garmin gps
have purchased garmin gpsmap60csx.without a micro card. .Machine has no maps etc.tried to do on line downloads to no avail. Cant find Garmin ph number to call for help. Any assistance really appreciated.
thank you bruce.
Reply By: Member - Lia H (SA) - Monday, Nov 09, 2009 at 10:07
Hey... if you google Garmin software, you will come up with loads of places that sell the software, alot sell on the cards already.
The downloaded software that I found was not from...the best sources. But I know there are many legit software download places.
We got ours from Johnny Appleseed, and they had loads of software and seem quite helpful. I'd ring them or JB Hifi or Supercheap or any of the bigger retailers.
AnswerID: 390572
Reply By: KennyBWilson - Monday, Nov 09, 2009 at 10:08
the 60Csx doesn't have an internal hard drive so you won't be able to load any maps into it,
It could have world wide base maps or an Australian base map which won't show you much
Buy yourself a 2Gb mircoSd card and then download Shonkymaps, and OSM
GPS Australia is a good forum to join
AnswerID: 390573
Follow Up By: Bonz (Vic) - Wednesday, Nov 11, 2009 at 17:50
whats OSM?
FollowupID: 658718
Follow Up By: KennyBWilson - Wednesday, Nov 11, 2009 at 21:40
Open Street Map , it's getting very big around the world.
FollowupID: 658758
Reply By: Member - Stephen L (Clare SA) - Monday, Nov 09, 2009 at 14:07
Hi Bruce
Firstly you have purchases a top hand held GPS, I have this same model, they are great and very user friendly.
Firstly the micro sd card is only for extra maps like the Garmin Topo Australia or Shonky Maps and do not come as standard when you buy the unit.
Did you buy the unit here in Australia or did it come from overseas - like buying it from eBay?. Australian units still have a very basic map set up. If you have no map of Australia when zoomed right out, it sounds like an overseas unit.
I will get their 1800 phone number from work and post it here tonight when I get home from work.
AnswerID: 390599
Follow Up By: Travelling Pixie - Wednesday, Nov 11, 2009 at 21:45
I got an ebay unit 18 months ago and the base map is of the world (ie. including Australia) with some detail
I loaded Shonky and went to a number of websites (including here) for Points of Interest to load
Also bought OziExplorer and NatMpas
Does mostly what I need without having to purchase anything else.
FollowupID: 658759
Reply By: Member - Tony V (NSW) - Monday, Nov 09, 2009 at 14:13
Just Googled Garmin Australia
Garmin Australia
Contact Garmin
Technical Support: For help and support, please visit our support pages.
Garmin Australasia
Unit 19
167 Prospect Highway
Seven Hills, NSW 2147
Australia Customer Support: 1800 235 822
Australia Fax Number: 02 8882 6150
New Zealand Customer Support: 0800 427 652
New Zealand Fax Number: 0800 427 646
AnswerID: 390601
Reply By: Member - Fred B (NT) - Monday, Nov 09, 2009 at 19:58
Hi Fence,
are you using "mapsource" to transfer your map files to the GPS?
regards
Fred B
VKS 737: Mobile/Selcall 1334
AnswerID: 390652
Reply By: fence - Monday, Nov 09, 2009 at 22:55
thank u all for the info. I bought the unit from Pally Paddin ,ringwood vic.Took it back an the manager explained all. salesman didnt know obout the extra card.Initial cost was $450..Unfortunatelly cost me an extra b$200l; but now got all maps .I am a little "peeved" for want of better word, as the screen is cluttered , ie top half covered with non pertinant info when u look at map.No doubt "my wife will figure out how to get rid of it.However if someone has the answer would make my life easier.
thank you again. bruce.
AnswerID: 390690
Follow Up By: Member - Andrew (QLD) - Wednesday, Nov 11, 2009 at 18:25
- push MENU on the map page, select DATA FIELDS..., select MAP ONLY.
You can also change whether the fields display whilst navigating by selecting the GUIDANCE TEXT... option in the map menu. Select the desired option.
Hope that helps.
Andrew
FollowupID: 658724
Follow Up By: Member - Andrew (QLD) - Wednesday, Nov 11, 2009 at 18:27
BTW Page 41 of my manual....should be the same for you hopefully.
Andrew
FollowupID: 658725
Reply By: fence - Wednesday, Nov 11, 2009 at 18:48
you are spot on. Thank you andrew.
AnswerID: 390905
Reply By: Travelling Pixie - Wednesday, Nov 11, 2009 at 21:47
i have the 60cx (no compass or altimeter although it does triangulate an altitude and bearing) and it's great!
AnswerID: 390931
