Portable aircon in small caravan?
Submitted: Tuesday, Oct 27, 2009 at 20:12
ThreadID: 73357 Views:4916 Replies:5 FollowUps:0
Heya Folks
Just wondering if anyone has used a small portable room aircon in a caravan? I have an Arlec PA-9000 which has been used in a big room with poor insulation at home and, while not perfect, runs remarkably well. In a smaller insulated area like the van, should work much better
I see no reason why it wouldn't work in the van. Sure, it's bulky, and needs to be put somewhere, and needs an external duct (which is simple enough), needs draining, and a whole lot of other negatives... However, it's also cheap, and when you don't need it, you don't take it. It should also run on a much smaller generator than the min 2000W Honda, or 2500W everything else, that most van aircons seem to need.
I don't need info on caravan air con units...got plenty of that, both positive and negative. Just wondered if anyone uses the portables, thanks.
Scott
Reply By: nowimnumberone - Tuesday, Oct 27, 2009 at 21:25
yes we bought a cheap portable air con for our hawk
run it of the honda and does a great job
AnswerID: 389033
Reply By: ishtvan - Wednesday, Oct 28, 2009 at 13:51
we traveld four jers in ultimate camper t, and kipped cool with 9000 BTU no troubles
AnswerID: 389106
Reply By: patrolmann - Wednesday, Oct 28, 2009 at 14:55
Hi I have a coromal 380 wind up off roader with canvas sides and i bought a protable refrigerated air con. Works a treat. When i first turned the air on it was reading 45c and within 1 hour it was 23c. I hunted around and found the smallest dimensions with the biggest cooling capasity. Got mine from The Good Guys in SA. Arlec 45000BTU I think. Was like $459.00 on special
cheap as
patrolman
AnswerID: 389116
Reply By: Member - BUNDY BOY (WA) - Wednesday, Oct 28, 2009 at 16:25
yep they work a treat ...i use o portable in my ambo when up nth for weeks on end...keeps me cool even in the daytime in open sun
Cheers Bundy
AnswerID: 389122
Reply By: Rocko Wallaby - Wednesday, Oct 28, 2009 at 18:49
Thanks guys. I think I'll be trying it this way for a while and, if it isn't 100%, can always change later. At least don't need to lug around a heavy unit in cold winter months!
AnswerID: 389138
