projecta air compressor storm- worth it?
Submitted: Thursday, Nov 05, 2009 at 14:18
getmethehelloutahere
At Repco $195 reduced to $119. Is it worth considering. Occasional sand driving in a 120 Prado, but wouldn't be getting heaps of use.
MAX PRESSURE 150psi
MAX FLOW RATE 72 litres per minute
MAX CURRENT 30 Amp
APPROVALS EMC
Tim
Reply By: Trevor R (QLD) - Thursday, Nov 05, 2009 at 15:31
72 l/min is a good flow rate. I have the same flow rate from a super cheap pump and find it acceptable for re-inflating tyres after a day of fun at lower pressures. With
mine, if I try to re-inflate an extra 2 tyres on my caravan it will heat overload and need a rest for a while so I suggest it is really designed for the occassional use warrior. Going from 16 or 18psi to 40psi may just be about the limit on 4 tyres but if it is, just pump the tyres back to say 35psi and let
the servo pumps do the rest or just allow extra time as you are coming off
the beach depending on how the Repco pump goes.
Seems a good price too, for that flow rate.
Hope this helps,
Trevor.
390086
Reply By: Member - Allan B (QLD) - Thursday, Nov 05, 2009 at 16:15
Hi Tim,
I have the twin cylinder (Typhoon) version of the Projecta Storm.
It has been excellent but at 600W is rated 150 l/min.
I would think that the "Storm" would get you there but a bit slower.
And at $119 is a good buy.
If you are re-inflating four tyres from 18 to 40 psi you may need to give it a rest halfway to avoid overheating. One way is to inflate all tyres to say 30 psi then drive quietly for 15 minutes to allow the compressor to cool before continuing the inflation to 40 psi. Or better still take a short walk for 15 minutes.
390091
Reply By: Member - David K (VIC) - Thursday, Nov 05, 2009 at 16:23
Hi getmethehelloutahere,
I have the same compressor and paid $165 from ebay for it. The Repco $119 is in my opinion a good price.
As mentioned it is more for occasional use but i would recommend getting one. I never realised how convenient a compressor is around the block.
Dave
390092
Reply By: Member - ross m (WA) - Thursday, Nov 05, 2009 at 16:30
Flow rates dont mean much as they are taken without a tyre attached.
Its a bit like reving the engine in neutral.
For about $135 Bushranger sell a pump that will pump your tyres all the way without a rest.
They did quite
well for the price in the 4wd action comparison a few months back
The cheapies will let you down when you need them the most.
390093
Follow Up By: Member - Tony V (NSW) - Thursday, Nov 05, 2009 at 18:21
Projecta got a "Highly Recommended" in that test, if I remember correctly.
657871
Reply By: DaveO*ST-R - Thursday, Nov 05, 2009 at 17:54
Tim,
I have the Projecta Typhoon which is rated the one above the Storm. It is a great unit. If I were you, I would spend the extra dollars on the Typhoon or equivalent. I have found it a great compressor for the price. (I think I paid around $160? a couple of years ago) Having just returned from up north where we did a fair bit of beach driving, I found I could inflate 6 tyres, including trailer, in hot weather, from (at one stage) 15 to 40 lb without it even protesting, overheating or cutting out. Perhaps the Storm might struggle to do the same.
Dave
390107
Follow Up By: Member - Mike DID - Thursday, Nov 05, 2009 at 19:07
For 4WD tyres, I wouldn't get anything less than the two-cylinder Typhoon.
657877
Reply By: getmethehelloutahere - Thursday, Nov 05, 2009 at 19:35
Thanks for the replies. Sounds like I will get frustrated at some stage by the unit being underpowered. I will wait for a bigger unit to come on special.
Tim
390121
Reply By: ABR - SIDEWINDER - Thursday, Nov 05, 2009 at 20:14
Hi Tim
Here are some test results.
Derek from ABR
390126
Follow Up By: getmethehelloutahere - Thursday, Nov 05, 2009 at 20:58
Thanks, that's really useful.
657898
