Inverter Generator
Submitted: Thursday, Oct 29, 2009 at 21:12
ThreadID: 73394 Views:4257 Replies:9 FollowUps:11
Hi, before parting with the hard earned, I would like to know your opinions on which generator is better (Honda or Yamaha) - only looking at getting the 1kva version for camping to top up batteries and maybe run a LCD tv for a couple of hours a night. cheers,
Reply By: Best Off Road - Thursday, Oct 29, 2009 at 21:21
I would suggest you also have a look at Kipor.
Our's has been great.
Jim.
AnswerID: 389315
Follow Up By: Laz01 - Friday, Oct 30, 2009 at 18:59
thanks for the feedback - never heard of Kipor gennies, but I will look into it. Are parts readily available should something stuff up?
cheers,
FollowupID: 657172
Follow Up By: Best Off Road - Friday, Oct 30, 2009 at 20:56
My undesrtanding of them is that they are such a perfect copy of the Honda that parts are interchangeable.
The Australian Distributor is now Primus Australia, their backup is without question.
FollowupID: 657196
Reply By: DIO - Thursday, Oct 29, 2009 at 21:27
A quick check of the archives on this forum turned up more than 1,000 hits relating to the word 'generator'. Check this link for access Archives re generator Good luck with it.
AnswerID: 389316
Follow Up By: nowimnumberone - Thursday, Oct 29, 2009 at 22:39
thats right more than 1000 hits who would want to read 1000 plus hits when the can just put up a new post and get what they want with 4-5 answers
FollowupID: 657061
Follow Up By: Maîneÿ . . .- Friday, Oct 30, 2009 at 10:35
so now your number one, another worthwhile point worth mentioning is the 'archived' posts will (most) possibly contain redundant information, as technology is changing rapidly with new models with improved specifications being released often, therefore not available on the 'archived threads'
Yes, I also say put up a new thread if you need relevant information
Maîneÿ . . .
FollowupID: 657117
Follow Up By: Laz01 - Friday, Oct 30, 2009 at 19:03
nowimnumberone & Maîneÿ pretty much sumed up what I was trying to acheive with new technology and without having to sort through 1000+ archive items.
cheers guys,
FollowupID: 657173
Reply By: Dennis Ellery - Thursday, Oct 29, 2009 at 21:59
There are many cheaper but none are as quiet as the Honda or Yamaha.
You couldn't go wrong with either.
AnswerID: 389328
Follow Up By: Laz01 - Friday, Oct 30, 2009 at 19:07
Thanks Dennis, one of the main factors that has made me lean more towards Yamaha.
cheers, Laurie
FollowupID: 657175
Reply By: Shaker - Thursday, Oct 29, 2009 at 22:47
Yamaha are quieter & I believe have a cylinder liner whereas the Honda doesn't.
AnswerID: 389336
Reply By: Serendipity (WA) - Thursday, Oct 29, 2009 at 23:09
I just researched this question for my parents recently. There is very little difference between the two. They settled on the Yamaha for a few dollars less and some minor spec data differences.
David
AnswerID: 389345
Reply By: Ozhumvee - Friday, Oct 30, 2009 at 07:29
Went through the same exercise earlier in the year, decided on the Yamaha as it was slightly cheaper (much cheaper currently on ebay), parts are much cheaper, no difference in performance other than the Yamaha is supposedly quieter and runs longer on a tank of fuel for a given load. Can't verify either of the latter claims.
AnswerID: 389357
Follow Up By: Member - Roachie (SA) - Friday, Oct 30, 2009 at 11:02
I also have a Yamaha 1kva inverter gennie. A mate of mine has the Honda equivalent. We were camped on Kangaroo Island a few years ago, side by side for about 10 days. Every few days we would take it in turns to fire-up one of the gennies to recharge our batteries. No point running both gennies at once, as each one was quite capable of running our 4 fridges and 3 battery chargers.
However, one arvo, just for the hell of it, we started them both up at the same time. I don't know if there's something wrong with mine or not (it works perfectly well), but although it is claimed to be quieter than the Honda, it was actually SLIGHTLY louder. It would not have been noticeable to the naked ear when only one or the other was running.....but when they were both running at the same time it did seem slightly louder than the Honda.
Both are very good at what they do. The first time I used mine was on a trip down to Monteith (near Murray Bridge) at Xmas 2005. We had 5 fridges (including Pesty's Waeco 110L, Muddy's 60L Waeco, Brew69's Waeco 60L and my 2 Engels....40L and 110L upright in the camper) PLUS we had 3 battery chargers running. This was on a pretty hot day. We started the gennie about half an hour after pesty's missus had gone for her nanny nap about 3pm....his camper was about 10 meters from where we set the gennie up. She never heard it running and slept blissfully through it. Even with this reasonable load on, we had it set on ECO mode and the only time it revved up a bit was when Pesty's great big Waeco cut in....then it would settle down again.
Roachie
FollowupID: 657120
Follow Up By: Laz01 - Friday, Oct 30, 2009 at 19:13
thanks Ozhumvee & Roachie for providing me with valuable first hand info in relation to this topic - pretty much what I was looking for, although the following couple of post directing me towrds "Solar" sounds very interesting, if you can get your head around the amount of power generated by various items and the amount of amps put back in with a solar panel.
thanks,
Laurie
FollowupID: 657178
Reply By: paulnsw - Friday, Oct 30, 2009 at 11:41
why not look at 80w solar panel. something you have for life no fuel no service no replacement. solar panel and decent solar regulator like Morningstar same price as generator with no running costs. other thing to consider no generators in national parks and no fights with camping neighbours over noise
we have 120w panel and would never consider going back to generator
AnswerID: 389399
Follow Up By: Shaker - Friday, Oct 30, 2009 at 19:11
How does solar help in this scenario?:
4pm .... Leaving campsite, camper all packed up, go to start vehicle, flat as a tack.
I hooked up the generator & had the vehicle started in 30 minutes.
FollowupID: 657176
Reply By: Member - Barry (NT) - Friday, Oct 30, 2009 at 14:09
AGREE look to solar, assuming 80% + of your camping is in fine weather.
On the road for 2 years in c van with 480 watts of solar and had to start the genny once,,, we had too much shade,,lol but our load is higher but same principles apply
AnswerID: 389417
Reply By: veight - Friday, Oct 30, 2009 at 22:59
Honda 4 year warranty
Yamaha 2 year warranty
Kipor are a copy of the Honda & electrical parts / carby etc are not the same
AnswerID: 389456
Follow Up By: Dennis Ellery - Friday, Oct 30, 2009 at 23:36
Where’s your evidence? – Another unsubstantiated claim. Check the specs - noise, capacity etc - the Kipor is neither a clone of the Yamaha or Honda. It’s not even a close copy.
FollowupID: 657210
Follow Up By: veight - Saturday, Oct 31, 2009 at 12:23
What i should say is Kipor is A poor chinese copy of a Honda
Yamaha / Honda in the 1kva is very close in specifications
I will State Kipor engine / electrical parts are NOT the same
Yes honda airfilters fit a kipor but thats about it.
FollowupID: 657245
