Cancelling TX4400 priority channel
Submitted: Friday, Nov 06, 2009 at 00:37
donk
I was wondering if any
forum members know if the priority channel can be cancelled on a TX4400 once it has been enabled
I can change the priority channel to any of the 40 transmit/receive channels available but i would like to cancel it completly if possible
Any help would be appreciated
Regards Don
Reply By: Pete Jackman (SA) - Friday, Nov 06, 2009 at 05:01
Try this from teh handbook:
"• Feature Disabling Function: Allows Scanning, Squelch, Duplex, Priority, Channel selection and CTCSS features to be enabled or disabled to make the radio simpler to operate."
Then:
"The TX4400 has a number of features that can be disabled by the user to allow for much simpler operation. This is done by disabling one or more of the keys on the front panel. These include the Function, Scan/Dim, OS/GS/Page, Duplex/
Alpha and the Quiet/Silent keys. To disable one of the keys:
1. Turn the radio OFF.
2. Press and hold the key you wish to disable while turning the radio back ON. A low beep will be heard and the selected key will no longer function. To re-enable the key, repeat the steps above. When the radio is turned on again, a high beep will be heard and the key will function normally again. For example, to disable the SCAN function:
2. Press and hold the SCAN key while turning the radio back on. A low beep will be heard and the SCAN function will no longer be available. Repeat the procedure to re-enable the SCAN function."
Pete
390173
Follow Up By: donk - Friday, Nov 06, 2009 at 09:36
Pete
This works with most features but not with the priority channel as doing this will put the radio into programming mode to allow the extra receive channels to be programmed in
Regards Don
657957
Follow Up By: Pete Jackman (SA) - Friday, Nov 06, 2009 at 10:28
Yeah, I read that after I posted. The post below looks like the answer. There must be some way of doing it as it says it can be done in the preamble to the guide.
Good luck
Pete
657965
Reply By: Gossy - Friday, Nov 06, 2009 at 09:58
I had a problem with
mine a day after i purchased it. Took it back and they plugged in a laptop and did it all on this (uploaded the changes to the radio).
390207
Reply By: DarrynJ - Friday, Nov 06, 2009 at 16:30
Donk why do you want to cancel it completely? If you don't need it then don't use it. I personally find it a very useful feature.
Regd's Darryn
390257
Follow Up By: donk - Friday, Nov 06, 2009 at 22:15
The trouble is once you but it in you cant remove it
It is a handy feature but i put a extra 15 receive only channels in and put them on a group scan but when it is group scanning if the priority channel (not one of the extra 15) has traffic on it the radio will lock on to it instead
If i want to than go back to the 15 i have to take it out of scan mode & manually select one of the 15
What i have done today is change (suggested by someone on another
forum) the 15 to open scan (no priority channel on open scan) & make the others group scan to get around this
Also received a reply back from GME saying they can manually disconnect it if i want to send the unit back but whti have done today will work ok for now
Regards Don
658093
Follow Up By: DarrynJ - Saturday, Nov 07, 2009 at 09:41
Looks like you've solved it Don, I have 5 extras in my TX4400 but I have the Priority Channel in the Scan Group.
658114
Reply By: SteveL (WA) - Friday, Nov 06, 2009 at 22:41
The priority channel can be disabled in the software, only problem is that it also disables the channel selector.Obviously not an option.-Steve
390312
