Cape Arid twiight cove
Submitted: Monday, Oct 26, 2009 at 22:11
ThreadID: 73331 Views:3066 Replies:4 FollowUps:1
Off to cape arid on sat for ten or so days.Wondering if anyone has been further east and had a look at the beaches back that way in regard to weed and driving on this time of year.Might go as far as twilight cove and back the telegraph track if possible.
Cheers Graeme.
Reply By: get outmore - Monday, Oct 26, 2009 at 22:19
you need to tkae the track behind the dunes from isralite for about 10k to avoid sand over weed after that you can hit the beach.
depending on tides andweed the run to pt culver can either be easy or immpaseable. I did it a few years back and it was a doddle - sometime later Willem did it and the beach was no go and he did it tough mostly along the telegraph line
basically theres no garantee its do able
AnswerID: 388884
Follow Up By: equinox - Monday, Oct 26, 2009 at 22:26
That seaweed west of Israelite Bay was scary stuff. I hired an 80's series in '97 and the water was up to the top of the wheel. At the bay the local fishermen joked that they would tow us out when they came through in a few days. I was as nervous as hell right until the end.
I advise to take the north track west of the bay.
FollowupID: 656585
Reply By: Member - joc45 (WA) - Tuesday, Oct 27, 2009 at 11:43
Went thru there in late Nov last year, travelling from east to west - on the Pt Culver to Israelite Bay beach run, the seaweed was pretty bad from Wattle Camp thru to Israelite Bay and I had to turn back. The track from the beach to Wattle Camp was flooded due to rain, so that option was also out. But an EO member was able to get thru about a month later with better tides. Driving thru the metre-deep seaweed is pretty risky business, and you could get hopelessly stuck.
I suggest you check tide charts for the area and try to make the run when the tides are at their largest amplitude (I was trying during a neap tide). Even so, you may still have to duck around some large seaweed heads at the water's edge. The 250K Topo, if you're using it, will show a track just behind the beach towards the Israelite Bay end, and you should try to get onto that as soon as you can, or if travelling west-east, take that track as far as you can before descending onto the beach. Alternatively, you could take the telegraph track a bit further inland between Israelite and Wattle Camp (Willem has successfully done that), then a few kms east of Wattle Camp, you can turn onto the beach (if the salt lakes are dry). The track is reportedly pretty overgrown and expect scratches.
Either way, there are some rocks NE of Israelite Bay blocking the beach run, which means you must take the telegraph track NE for about the first 20km before trying for the beach.
Having painted a gloomy picture, it is a wonderful run; the Bilbunya dunes are amazing, and there is a good camping spot at the eastern end in the dunes amongst banksias. If you dig, you can get good fresh water at the base of the Bilbunya dunes.
Also the run from Cape Arid along the telegraph track to Pt Malcolm, south of Israelite is a good run. Good camping at Pt Malcolm (better than Israelite) with a fresh water bore hidden in the dunes.
Gerry
AnswerID: 388932
Reply By: Member - John Baas (WA) - Wednesday, Oct 28, 2009 at 00:06
Hi Graeme. We did much of that in Feb this year. There is a full treknote of our trip on this site.
Cheers.
AnswerID: 389062
Reply By: Willem - Wednesday, Oct 28, 2009 at 20:16
Graeme
You may read about our trip in 2005, here
The Cape Arid/Israelite Bay/Bilbunya Dunes/Perpendicular Cliffs run is around the middle of the write up
AnswerID: 389159
