03 Prado GX Turbo Diesel
Submitted: Friday, Nov 06, 2009 at 18:34
ThreadID: 73573 Views:4522 Replies:7 FollowUps:6
G'day everyone, i have recently sold the Patrol & now have the opportunity to buy the above vehicle. I have looked at it & taken it for a drive, it seems to drive nice, but i am wondering if there is anything in particular i should look out for???
Any advice will be taken on board (even advice such as "don't touch it, buy another Nissan" hahahaha
Reply By: Member - Kroozer (WA) - Friday, Nov 06, 2009 at 19:32
Look for cracks in the inner guards(under bonnet, around battery etc) and on dashboard. Check back door for cracks along seams also. Check in jack compartment in rear and tool compartment on rear door for dust/rust etc, get a good indication to where its been. Also get underneath of course and check thoroughly for rust/dings/leaks etc.
Very easy to get stung with an ex mine Prado these days.
AnswerID: 390292
Reply By: RobertHL (SEQ) - Friday, Nov 06, 2009 at 19:33
Hi Dave, "OTHER VEHICLES."
Sorry could not help myself.
Bob.
AnswerID: 390293
Follow Up By: OREJAP - Friday, Nov 06, 2009 at 22:03
Hi Dave, A 2003 NP GLS Pajero 3.2 Did Auto would be better. Sorry couldn't resist it either!!
FollowupID: 658090
Reply By: On Patrol & TONI - Saturday, Nov 07, 2009 at 06:57
Hi Dave
I see the Land Rover 130 dual cab utes are not too expensive new now & they come std with a dash board and upholstery & everything including fresh air.
Cheers Colin.
AnswerID: 390326
Follow Up By: Dave... Adelaide (SA) - Saturday, Nov 07, 2009 at 15:34
I think i'd get more joy out of a Lada Niva ......PMSL
FollowupID: 658138
Reply By: Anthony - Saturday, Nov 07, 2009 at 08:30
Hi Dave,
I bought the same model Prado, the 03 GX diesel manual, about 2.5 years back for $38,000. It was an ex Vic Government 4wd. Then 65,000kms, now 123,000kms. It going great still, as you would hope at that number of kms.
I had our local 4wd guy go over it before the purchase. He did a simple check of the engine compression by driving the 4wd onto a steep slope about 40 degrees with the front proint down, then turned off the engine and left in gear (1st or 2nd ???) with the brake off.
If the engine compression was poor, the theory was that the 4wd would move forward with the engine turning over from the weight of the 4wd on the slope and in gear.
If your GX has the std 6.5inch steel wheel, as mine did, I fitted 17 by 8inch stell rims and 245/70-17 tyres (Cooper STT). With this tyre size,I didn't need to add flares and the tyre diameter is abou 777mm, which is the same as the std GXL tyre dia. So the speedo was spot on still.
I think the GX 03 Prado is great, it doesn't have those plastic flare that fall off after a bit of a bump out 4wding.
AnswerID: 390333
Reply By: Cruiser .- Saturday, Nov 07, 2009 at 09:46
Dave,
As you know I have a Prado (04 GX) and all of the above replies (well the serious ones anyway) have good advice.
You won't regret it if you do buy one, but as Kroozer said, be carefull its not an ex mine vehicle.
Cruiser
AnswerID: 390342
Reply By: PradOz - Saturday, Nov 07, 2009 at 13:28
If its had a hard life check all cracking. I havent seen one with all cracks as mentioned as yet. I have heard about dash cracking though (not seen any yet) in some 03 and 04 models.
I know someone who was a dedicated Paj owner with many new models to his name over the years. It was only after getting a dead set lemon that Mits would not touch (under a year old and even under warranty as they could not fix it) he tried a Prado and said he would never go back. He said the ride is so much better. Its only when buying a Prado new you get hit so hard in the pocket that you start to look at the others for sale....
AnswerID: 390364
Reply By: Dave... Adelaide (SA) - Saturday, Nov 07, 2009 at 15:32
Thanks for the replies everyone, checked it all out & everything looks the goods... Have put a deposit on it & as of Monday i will be driving a Prado...
AnswerID: 390372
Follow Up By: 120scruiser (NSW) - Saturday, Nov 07, 2009 at 19:10
I had an 05 GXL TD.
Cracks under the second battery tray.
Unbelievable amount of dust ingress, rear doors, vents etc everywhere. For a late model car, it was disgusting for dust and that was with a cabin filter.
Poor fuel economy, (mine was auto) and very under powered.
Extremely comfortable and quiet car to drive though.
I went back to an 80series.
Scott
FollowupID: 658150
Follow Up By: Anthony - Saturday, Nov 07, 2009 at 20:57
In our case, our 03 GX is very good at keeping out dust. The Prado has a dust filter for the air flow intothe cabin. The filter is behind the glove box. I checked our filter before the outback trip and found that the filter material was missing. I fitted a filter material that I purchased and cut to size.
I wish our camper had a good a dust seal as the Prado.
FollowupID: 658157
Follow Up By: 120scruiser (NSW) - Saturday, Nov 07, 2009 at 21:17
The only Prados that have the cabin/dust filter fitted is the Grande and the VX. The GXL and GX models have the tray for the filter but the filter is not fitted. The filter does jack bleep in my opinion.
FollowupID: 658160
Follow Up By: Member - Kroozer (WA) - Saturday, Nov 07, 2009 at 22:45
My GXL has the filter fitted. I use my air con on recirc and never have prob with dust.
FollowupID: 658170
