitely illegal.
Shame to buy a new camper and perhaps lose it to techicalities.
I might be missing something but you say when the tow ball was lower the trailer wouldnt go high enough and then you make it higher and it worked ????????
388616
Follow Up By: Member - Ed. C. (QLD) - Sunday, Oct 25, 2009 at 13:14
The way I read it, he couldn't get the weight off the swing-away jockey wheel with the hitch in the low position....
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
656268
Follow Up By: Member - Malcolm (Townsville) - Sunday, Oct 25, 2009 at 13:18
wot ed says ....
656271
Follow Up By: Member - Graham H (QLD) - Sunday, Oct 25, 2009 at 13:27
Ah all in the reading I guess or the writing.
LOL
Have hung on those connectors on the side of a mountain but wouldnt like to try putting a Tonne or more of sudden load on them.
656273
Follow Up By: jdwynn (Adelaide) - Sunday, Oct 25, 2009 at 17:32
Graham is strictly correct chaps. Reason straightforward. Tongue bears on shaft the correct way around but in the way you have it
Malcolm the weld always takes the full load and some of the weld is always in tension. Now when it comes to fatigue (repetitious loading) you can’t just say “she’ll be right mate”.
It so happens I do exactly the same thing as you
Malcolm – but I have a light camper whereas the KK (and some models in particular) can be very heavy at the hitch. I think its important to recognise there is a risk. I check hitch regularly. The alternative is to buy the tongue that purpose made with the height you want (Eaz Lift make a tongue to fit every possible height).
PS, 12kN is 1223kg.
656319
Follow Up By: jdwynn (Adelaide) - Sunday, Oct 25, 2009 at 18:14
Thought it mght be worth posting this link to reversible ball mounts (see page 12). I don't know whether these are sold in Oz but still it's worth finding a mount that's purpose made for the job.
Site Link
About 2.5MB - sorry can't find a single page link.
Does anyone know where Nissan sources it's tow bar tongue from?
656336
Reply By: Member - Graham S1 (QLD) - Sunday, Oct 25, 2009 at 13:28
Malcolm
I have a KK.
i don't have the manual with me but my recollection is that
Kimberley recommend/require a minimum heigth of the hitch above ground level - hence the need to reverse the tongue
I agree with earlier comment that the quick release caribinner is not likely to be legal-its doubtful that it would be rated. was it supplied by
Kimberley or a dealer? be surprised if it was
Happy Kamping
Graham
388617
Follow Up By: Member - DickyBeach - Sunday, Oct 25, 2009 at 14:08
Malcolm (or Graham),
Would you please let me know the height of the top of the hitch when the KK is nice and level with the ground?
Many thanks,
DickyBeach
656277
Follow Up By: Member - Malcolm (Townsville) - Sunday, Oct 25, 2009 at 16:20
Hi Graham
Measured the top of the KK drawbar just in front of the wheel and it is 23".
At present, on my setup, to the top of the drawbar, above where the safety chain is welded, is 19". That's a difference of 4 inches.
When I jacked up the front of the drawbar 3" (max jack would take it without shimming it up) the back of the D-MAX looked liked one of those drag cars. I'm not sure airbags is solving THIS problem. IMHO i think I need an adjustable hitch that slips into the box channel on the HR TB. I can then adjust it up/down until the drawbar IS level. Once that is done and the vehicle loaded, any sagging of the rear end will prove if any airbags are necessary. Which I think will be, YES.
I have photos of all this if interested. Just didn't want to clog up the thread.
Malcolm
656310
Follow Up By: Member - DickyBeach - Sunday, Oct 25, 2009 at 17:46
Malcolm,
We used to own a KK and sold it only because we went to live overseas for three years and we hope to replace it say next year - iIn the meantime I'll build (get built) an off-road bush trailer a la the KK.
In the VSB1 Regulations there's a requirement that the (50mm) ball coupling should not be greater than 420mm above road level and, with the centre of my Cruiser's
wheels being 385mm, that seemed to be difficult - hence my question to you to see what the KK is.
Perhaps because a Treg hitch is not a ball coupling that restriction does not apply. (The bureaucrats at the government department have not been much help to date.)
Cheers, and enjoy the KK - we certainly did.
656323
Reply By: Bob of KAOS - Sunday, Oct 25, 2009 at 13:30
Malcolm
You seriously need some PolyAirs
388618
Follow Up By: Member - Malcolm (Townsville) - Sunday, Oct 25, 2009 at 15:55
Thanks Bob
It is on my wish list. Mr Airbags has already been contacted. Believe they are about $450 a set. Just have to save a bit more dough. I'm broke! LOL.
Malcolm
656300
Follow Up By: Member - Graham H (QLD) - Sunday, Oct 25, 2009 at 18:33
Repco sell Polyairs for a lot less than that.
656339
Follow Up By: Member - Malcolm (Townsville) - Sunday, Oct 25, 2009 at 18:46
Hi Bob
what I'm talking about is these ....
http://www.airbagman.com.au/lightvehicle.html# then click on Air-Rite more info or even the full air bag system (when the vehicle is out of warranty maybe ;-) ).
Malcolm
656342
Follow Up By: gav99x - Wednesday, Oct 28, 2009 at 15:49
Have you tried www.truckspring.com in the US?
Exact same product and much cheaper. Good time at the moment with the AUD the way it is too.
656828
Reply By: Roughasguts - Sunday, Oct 25, 2009 at 13:31
Or if you couldn't do that! Completly un-wind the jockey wheel! (pull it apart) and then cut off 50-75 mm off the outer jockey wheel tube.
That will also have the effect of lifting the jockey wheel so it can be more easily swung away.
cheers.
388619
Reply By: Member - Warrie (NSW) - Sunday, Oct 25, 2009 at 14:41
Gentlemen, there's probably 300 plus years of towing experience in this post. Who has had a weld or towball/bar fail and needed those chains to do some work?... Warrie
388622
Follow Up By: Alan S (WA) - Sunday, Oct 25, 2009 at 15:12
Yep, on my fathers caravan back in the 70's the welds failed on the caravans hitch and the chains were needed.
Welding technology is better now but faults can still happen.
656287
Follow Up By: Member - Duncs - Sunday, Oct 25, 2009 at 15:39
It was not the ball but I did have a coupling fail.
The tongue in the cup on the trailer failed and the trailer jumped off the ball. Chains are a very good thing. If they are the right length they not only keep the A frame off the ground but keep the coupling away from the shiny sheet metal on the back of the car.
As for the quick fit couplings, I use stainless steel carribeeners rated at 3.6 tonne each. I have 2, one on each chain that is a total of 7.2 tonne. With the max rated capacity of the towbar at 3.5 tonne I reckon I am OK.
Duncs
656292
Follow Up By: Member - Roachie (SA) - Sunday, Oct 25, 2009 at 15:39
Yep, was following an old bloke out of
Cooktown in 2002 on our way to the Cape. He had a droopcarrier with a full size, single axle caravan on the back. As he hit the dirt, after leaving the end of the bitumen, it became apparent that he hadn't properly hitched the towball onto the towbar correctly and the 2 separated company due to the jolt. The chains saved the caravan spearing off in whatever directon it would have otherwise chosen to pursue!!! hahaha
The caravan still hit the dirt........... I think the majority of trailers would be likely to hit the dirt if the coupling failed and they were relying on the chains. If you seriously have the chains short enough to prevent this from happening, then it is likely that you "could" stretch the chains when under full articulation (with the front of the towing vehicle facing up a steep pinch and the rear of the trailer still up high on the previous pinch....EG: when the rear axle of the 4x4 is down in the bottom of a ditch).
Roachie
656293
Follow Up By: Member - Malcolm (Townsville) - Sunday, Oct 25, 2009 at 15:52
They can and do come unstuck. All we can do is try to minimize any subsequent damage.
We used to run Airport Transfer in
Townsville. One of my drivers had the trailer hooked onto the Coaster and was just slowing down to turn right onto the airport road when the complete trailer came unhooked from the Coaster. The 'A' frame slid under the back of the bus and everything came to a stop. Extremely lucky outcome.
On investigation I found that the two bolts that held the tongue to the bottom of the towbar had snapped. Problem was, the safety chain was also fastened to the tongue. I was so thankful that he was nearly stopped when it 'let go'.
I would recommend you
check your towbar and see exactly where your safety chains are connected.
Malcolm
656298
Follow Up By: Member - Howard (ACT) - Monday, Oct 26, 2009 at 20:29
have to plead guilty to having the weld let go on HR tongue on my vehicle when towing all terrain trailer to
cape york last year. the tongue started to bend and weld started to crack at top.
ball load( trigg hitch) was just under 100kg
fortunately I had spare tongue with me and changed over for rest of trip. since getting back have rewelded and gussetted old tongue and have been using it for last 15 months no problem .
interestingly I also found 2 other broken HR tongues in
the gardens of the caravan
park at seisa so obviously others have had issues.
Howard
656533
Reply By: Member - Malcolm (Townsville) - Sunday, Oct 25, 2009 at 18:00
Thanks for all the excellent input in this thread.
I've just leveled everything (on level ground) and even with the tongue the 'wrong' way around, I am still 50mm short on tongue height to have everything perfectly level.
Here is a picture to explain .....
Any WDH will not solve the problem as the KK does not have a tow BALL.
Check the photo. It has a TREG hitch.
I already own a Hayman Reese WDH with anti sway that I used on the caravan setup (and kept. Too good to give away for nothing). The part that fits into the towbar is perfect. If we could now have just a flat tongue that bolts to that, it would allow the KK's TREG hitch to bolt to the tongue. We can then adjust the tongue up/down as required.
Considering the towbar fitted was to be suitable to fit to a KK, and a Hayman Reese towbar was subsequently fitted, I think I'll post an email off to Hayman Reese for a conclusive answer.
Stay with me guys ;-)
Malcolm
388657
Follow Up By: Member - Andrew (QLD) - Sunday, Oct 25, 2009 at 19:13
The problem i have found Malcom is that if you go too high, you end up with the T piece stopping the door opening in some cases. At least in your case the bumper setup seems to negate some of this issue.
If i have my KK on the Pajero as you have shown, then it becomes impossible to open the door.
Why do you need to have everything level? I'm not sure i understand the reason.
Andrew
656352
Follow Up By: Member - Malcolm (Townsville) - Monday, Oct 26, 2009 at 16:40
Andrew
You are correct. That's a problem when I had the Patrol Wagon with
barn doors. The D-MAX has a drop down tailgate. This is not a problem with the above setup (at present).
Malcolm
656494
Reply By: Member - Tom V (WA) - Sunday, Oct 25, 2009 at 19:54
Malcolm
I have done exactly the same for my D3 to match the treg or trigg for my jayco outback camper.
where did u get the, qucik connect, shackles. ???
cheers Tom
388673
Follow Up By: Member - Malcolm (Townsville) - Monday, Oct 26, 2009 at 16:48
Hi Tom
They came with the KK. I bought the KK from 'teabag'. There was a writeup about this camper in 4WD Action Issue 117 and recently in Issue 136 (p133). I'm sure Paul new what he was doing when he used the couplings ;-)
I would go to a yacht place (chandlery) and
check out stainless steel couplings.
Malcolm
656496
Reply By: Member - Malcolm (Townsville) - Monday, Oct 26, 2009 at 16:18
I sent a request to Hayman Reese to comment on this thread with an authoritive response to me. This is the answer I have received so far .....
[snip]
To address your concern over the height of the towball on your vehicle, I have read through the thread.
The thread by Graham H, raises a good point. The Trailer Ball Mount on your DMax has not been tested to be used in the upwards direction. This TBM has been used in the downwards direction to allow the towbar to achieve the maximum tow rating and ball weight maximum of the vehicle and to keep the centre of the towball within the specific Australian Design Rules and Australian Standards(ADR62 and AS4177) which is between 350mm and 460mm when the vehicle is fully laden.
Another interesting point raised is the definition of the a towball coupling. Some information given to me from a
well respected off road coupling manufacturer is that many off road style couplings are not referred to a towball coupling therefore as Dickybeach states, this allows some caravan, trailer, camper manufacturers to build their products with the tow coupling higher than the ADR.
But back to your initial concern, we have a couple of different solutions, one of which may work for you, either option will depend on what sort of towing weight and ball weight your camper has when fully loaded. If you could let me know these weights I can then advise you the best solution for you.
I look forward to your reply and being able to assist you.
Regards,
Gary Gardiner
Technical Support Representative - Hayman Reese Towing
CEQUENT, a division of TriMas Corporation Pty Ltd
E-Mail: ggardiner@cequent.com.au
CEQUENT
Phone: 0412 145 795
PO Box 4050
Dandenong South VIC 3164
Australia
My answer to
Gary's question is "Whatever the maximum is for the camper trailer manufacturer". Anything less would then be a safety zone for me.
I suppose my next point of call is to
Kimberley Kamper Group and get their comments on this thread.
Stay tuned .....
Malcolm
388804
Reply By: Roughasguts - Monday, Oct 26, 2009 at 17:43
My question is on that tounge the cut on the 50 mm square bar is at 45 deg. So in my theory that gives more weld area therefore a stronger or higher tow ball rating but only in the lower tounge direction.
So if the cut was square or the angle of the cut in the other direction would it be stronger as the weld would be stronger cause there is less of a shear angle ???.
Maybe a square cut is better for inverting the tounge, as
mine is also upside down to get the van level.
Mind you I also have a 2 bar WDH as
well ! that probably makes it worse on the welds.
388814
Reply By: Member - Roachie (SA) - Wednesday, Oct 28, 2009 at 16:57
I had a similar problem with my Ultimate Camper behind the lifted patrol....it always sat down at the nose and looked just plain WRONG.
On a trip through
Oodnadatta a few years ago, we were looking around inside the
Pink Roadhouse and I spotted a few shelves of second-hand bits and pieces up the back. There were a number of tow-bar tongues; one of which was like those you often see on an older style Hilux. It was a box section (Hayman Reece style), with a squared-off end and a flat heavy bar welded and bent to 90 degrees. On the Hilux (which had an unusually high chassis cross member at the back), they were designed to be used to drop the towball height down by about 6". I grabbed this item off the shelf, took it out to my rig and proceeded to swap my Treg coupling over to it. Of course I turned it upside down from it's original intended position, but because the end of the box section was squared-off, the sheer factor would have to be the same whichever way it was mounted (as far as I was concerned).
It raised the the nose of the Ultimate so that it now sits almost perfectly level. The deal was done and I traded my old Nissan tongue for the one that I really needed.
I find it difficult to believe that there could be any significant difference in the strength of those sloped-ended tongues, regardless of which way they are mounted. What you're saying is that the fact that there is some kind of "support" (because the box section extends underneath the flat bar portion), that this makes the joint stronger than if it were upside down. All I can say is that I have done thousands of kilometers with the original Nissan tongue mounted "incorrectly" and have never had any issues. I will admit that I don't have a huge ball weight (only about 120kg), but by crikey, I've towed my Ultimate to
Cape York twice with that old tongue and it's copped a pounding on corrogations etc..... never an issue.
The surface of weld on the sloped Nissan tongue is still larger than any squared-off type (like the type I'm now using with the extended raised section), so you'd have to imagine it would be stronger if anything.
Roachie
389129
Reply By: Member - Malcolm (Townsville) - Thursday, Nov 05, 2009 at 17:28
and here is the reply I received from
Kimberley kampers ....
Sorry malcom for the late response you can turn your hitch upside down
or get some air bags fitted to the rear that's the best advice I can give
Ben Haley
Service Manager
Direct: 02 6620 6821
www.kimberleygroup.com.au
Go figure ........
Malcolm
390103
