Which drawer system
Submitted: Thursday, Oct 29, 2009 at 18:59
ThreadID: 73389 Views:6102 Replies:10 FollowUps:14
Hi I,m looking to install either a Black Widow or an ORS drawer system into my 100 series. Both seem to be very good products and both are priced similar. Can anyone comment on pros and cons between the two.
Also has anyone got one of these
http://www.platinumgear.com.au/
If so can you comment on them?
Reply By: Member - Stephen L (Clare SA) - Thursday, Oct 29, 2009 at 19:36
Hi Rare
I have and can recommend the Black Widow draw system. In a lot of cases, if you sell your vehicle, you are able to install your old unit in your new vehicle, while only having to replace the side wing sections. They have many add on features and work a treat. My system has seen the toughest of conditions that Australia can through at you, and have stood up with no problems at all. There are a lot of other systems on the market, all being good, but will vary greatly.
My unit has the sliding fridge slide, half rated cargo barrier in the back, as well as a Black Widow top shelf barrier, while when I head bush, I take out the back seats and install the forward half floor. On the outside I have the Black Widow 2.5m Side awning. No I do not work or have and interest in the Company, just one very happy and satisfied customer with their products.
StephenImage Could Not Be Found
AnswerID: 389286
Follow Up By: Fred G NSW - Thursday, Oct 29, 2009 at 19:55
Nice rig there Stephen. I just had a closer look (double click) and can see lot's of space for more stuff LOL :-))
I like that awning, I'll hafta look into that.
Ta for the pic.
Fred.
FollowupID: 657015
Follow Up By: rare - Thursday, Oct 29, 2009 at 20:00
You are setup similar to what I,m look for Cargo barrier with shelf. I,m thinking about installing the stainless steel water tank as well between the drawers and back seats?
Have you seen this slide before http://www.platinumgear.com.au/
Seems to be a good idea but I,ve little about them?
FollowupID: 657017
Follow Up By: Member - Stephen L (Clare SA) - Thursday, Oct 29, 2009 at 21:13
Hi Fred
When we head bush, you would be surprised just how much gear we take. We have just purchased a kitchen sink - well the fold up ones from the EO shop, so next time we will have even more gear in the car, including the kitchen sink. LOL
As for the awning, it is great. We usually use it at night, but the day that we were at Neale Breakaway on the Connie Sue, it was quite warm without any shade, so we put out the awning for some shade and our lunch break. We have had all our gear for some time and are very happy with the way that it all works.
FollowupID: 657035
Follow Up By: Member - Stephen L (Clare SA) - Thursday, Oct 29, 2009 at 21:30
Hi Rare
The water tank would be great, but not sure on the size. Whenever we head bush, we always carry a minimum of 100 litres of water. It sounds a lot, but when you are not able to top up along the way, you would not believe just how quick the water goes in a 3 week trip. We do not waist it, purely for drinking, cooking and washing dishes etc. We usually have 1 x 20 litre water container, 10 x 2 litre old coke bottles full of water 6 x 10 litre casks of spring water. In this way, when the coke bottles and spring water are used, it gives us extra free space inside the car. The coke bottles fit very neatly in both foot wells under the Forward Floor.
As for the drop down fridge slides, they are only new out and we have our set up long before they were out. The only trouble now with the Top Shelf Barrier, you can not just open up the fridge the way I used to before, as the is less than 10mm gap between the fridge cover and the bottom of the barrier frame ( this is for my 40 litre Engel.) As I am a lot taller than Fiona, I slide the fridge out and can see what is in there.
FollowupID: 657043
Reply By: you eat the bear - Thursday, Oct 29, 2009 at 20:01
You should have a look at the draw systems from Best Off Road too (on this site).
Jim is very competitive if that's of significance for you.
I haven't got the platinum unit for the fridge - great idea but I can't justify the $$'s when I can stand in the towbar instead.
Good luck
Steve
AnswerID: 389288
Follow Up By: nowimnumberone - Thursday, Oct 29, 2009 at 21:27
ill second that
very good unit and only half the price
FollowupID: 657042
Reply By: Member - evren1 (WA) - Thursday, Oct 29, 2009 at 20:16
got a black widow in my 100 series. Got the full setup, draws/fridge slid/centre divider/ roof shelf and cargo barrier.. If you want the drop down slide(platinum) don't install the roof shelf, as my 60L Engel won't fit.
Quality finish and other than having to tighten a couple of bolts after some bumpy stuff and service the draw bearings and lube the runners, it pretty much looks after itself. I am more than happy with my system.
EvanImage Could Not Be Found
Despite the cost of living, have you noticed how popular it remains!
AnswerID: 389290
Reply By: Featherfoot - Thursday, Oct 29, 2009 at 20:27
HiRare
I have the Black Widow drawers , front floor section and half cargo barrier in my 100 series. Fitted it myself which wasn't too hard. They are well made and fit very well. Also have a fridge slide which lets the engel 39l slide out the passenger side door.Wife needs a step to see in the fridge as it is a tad high for her. all in all am quite happy with the drawer system.
Gary
AnswerID: 389293
Reply By: Best Off Road - Thursday, Oct 29, 2009 at 20:29
Well seeing as Steve has mentioned us I'll chime in.
We professionally build Drawer Units that will do everything that Black Widow or ORS or Outback do for about half the price. Every bit a strong and about half the weight.
The other advantage of ours is that they take only 10 to 15 minutes to install or remove.
Have a look at our website
Best Off Road Website
You'll find shots of the 100 series there.
Jim Best.
AnswerID: 389294
Follow Up By: Best Off Road - Thursday, Oct 29, 2009 at 20:38
I should have mentioned, if you are in the market for the real upmarket stuff I'd suggest "Fourby Fitouts", Hallam, Vic.
They build great "modular" drawer systems. Only marginally dearer than the others mentioned but superb, if you're not on a budget.
Jim.
FollowupID: 657024
Follow Up By: River Swaggie - Friday, Oct 30, 2009 at 00:12
Your Website's looking great Jimbo !
FollowupID: 657077
Follow Up By: Best Off Road - Friday, Oct 30, 2009 at 22:29
Thanks Wayne,
We've spent a dollar or two to get it right.
Regards,
Jim.
FollowupID: 657203
Reply By: andoland - Friday, Oct 30, 2009 at 12:11
I would recomment that you speak to each manufacturer and find out what the internal dimensions of their drawers are. There is a big difference in the size - some are up to 100mm longer than others and the height varies quite a bit too. If, like us, you were after maximum space inside the drawers then this is important. We found that the Black Widow had the largest capacity drawers and they were a quality product so we were prepared to pay the price premium for this, rather than get something cheaper and have limited room.
We have a Prado so I can't say whether or not Black Widow would have the most room for a 100 series.
Ando
AnswerID: 389406
Reply By: Member - Tour Boy ( Bundy QLD) - Friday, Oct 30, 2009 at 15:52
We bought our Outback system 2nd hand and have since had it in 3 different vehicles. It has been pounded on thousands of km of corrugations and flexed on some hard off roading and still works like the day it was new. A few of the screw heads aren't the best anymore due to bad operation of a screwdriver installing and removing the top.Image Could Not Be Found
Dave
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 389423
Reply By: RobAck - Friday, Oct 30, 2009 at 18:59
Have you looked at http://www.4wdinteriors.com/ We have been using these for the last three vehicles and find them excellent. Not a rattle, extremely well made and last forever by the looks of things. Price wise I reckon they will be line ball with the rest and it will depend on your reseller as to how interested they are in discounting.
As a tour operator and trainer we need stuff to last and these guys deliver and no I don't get anything from them
RobA
AnswerID: 389437
Reply By: Member - Greg T (ACT) - Sunday, Nov 01, 2009 at 09:27
rare,
i have a platinumgear drop down fridge slide. bought it two weeks ago.
what can i say about it. fan bloody tastic!!!.
would recommend it to anyone.
a bit expensive, but with the extra couple of buck when the 80 waeco drops from shoulder height to hip height.
now the bride can get me beers while i stoke the fire!!
AnswerID: 389566
Follow Up By: Member - Timbo - Tuesday, Nov 03, 2009 at 19:48
Hey Greg, do you mind giving us an idea of how much they are? There seems to be no info on the website - even on the order form where they ask for your credit card details but don't mention the price... is it a case of "if you have to ask then you can't afford it?!"
FollowupID: 657615
Follow Up By: Member - Andrew (QLD) - Tuesday, Nov 03, 2009 at 21:58
$550 was listed in the last thread about them on here.....though it might be good to read that thread: 55491 - Drop_Down_Fridge_Slide
Hope they have changed management practices.....
Andrew
FollowupID: 657628
Follow Up By: Member - Timbo - Wednesday, Nov 04, 2009 at 14:14
Thanks Andrew. I thought the website looked like it hadn't been updated in a while, then I read that thread - they must be out ExplorOzing somewhere because it sure seems they're not putting much time into their business venture!
FollowupID: 657693
Follow Up By: Member - Greg T (ACT) - Wednesday, Nov 04, 2009 at 22:36
sorry for the lateness in this reply timbo.
i paid $645 delivered. bit expensive but worth every cent
FollowupID: 657779
Follow Up By: Member - Greg T (ACT) - Wednesday, Nov 04, 2009 at 22:38
to add to my last.
this is for the 80-100 ltr slide. the smaller fridges get a smaller price tag.
i spoke to them when i ordered it and they are having trouble updating thier website
FollowupID: 657780
Follow Up By: Member - Timbo - Thursday, Nov 05, 2009 at 13:02
Thanks Greg - yes, that is a lot, but then again, a standard fridge slide is usually already at least $350-400.
FollowupID: 657839
Reply By: Who was that again? (Vic) - Wednesday, Nov 04, 2009 at 22:50
rare, I see that Tanami haven't been mentioned here. They are a great set in aluminium but aren't cheap. They are solid when in place.The Tanami range The problem there was that they weren't the most professional but the job was great
AnswerID: 390025
