OL Mate" Behind the front seat finally karks it!..lol.
Submitted: Friday, Nov 06, 2009 at 19:56
ThreadID: 73575 Views:3950 Replies:4 FollowUps:11
Had to jack the truck up to- day to replace a wheel bearing, and bugger me if the 2t bottle jack i've had for twenty years stuffed up, seals blown',oil everywhere!.....can't complain after all that time,but one thing though you cant trust things to much, it lifted the vehicle, but also came down pretty quick to!, pays to keep the head out from underneath a jacked up truck as much as possible!!, me beginning to think..lol.
Cheers Axle.
Reply By: disco driver - Friday, Nov 06, 2009 at 20:31
Axle,
That would have to be the Defender one ,wouldn't it?
Toyota haven't worked out how to make a hydraulic jack that works, they still use screwjacks that were invented even before the first Landrover S1 was thought about.
LOL
Disco.
AnswerID: 390300
Follow Up By: Member - Axle - Friday, Nov 06, 2009 at 20:49
Dead right there mate! .......hahahah!.
Cheers.
FollowupID: 658075
Follow Up By: Member - Graham H (QLD) - Friday, Nov 06, 2009 at 20:58
Might be slow and old Just like a Landy LOL
but at least they dont drop the lot on your head
FollowupID: 658077
Follow Up By: Member - Timbo - Friday, Nov 06, 2009 at 21:14
Of course it was the Landrover jack - it was the one leaking oil everywhere, er, marking its territory :-)
Yep, I'll have a screw jack over a hydaulic anyday - virtually maintenance free for a bit of kit that you hardly ever use but depend on when you do need it! I also find them much faster than a the hydraulic jacks.
Mind you, when I had to change a tyre on a coach I was thankful it had a hydraulic jack and not a screw jack - it was a little more than 2.5T!
FollowupID: 658082
Follow Up By: Member - Axle - Friday, Nov 06, 2009 at 21:17
Not so sure about that Graham?, The screw jack supplied with my 100series, with all its little bits with the extension handle is nothing short of being pathetic!!., It all needs to be twice the size!, Jack inclued.
Cheers Axle.
FollowupID: 658083
Follow Up By: Member - Axle - Friday, Nov 06, 2009 at 21:20
INCLUDED!, i think.
FollowupID: 658084
Reply By: Willem - Friday, Nov 06, 2009 at 20:37
Luckily the truck didn't fall down on to the 'Axle'....lol
Yeah, keep yer head out of the way!!
AnswerID: 390301
Follow Up By: Member - Axle - Friday, Nov 06, 2009 at 21:03
G/Day Willem
LOL!, ...Bent Axles are hard to get straight again!.
You get so complacent over time with different things ,when something happens , it can be a worry...lol.
Cheers.
FollowupID: 658079
Follow Up By: Member - Bentaxle - Friday, Nov 06, 2009 at 22:13
Axel
Once bent they stay bent
Mike
May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
FollowupID: 658092
Reply By: get outmore - Saturday, Nov 07, 2009 at 06:00
gimmie a Valiant any day - they came factory standard with a high lift
AnswerID: 390321
Follow Up By: On Patrol & TONI - Saturday, Nov 07, 2009 at 06:52
VALIANT!!!!!
Jeeez!!!!! you really do need to get out more, he he he.
Colin.
FollowupID: 658102
Follow Up By: Wherehegon - Sunday, Nov 08, 2009 at 12:35
Spot on get outmore, my parents has 3 vals I had 3 of them, when bumper bars were real and made of steel, put the jack under them and the bumper would take the whole weight of the vehicle back or front end, use to use the tyre lever to jack it up and down, they took up a bit of room in the boot but they did have a huge boot, bit shallow but.....Ah the good old days, no air or steer, wondered all over the road under hard braking but boy did they tow well, big stroke, 245, 265, then my last was a CM with a 318 V8 that did have air and steer, the front bucket seat were like my seats in my lounge room at home LOL Regards Steve M
FollowupID: 658251
Reply By: Ozboc - Saturday, Nov 07, 2009 at 06:55
yes never trust ANY lifting gear - new or old -- always use stands after all accidents don't happen over a 5 min period they happen instantly and when not expected
Boc
AnswerID: 390325
Follow Up By: Member - DAZA (QLD) - Saturday, Nov 07, 2009 at 09:01
Hi All
When ever I jack the 4wd up to change a tyre I allways place the wheel under the edge of the vehicle, if the jack moves, you don't end up with the vehicle sitting on the ground.
FollowupID: 658111
Follow Up By: Ozboc - Saturday, Nov 07, 2009 at 11:37
i do that in addition to the stands --- don't care if it falls on the floor -- rather not have it fall on my lap / head
Boc
FollowupID: 658117
