Tuesday, Oct 27, 2009 at 21:23
I have a 2009 V8 trayback GXL and know of the problems or lack of them of a few more similar vehicles around the area. The cruiser is a lot dearer but is a lot more capable than the Hilux. The choice would surely come down to terrain to be covered and load to be carried. The rougher the terrain and the heavier the load the greater the landcruiser advantage. If the terrain is mild and the load light a Hilux may be better for the job.
When I chose the cruiser I only did so after ruling out all the Hilux, Navara, Rodeo, Bravo type of vehicle that I had first been looking at. The only competitor left was the Patrol and it lost out on account of the engine. In the end I worked back from a possible
Canning Stock Route crossing as
well as a need to carry heavy loads ie a lot more than half a ton. For a long range trayback, as needed for CSR, there was simply no close competitor. The dual 90 litre tanks combined with the extra load carrying ability put it way out in front. The Patrol was still tempting though, at its much lower price.
Only real problem I know of personally, and not hearsay, is that one driver had access to some iffy
fuel and used it and had some rough running after it.
I have not had any real problem and think it is a great vehicle. One time I topped up the oil, used about a litre I think after having a service done while away on holiday. The service oil change had "economised" on the amount of oil used, something I noticed straight away and fixed. Took 10 litres across the Simpson twice "just in case" it developed the dreaded oil usage problem in
the desert. It didn't. Not surprising given they have been around for about 3 years and should by now be pretty
well sorted.
I agree with the comments about avoiding second hand ones. Second hand ones are far too dear compared to new and they are often driven by drivers who do not own them and some thrash them a fair bit. IMHO they are not good value.
The V8 traybacks are not perfect. They need an after market drivers
seat fitted and maybe one for a passenger as
well and probably should come with a standard roo bar. The standard seating is very poor and on a vehicle that costs around 70 grand set up is inexcusable.
They are great fun to drive.
656753
