Friday, Nov 06, 2009 at 14:56
Seachanger
Many good replies above. With at bit of experience, you should get through if you follow a few very basis requirements, that surprisingly not every one follows. The ones that do not follow it are the Cowboys, Have 4x4 can go anywhere with no preparation or exception.
We have travelled the Simpson countless times, and it will get you in. We prefer the east/west crossings, a little more of a challenge, but still no dramas.
July/August are peak times our there, and the best time to drive it. Days should be perfect, mid to high 20's, even low 30's. Nights will depend on any cloud cover from
well below 0 to teens when cloud cover. If you follow what I suggest, you should have a very enjoyable and safe trip.
At the base of either Big/
Little Red, depending which way you want to go over, drop your tyre pressure to 14psi.
You must have a good sand flag, at least 3m high from ground level.
Use channel 10 UHF, but also scan, and keep a listen out for any radio traffic that may be in the area that you will be.
Do not go like a Bull at a
Gate, gentle as she goes are the best results.
When at the top of the larger dune in the area that you are going over, put out a call on channel 10, asking if anyone is travelling the track that you are travelling.
Set up
camp early, so you can go for a walk, get the fire going and take in the surroundings before it gets dark.
Having said what I have said, if you are experienced, you will know what I am talking about.
Drive to the conditions and your experience and will have a great trip.
390242
Follow Up By: Member - Mick O (VIC) - Friday, Nov 06, 2009 at 21:50
Comprehensive reply Stephen, I'd just add carrying a little fire wood with you can be very advantageous and make sure you have decent tyres with you. If your using splits and tubes, be aware that sand can get past the bead and
ruins your tubes really fast if you are using really low pressures. A good A/T or better is an advantage. As tenpounder said above, a stiff wind will erase all tracks on the dune tops within minutes so care is needed in those conditions and a UHF is a must. Use frequently to announce your position.
Hope you enjoy it. Fantastic trip from either direction. Bit of info from my previous trips
Big Red west to Poeppels CornerWest on the French, Knolls Track and WAA Line to ErebenaWAA, Colson Track & French Line to Dalhousie
Cheers Mick
658087
Follow Up By: Member - Stephen L (Clare SA) - Friday, Nov 06, 2009 at 22:35
Hi Mick,
We will have to get you out into the
Simpson Desert proper one day. LOL. After our Geo crossing, over 400 kilometres of no tracks from
The Twins, out to the Colson, then on to Geosurvey
Hill, then north-east to a confluence, then down to the Geographical Centre, the usual Simpson tracks are a walk in the
park and like driving on a bitumen road. When we got back onto the QAA, nearly ever dune that we approached, some vehicle had been very badly bogged, and must have spent hours filling in the tracks with cane grass, while we just glided over with no problems. After a few dune we thought that it would have to stop, but no, all the way to Big Red. We mentioned this in
Birdsville and was told than some European Tourists in a hired Troopy went through in 40 psi and got bogged on every dune, what a joke. Just imagine how much
fuel they must have used.
Image Could Not Be FoundImage Could Not Be Found
658095
Follow Up By: Member - Mick O (VIC) - Friday, Nov 06, 2009 at 23:36
Stephen,
I tackled a bit of that in 1984 in a Datsun 720 Kingcab 4x4 ute Grossly underpowered with the L18 - 1800cc 4). I had a rack setup in the back and cut myself six lengths of 50mm weld mesh that were about 2m x 450. The good old days of compass, map and sextant map. My mate was a navigation buff who was proficient with the sextant. No GPS or moving map LOL. Hired a "Flying Doctor Radio" Ha. Took me 23 years to go back LOL. Bloody tough going. I must digitise those photos and dig out the travel journal.
Cheers Mick
658098
Follow Up By: Member - Stephen L (Clare SA) - Saturday, Nov 07, 2009 at 09:32
Hi Mick
The one sure thing about a true cross country Simpson trip is it will not matter if it was 1964 when Reg Sprigg made the first crossing, or 2010 when Fred Blocks does it, it will not change. As you would know, there are some real mother of dunes out in the centre and one soon becomes an expert at picking the easiest way over - or around the hardest. There is not the luxury of a little speed to get over them, just pick the best path and avoid these dreaded moguls.
658113
Follow Up By: Member - Boobook - Saturday, Nov 14, 2009 at 08:05
Stephen et all, I am going on my first simpson trip next year.
Can you elaborate on the wood situation if we did one of the heavily traveled
routes. Say the French line. Will we need to carry in every bit of wood we need?
659012
Follow Up By: Member - Stephen L (Clare SA) - Saturday, Nov 14, 2009 at 08:34
Hi Boobook
The Simpson is a great place, and if you have not been out there before, you will have a ball. Like all have mentioned, your biggest enemy is too high a tyre pressure. Most times, you will be travelling slow, second and third gear high range. There will be times when you can faster and use other gears, but for a first trip, just take it all in. Depending on which way you are crossing, you will find that wood is getting scarce in the western parts of
the desert, but will always find enough for that nightly
camp fire. The eastern sections of
the desert, just before
Poeppel Corner, you get into the Gidgee Country with a lot more solid timber around. Our motto was when you see good timber collect it, as when you get to a
good camp site, thousands of other people have thought the same, and timber could be scarce. You do not need ton's of wood, and you will know after a few camps what you need, and us it sparingly. It would be impossible to bring enough timber with you, plus you would not have the room.
659013
