Transfer Case Oil darken quickly
Submitted: Thursday, Nov 05, 2009 at 09:14
ThreadID: 73537 Views:6028 Replies:5 FollowUps:12
Hi. I have a 1994 HZJ75RV Troopy that I service myself with 282,000 km on the meter. I usually change the transfer case oil every 20,000 km as it gets very dark/black. I recently bought a Jayco camper and it seems that towing makes the oil darker quicker which is sort of normal given the added stress. I use Castrol Multitrax for the transfer. Gear box oil remains very clear and light in colour. I spoke to a few people and some tell me that it is normal for the transfer oil in the cruiser to get black and that it should be changed every 20,000 km max and others tell me that I may have a problem. I have had the car for 4 years now and have done about 60,000 km with it, including highway, desert, high country, etc... there is no noise or other that seem to come from the transmission. The only issue I have had was that the flange at the back of the transfer got loose a little and oil leaked a bit but level was never low. Got it fix. Anybody got any idea or knowledge of what could cause the oil to darken. Any reason why the transfer would overheat (although the oil does not smell burnt)? Cheers, Didier.
Reply By: fisho64 - Thursday, Nov 05, 2009 at 11:12
bit of a mystery why transfer case oil would go dark-there is no reason I can think of other than cooked?
Perhaps (to eliminate if nothing else) find someone with an IR heat gun and check temp after a hard highway run? It must be significantly different from GB temp.
I cant for the life of me understand why someone would think its normal for transfer case oil to go black. 20000km for trans oil change seems very short?
AnswerID: 390055
Follow Up By: Fab72 - Thursday, Nov 05, 2009 at 12:49
I agree with fisho.... having been a Toyota tech in my previous life, we used to change drive line oils every 30,000kms and to be honest, the transfer oil was always the cleanest out of the engine, diff, gearbox and transfer. Dark oil is "usually" an indication of burnt oil. A smell test will confirm that, if that is in fact the case.
The type of oil you're using is the correct one...so stuffed if I know. Are there any particulates in the oil? Is the breather venting OK?
I had a quick chat to our on-site Castrol rep here at.......... where I work now. He suggested taking a sample of the used oil some where to have it analysed.
FollowupID: 657837
Follow Up By: dc - Thursday, Nov 05, 2009 at 16:37
Smell is "normal" as in not that different from clean oil. Gearbox oil is clear as new. Will try to check temperature and get a sample. Cheers.
FollowupID: 657858
Follow Up By: dc - Thursday, Nov 05, 2009 at 17:01
Sorry, forgot to answer the following:
- Seems to vent OK
- No particulates or shavings/fillings that I can detect. Nothing stuck to the drain plug magnet.
Cheers.
FollowupID: 657867
Reply By: Member - Kiwi Kia - Thursday, Nov 05, 2009 at 14:28
A known Troopy problem is oil finding it's way between the gearbox and transfer case. What colour is the gearbox oil ?
KK
AnswerID: 390080
Follow Up By: fisho64 - Thursday, Nov 05, 2009 at 21:22
seek and ye shall find!
in his post he says GB oil is clear as!
FollowupID: 657903
Follow Up By: Member - Kiwi Kia - Friday, Nov 06, 2009 at 06:27
You are right :-((
KK
FollowupID: 657931
Reply By: Member - Vic S (VIC) - Thursday, Nov 05, 2009 at 14:51
Hello
I had the same problem,initially pulled out the gear box to fix the seals between it and the transfer and noticed the thrust washers in the transfer were black (should be copper) replaced them and had no more dark oil issues.The same job can be done leaving the gearbox in the car its just a bit of a fiddle.
Vic
AnswerID: 390083
Follow Up By: dc - Thursday, Nov 05, 2009 at 16:42
Hi Vic,
When you say the thrust washers were black, do you mean they were of an unknown black material in place of copper or they had deteriorated so badly that they appear black? How long did you drive yours with the "black oil issue"? I had plan to do the clutch in a few months so it will make sense to do all at once.
Didier.
FollowupID: 657860
Follow Up By: Member - Vic S (VIC) - Friday, Nov 06, 2009 at 09:58
Hello again
My oil was dark for one or two changes so about 18 months / 2 years and getting darker.The washers were the correct copper ones but had burnt on the thrust surface,I had the car for one oil change after replacing the thrust and it was not dark then.
Vic
FollowupID: 657960
Reply By: Member - ross m (WA) - Thursday, Nov 05, 2009 at 16:39
I do the gearbox and t/case in my HZJ75 every 25-30000 and it is still clear and light coloured.
Im using Castrol VMX90 (or is it 80)
Not towing in 5th by any chance
AnswerID: 390095
Follow Up By: dc - Thursday, Nov 05, 2009 at 16:49
G'day Ross,
I tow in 5th from time to time: flat on highway at around 100km/h when the running is easy. Gearbox oil is always clear and transfer oil problem appeared well before I got the camper and started towing. I just can't remember if it always been there or not. I bought the car second hand and changed all the fluids as soon as I got it. Transfer was clear but I don't know if the previous owner had just changed it or not.... After that, the "problem" started to appear. Never found any metal shaving.
Didier.
FollowupID: 657863
Reply By: racinrob - Thursday, Nov 05, 2009 at 16:46
G'day Didier, I have a similar vehicle (tray back) with same mileage, I fitted an oil bypass line between the gearbox and transfer case many kms ago so the oil in both is the same colour but definitely not dark. I change my oil at 20,000 kms also on the advice of my mechanic and use an additive. Transmission has recently developed a noise and the transfer case gets very hot but asking around I'm told this is due to the weight I'm carrying, I'm waiting to see if this noise gets worse however the oil is still light in colour and no metal evident on the drain plug.
I'm leaving tomorrow on a 4,000 kms round trip trip but will be listening with to that transmission noise the whole time with fingers crossed.
RR
AnswerID: 390097
Follow Up By: dc - Thursday, Nov 05, 2009 at 16:55
I am 100% sure that no oil is being pumped into the gearbox. No leaks, level always full. I do carry a bit of weight in the back of the troopy but I would not think it is too much.
Best of luck RR. Thanks for your input.
FollowupID: 657864
Follow Up By: Ozhumvee - Thursday, Nov 05, 2009 at 20:22
Having owned several 75 series troopies over the years I found they all suffered from the same or similar problems especially when constantly laden or towing.
The input gear on the gearbox output shaft/transfer input slowly flogs the splines on the shaft out putting a very fine mist/sludge of metal dust into the oil causing the blackness, eventually the metal also helps to remove the case hardening on the idler shaft and it then contributes more metal to the oil.
I never got more than 120k out of a transfer before it needed rebuilding and one of a similar vintage to yours had worn the shaft splines down to about 2mm from the original 5mm by the time it started to make a noise. A hairs breadth away from losing all drive!
Drain the oil, take the PTO cover off the side and the black tin cover off the rear of the transfer case. Hold the end of the shaft inside the tin cover with one hand and attempt to rotate the input gear (closest to the gearbox) with the other hand. If there is any rotational movement of the input gear on the shaft you have a problem. There should also be no movement sideways between the gear and shaft either.
You must have been getting some "sludge" on the magnetic drain plug surely.
FollowupID: 657887
Follow Up By: racinrob - Thursday, Nov 05, 2009 at 21:00
Thanks Peter, I'll do as you suggest. I had the transfer case rebuilt at 100,000 and again at about 130,000, mechanic gave me a discount the second time as he couldn't believe the problem re occured so quickly.... neither could I !
Before someone jumps in I only use overdrive on flat going over 80 kms and generally sit on about 90 - 95. Apart from the transfer case I've had a terrific run out of the 75 series, 270,000 kms trouble free but past time to upgrade.
Rob.
FollowupID: 657900
Follow Up By: dc - Friday, Nov 06, 2009 at 08:10
Thanks Peter, will check for movement as suggested as well. Didier.
FollowupID: 657943
