Which end od the pump is the head?
Submitted: Monday, Nov 02, 2009 at 20:42
Member - Boo Boo (NSW)
G'day all
I have bought a flojet LF22202 pump for our camper trailer.
I have work out where to put it and hook up the electrics, but I can't figure out which end of the pump is the head.
No smart @rse answer please. LOL
I presume its the end that has the
water inlet and outlet.
Reply By: Member - Graham H (QLD) - Monday, Nov 02, 2009 at 20:45
Yes
389750
Follow Up By: Member - Boo Boo (NSW) - Monday, Nov 02, 2009 at 21:00
Thanks Graham.
657502
Follow Up By: Member - Pesty (SA) - Monday, Nov 02, 2009 at 21:37
Will have an arrow marked on there too to show
water flow direction.
The smart rse answers would have been more fun hahaha
Pesty
657510
Follow Up By: Member - Boo Boo (NSW) - Tuesday, Nov 03, 2009 at 07:47
Thanks pesty
I wondered about this when I had a look this morning.
However there are no arrows, but I worked that out the flow by the diagram set up. I'll check it when I turn on the electrics and before I put it in place.
657533
Reply By: Member - Mike DID - Monday, Nov 02, 2009 at 22:10
When referring to a pump, the head is the maximum height of
water that the pump can lift or suck.
389759
Follow Up By: Who was that again? (Vic) - Monday, Nov 02, 2009 at 22:36
That is right Mike. Whatever the head capacity, it will never lift over 6 metres by suction and those little pumps can easily get a particle under a valve that may cheat that. Many cut out at about 35psi, so 10 metres or so for one like that. Combined head of, say, 16m.
657515
Reply By: Member - Axle - Monday, Nov 02, 2009 at 22:18
WOT!!!!!!???? .......:)))))))))).
Cheers Axle.
389760
