Lithium Manganese Batteries
Submitted: Sunday, Nov 08, 2009 at 19:57
ThreadID: 73622 Views:3118 Replies:2 FollowUps:1
Well you know you get obsessed with power and all and you take notice when this sort of stuff pops up. My question is with the chart, Charge is rated at "77amphours" but "maximum power yield" is 120amphours:
THis is the web link, the chart reproduced below didn't quite transplant as the right format - http://www.torqeedo.com/en/hn/products/power/technical-data-measures.html
Technical data & measures (mm)
Torqeedo Power 26-77
General data
Capacity
2.0 kWh
Charge
77 Ah
Rated voltage
25.9 V
Final voltage
29.05 V
Weight
19 kg
Dimensions (length x width x height)
510 x 176 x 223 mm
Electrochemical base
Lithium manganese (LIMA)
High-current resistance
Maximum yield
3.1 kW
Maximum power consumption
120 A
Ladung
Charge characteristic
CC-CV (Constant Current - Constant Voltage)
Duration of charge using 350 W charger
< 6 hours
So what does this mean? Can you draw 77amhours out of it or 120amphours, not that I'd ever be able to afford one but know, we dream on don't we.
A 19kg battery that is good for 120amphours and charges like an AGM, I'd like that!
Reply By: Member - Mike DID - Sunday, Nov 08, 2009 at 20:27
Unfortunately it suffers in the translation from German
"Maximum Power Comsumption" should read maximum load current - the unit is amps (A) - NOT amphours.
It clearly states that it's 77 amphours.
But it's a 24 volt battery - where would you use it ?
AnswerID: 390513
Follow Up By: Member - Porl - Sunday, Nov 08, 2009 at 20:38
uh oh, thought it was 12v, sorry. Was looking into their claimed lighweight freshwater outboard electric motors and followed the links to their batteries ...
FollowupID: 658316
Reply By:- Monday, Nov 09, 2009 at 22:21
forget it, they want 7 grand of hard earned aussie dollars for it....
best regards, mr.batteryvalue
AnswerID: 390681
